Redex diesel system cleaner.
Bike Chat Forums Index -> Random Banter Goto page Previous  1, 2
stevo as b4
PostPosted: 16:19 - 10 Jun 2017    Post subject: Reply with quote
You often see on engines where a head gasket has failed between the water ways and the fire ring of a cylinder, that the valves and combustion chamber look very clean compared to the other cylinders.
Its not going to be a huge flood of coolant into the cylinder normally, but a slow dribble that probably collects when the engine is left and then cold started later.
On FI engines, I believe that sometimes the water/meth injection systems also do leave the internals looking cleaner than they otherwise would be.
What I'd like to know is if it's possible for some kind of fuel additive to clean injector tips and nozzles as well as an ultrasonic bath would?
PostPosted: 17:32 - 10 Jun 2017    Post subject: Reply with quote
The most common issue on 'modern' injection systems I see is inferior fuel, and or poor filtration.
The carbon build up is not so bad if the engine is run at it's rated load there should not be any build up.
But wear in injectors is difficult to 'wash off'. Smile
sickpup
Old Timer
PostPosted: 22:00 - 10 Jun 2017    Post subject: Reply with quote
CrippleTron wrote:
used in my perkins deisel on boat and seemed to run smoother but maybe placebo
Obvious placebo, Perkins are never smooth.
Ben90
PostPosted: 08:34 - 11 Jun 2017    Post subject: Reply with quote
I did once use this product called Revive which you sprayed into the air intake as close to the compressor side of the turbo as possible while the engine was running at a series of set RPMs, turned it off halfway through, let it soak for a bit and turn it on again and rev some more.
It filled my whole street with thick clouds of steam and left a dirty skid mark behind the car Laughing but it fixed an issue I had in my turbo where the vanes would stick momentarily causing hesitation. Thumbs Up
Probably dindunuffin to injectors mind.
Yamaha FZ6 S2
The last post was made 6 years, 323 days ago. Instead of replying here, would creating a new thread be more useful?
Page 2 of 2
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.73 - MySQL Queries: 17 - Page Size: 42.99 Kb
