maspito |
maspito Derestricted Danger
maspito |
Posted: 20:19 - 24 Jun 2017 Post subject: UPDATE... |
I removed the Rotor Generator again, and function tested the Sprag / Starter Clutch against the Idle Gear. It worked perfectly, so that couldn't be the root cause for why the Start Clutch wasn't engaging.
I then realised that the Idle Gear must be spinning in the WRONG direction, which would explain why the Sprag Clutch wouldn't engage!
But how could it be spinning int he wring direction I hear you cry...
Well... the reason was....
When I'd serviced the Starter Motor and was putting everything back together, I hadn't paid attention to the orientation of the cylindrical housing which has the magnets attached on the inside. So the magnets where roughly 1/8 to 1/4 turn out of phase, which resulted in a reverse polarity, and therefore spinning my Start Motor, and thus the Idle Gear, in the wrong direction (clockwise)!
I correctly aligned the Starter Motor housing and boom. Starter Motor spins in the CORRECT direction (anit-clockwise) and now turns the engine over!!!
However.. My battery is completely dead from all the testing I used it for, so I will check back in a day or two to confirm case closed.
Sorry if you all got bored of my shenanigans, but if just one person googles problems with their starter system, and they find my ramblings to be their solution, then it was all worth it
PEACE. |
maspito |
pepperami |
pepperami Super Spammer
maspito |
maspito |
The last post was made 6 years, 306 days ago. Instead of replying here, would creating a new thread be more useful? |
