Rear Drum Brake Lever
MahatmaAndhi
PostPosted: 18:06 - 21 May 2017    Post subject: Rear Drum Brake Lever Reply with quote
Hi guys,
The Suzuki is alive... for now. Assuming that I've done everything correctly (doubt it), I just have to small issues left: changing the brake lever (shouldn't be an issue) and the back brake has stopped working.
https://images.cmsnl.com/img/products/leverrr-brake-cam_medium6445148000-01_29ad.jpg
This is the part that I am referring to.
The circular bit with the teeth inside is sitting either side of the cam brake. I can't seem to prise it open so that I can resit it where it should be.
I can't buy a new one either, because I still need this one open to come off.
Any suggestions on how to widen that gap so I can get it back where it should be? Then I can clamp it shut with the nut and bolt combo.
2008 Aprilia Sportcity 250
kgm
PostPosted: 19:33 - 21 May 2017    Post subject: Reply with quote
Spray it with WD40 or plusgas type stuff, give it a wiggle till the rust is free and stick an old screwdriver into the gap to prise it wider. I assume you've taken the bolt all the way out?
Chris45
PostPosted: 19:39 - 21 May 2017    Post subject: Reply with quote
As above. Also try to get a thin flat bladed screwdriver in between the gap and prise open should be enough to loosen it and remove.
Honda CG125>Suzuki GT185>Honda CB 250N>Suzuki GSX400>Honda CX500B>Kawasaki GPZ305> Kawasaki GPZ550>Kawasaki GPZ500S+BMW 650GS
wristjob
PostPosted: 19:41 - 21 May 2017    Post subject: Reply with quote
have you taken the clamp bolt out completely?
as they usualy sit in a groove.
if you have then some wd and a lever will move it in no time
MahatmaAndhi
PostPosted: 20:04 - 21 May 2017    Post subject: Reply with quote
Yep, the bolt is completely out.
I have gallons of WD40, so I guess I just gotta find some kind of flathead screwdriver (harder than it sounds in this house)
The last post was made 6 years, 335 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.37 - MySQL Queries: 17 - Page Size: 44.58 Kb
