Changed Oil level at 2500 miles but super dry wtf?
Valerian95 This post is not being displayed because the poster is banned. Unhide this post / all posts.
Chris45
PostPosted: 16:34 - 24 May 2017    Post subject: Reply with quote
A hot metallic or strong burning oil smell is always ominous.
Are you sure it was topped up with the correct quantity? Any sign of it burning oil? Smokey exhaust?
Whatever, top it up to the max, let the engine turn over for a few secs (use the kill switch to stop the engine from firing up). Then start it. Don't rev it, let it settle and listen. Check it every 500 miles. It's a 50/50 chance the engine is fekked.
Honda CG125>Suzuki GT185>Honda CB 250N>Suzuki GSX400>Honda CX500B>Kawasaki GPZ305> Kawasaki GPZ550>Kawasaki GPZ500S+BMW 650GS
NJD
PostPosted: 16:57 - 24 May 2017    Post subject: Reply with quote
Valerian95 wrote:
If very little or none comes out I am going to be a sweating very hard.
Take your time to look at if anything comes out with the oil as well, that might tell you a thing or two.
edit: like little metal pieces.
PostPosted: 17:04 - 24 May 2017    Post subject: Reply with quote
What could that indicate?
Your engine is in more bits than was designed.
Triumph Trophy Launch Edition
PostPosted: 17:07 - 24 May 2017    Post subject: Reply with quote
Change the oil. I would flush out with cheapy Asda oil then put a decentish one in, Motul or the like. Make sure you put in the correct amount and check it on the dipstick, almost certainly with the dipstick resting on the threads (not screwed in) and bike level.
pompousporcup...
PostPosted: 17:27 - 24 May 2017    Post subject: Reply with quote
cbr125? ride at the limit (of the engine) a lot by any chance? by that i mean high rpms..
my old 500 would not lose a drop through town riding for over 12months. I then did a few weeks on the motorway pushing the engine and it burned off half the sumps worth before i noticed.
PostPosted: 18:03 - 24 May 2017    Post subject: Reply with quote
Yes. there was a good fat chunk of dual carriageways and recently a little now on motorways- that stretches it to 10RPM just a little below redline- I think 750 miles went on that. Hmm wow how interesting the effect of high RPM's -it's completely devoured the oil! Thanks to all- I had no idea- for some mad reason thought the bike's usage of engine oil was just uniform no matter how you rode- silly when I think about it now... of course more lubricant is needed when the parts are moving faster and it's more stressed Doh!
just shows these things are really intended by manufacturer for in town riding.
No, in a 4 stroke engine you are perfectly correct, it should, theoretically, use no oil irrespective of riding style. However this is not a theoretical world.
My Trophy (ex demo, probably ranted from mile 1) uses nil, nada, not a drop irrespective of how I ride it. My Street Triple (run in exactly as the manufacturers guidelines) I had to regularly top up. There is no real rhyme or reason for how mch oil they use.
PostPosted: 19:05 - 24 May 2017    Post subject: Reply with quote
Thanks for making us guess the bike.
A 125? No chance should you leave that for 5,000 miles between changes, let alone checking it. It's not one of the bikes that are known for devouring oil (CBF125, YZF-R125 spring to mind) but I'd be checking it every time I filled the tank, and changing every 1000 - 1500 miles or so. It's only a litre, and it's all that's stopping your engine from becoming a grenade.
Robby
Dirty Old Man
PostPosted: 19:23 - 24 May 2017    Post subject: Reply with quote
You've had enough hints, what bike is it?
Either your manual is wrong, or you are reading it wrong, but I've never come across a manual that tells you to check your oil level every 2500 miles. They usually say check it weekly, or every time you fill up with fuel.
2500 miles is more likely to be the oil change interval. On a 125, I'd change it twice as often as that.
PostPosted: 21:46 - 24 May 2017    Post subject: Reply with quote
Valerian95 wrote:
but what could have caused the oil to disappear like this? in 2000 miles? the heck? seriously unheard of.
You've obviously never heard of an FZR....
Is this Tritey again?
Commuter_Tim
PostPosted: 21:47 - 24 May 2017    Post subject: Reply with quote
Still ignoring "what bike?"
At this point I'm declaring 'Tritey' and demanding to claim my 5 ponds.
I ride a Bandit 600... badly.
PostPosted: 21:48 - 24 May 2017    Post subject: Reply with quote
Damnit, I edited in Tritey whilst you were posting...
Commuter_Tim
PostPosted: 22:45 - 24 May 2017    Post subject: Reply with quote
We can both be right, and Tritey can still be losing his touch.
I'm not mad, I'm just disappointed, he used to be entertaining. Folded arms
Mark65
PostPosted: 08:42 - 25 May 2017    Post subject: Reply with quote
Valerian95 wrote:
Workshop manual
Edit : Oh I realise you said check and it says change- so when it's decreasing every week I'm supposed to top up until full and then at the 5000 mile mark like it says just completely change the whole thing?
CBR125
rpsmith79
PostPosted: 09:11 - 25 May 2017    Post subject: Reply with quote
Just checking, but you are checking the oil level when the bike is upright aren't you, not when it's tilted over on the pavement on it's side stand aren't you
skatefreak
PostPosted: 09:37 - 25 May 2017    Post subject: Reply with quote
rpsmith79 wrote:
Just checking, but you are checking the oil level when the bike is upright aren't you, not when it's tilted over in the back of a council van (sniggers) on it's side stand aren't you
pompousporcup...
PostPosted: 10:28 - 25 May 2017    Post subject: Reply with quote
Take it as a lesson learned. I echo others advice of changing the oil much more frequently as its only a fiver or so a litre and could ensure your engine lasts that much longer.
Also, don't keep it at higher rpm if you are on the motorway (assume you dont have L plates and know the rules yes?). If it were me i'd be uber paranoid about mechanical failure when pushing the engine causing a lockup and sending me down the road. There is no shame in riding at 55-60 (lol)
The last post was made 6 years, 335 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.38 - MySQL Queries: 17 - Page Size: 136.13 Kb
