classified-moto |
classified-moto Derestricted Danger
Teflon-Mike |
Teflon-Mike tl;dr
Posted: 21:36 - 24 May 2017 Post subject: |
Do you expect to get a MOT on this thing?
If so go read the SVA rules... modify the main structural member.. ie 'the frame' bike needs to be single-vehicle-approval, and re-registered.
What you are talking abut cutting BTW is the seat rails. Man backbone extends from the head-stock to the suspension mounts; rails around the engine are the 'engine cradle'.
Cut ANYTHING between the headstock and suspension mounts, you will certainly require SVA. abreviating the seat rails, you might just eek through regs, but READ THEM FIRST before you get the angry-grinder/hack-saw out! And yes, take outthe stay between the rails, the abreviated rails will need some-hoe bracing. Needn't be welded, if you are cunng a bolt-in cross member may be sufficient. But it will need bracing, especially if you have ditched anything else that might bridge & stiffen them like a steel mudguard. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
Nobby the Bastard |
Posted: 21:44 - 24 May 2017 Post subject: |
Teflon-Mike wrote: | Do you expect to get a MOT on this thing?
Cut ANYTHING between the headstock and suspension mounts, you will certainly require SVA. abreviating the seat rails, you might just eek through regs, but READ THEM FIRST before you get the angry-grinder/hack-saw out! And yes, take outthe stay between the rails, the abreviated rails will need some-hoe bracing. Needn't be welded, if you are cunng a bolt-in cross member may be sufficient. But it will need bracing, especially if you have ditched anything else that might bridge & stiffen them like a steel mudguard. |
Did you look at the picture? He's talking about the frame loop at the back of the bike. Yes it will reduce the strength of the frame, but a 125 modified wanker-style isn't really going to ridden in a manner thats going to stress the frame so meh. ____________________ trevor saxe-coburg-gotha:"Remember this simple rule - scooters are for men who like to feel the breeze on their huge, flapping cunt lips."
Sprint ST 1050 |
classified-moto |
Nobby the Bastard |
cresad |
cresad Nova Slayer
classified-moto |
redeem ouzzer |
classified-moto |
Nobby the Bastard |
classified-moto |
Nobby the Bastard |
redeem ouzzer |
Jay2903 |
Jay2903 Scooby Slapper
WD Forte |
WD Forte World Chat Champion
Teflon-Mike |
Teflon-Mike tl;dr
Posted: 23:23 - 24 May 2017 Post subject: |
classified-moto wrote: | I think it's great the amount of assumptions you've made when you haven't even seen my bike and don't even know what kind it is and what modifications have been carried out but you carry on |
Much as I am scared to even be associated with, more in even slight agreement with the flexi-flyer fan.. describing your creation in the lexcon of the geeknik as Brat-Chop cafe-street scrambler, hipster wannabee 125 DOES sort of set the tone of our expectatons.... if not yours.... admission, then, you cant/dont have equipment/wont pay some-one else with either to weld, also speaks volumes about the level of met-fab skill and attention to detail you are prepared to put into this thing... you clam to be 'very high'!?!
As to knowing what 125 it might have started out as? Given how often such similar suggestions pop up, I would lay 8:1 odds on it's something Chinese, or heave forbid I am going to be seen on a thread agreeing not just with GT200, but the Borg too, and that idea is making me feint! But If it's anything BUT a generic Chink, probably CG clone/derivatve; then anything you do to it is likely to make it both less valuable, less reliable, and less rideable... only reason that that wouldn't apply to a generic chink, is that they have blugger all value or reliability to start with... so what the heck!
Nobby the Bastard wrote: | Did you look at the picture? He's talking about the frame loop at the back of the bike. |
Yup, hence offering clarification between seat-rails, back-bone and engine cradle.
Nobby the Bastard wrote: | Yes it will reduce the strength of the frame, but a 125 modified wanker-style isn't really going to ridden in a manner thats going to stress the frame so meh. |
Yes, again, and tend to agree, but I still reckon that the frame rails need bracing, some-how.. unbraced the rails will be free to flex, which might not unduly effect suspension performance, given the rather dire plungers usually employed on lo-po lightweight T-Shocks, but it's ot going to help much! While un-connstrained they can pass vibraton and flex itio anything bolted to them.. and a cheap GRP brat-cafe-tracker seat is likely to not sit well or long on them moving about....
They omitted the stay-bracing on my Cota-Frame when they redesigned it for the 1980 season, having magestied the cradle, and heavily braced the back of the back-bone, moving top-mounts to the apex, and it's a bugger for cracking plastic back mudguards at the end of the rails.... see similar on a lot of other 'specials' with abbreviated rails too... given how well this particular example is likely to be executed, and how long its likely to last n regular disservice, it IS probably no great concern.... but still.. best not to encourage his delusions too much me-thinks. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
terrytibbs |
terrytibbs Derestricted Danger
Posted: 00:12 - 02 Jun 2017 Post subject: |
Teflon-Mike wrote: | describing your creation in the lexcon of the geeknik as Brat-Chop cafe-street scrambler, hipster wannabee 125 DOES sort of set the tone of our expectatons.... |
ZOMG some one used a WORD to describe their bike - quick call the fashion police, while your at it dob in all those people descibing their bikes as streetfighters, cafe racers, choppers..................
Teflon-Mike wrote: | you cant/dont have equipment/wont pay some-one else with either to weld, also speaks volumes about the level of met-fab skill and attention to detail you are prepared to put into this thing... you clam to be 'very high'!?! |
Let me guess, you were born with a welding gun in one hand and a plasma cutters in the other so you didnt have to start somewhere, hate to think of the state of your mothers chuff after she pushed out that lot
Teflon-Mike wrote: | As to knowing what 125 it might have started out as? |
Given the OP could have indicated whether mono shock or twin shocker do they really have to give exactly which model, when registered, colour of salesmans undies for you to answer a relatively simple question
Teflon-Mike wrote: | valuable, less reliable, and less rideable... only reason that that wouldn't apply to a generic chink, is that they have blugger all value or reliability to start with... so what the heck! |
Oh noes the OP might do something out of the box, he might actually you know change stuff, it might affect the value (given you have no idea what he paid for it thats a big assumption), perhaps just perhaps he realizes this and just wants to aesthetically modify something to make it his own and bugger the residuals. Its not like he's bought dozens of shit box Honda 125 twins and poured well over the resale value into them when it would have been easier to buy a good example in the first place.
Teflon-Mike wrote: | but I still reckon that the frame rails need bracing, some-how.. unbraced the rails will be free to flex, which might not unduly effect suspension performance, given the rather dire plungers usually employed on lo-po lightweight T-Shocks, but it's ot going to help much! |
Here is a picture of what is considered one of the best handling chassis's for around 30 years, it has held many engines from big singles, british twins, turned into cafe racers (on my god someones at it again, actually calling they're modified bike a NAME), it has held no end of japanese big bore 4's and even the occasional car engine. It has won races at the TT and no end of circuits. Please take a look at the rear of the frame and note the lack of....... https://s-media-cache-ak0.pinimg.com/originals/c4/55/28/c4552825675994284fc77776db4a78fe.jpg
Teflon-Mike wrote: | They omitted the stay-bracing on my Cota-Frame waffle and blah removed magestied the cradle (wtf who magnetizes a frame) ,yet more verbal diarrhea... best not to encourage his delusions too much me-thinks. |
Comparing a chassis designed for hard off road use to a road going light weight chassis is totally fair.....oh wait I think its you who delusional
[/img] |
Polarbear |
Polarbear Super Spammer
mentalboy |
mentalboy World Chat Champion
ThatDippyTwat |
Posted: 06:37 - 02 Jun 2017 Post subject: |
The problem with "Cafe racers" is not people building actual Cafe Racers. It's the Hipster shit purporting to be one, and is in reality a perfectly good bike that's been mangled into a style that does not suit. It's done badly and with no regard to safety, rideability or performance, it's looks over everything, and those are done with a large set of goggles on.
If you have the skill and taste to build an actual cafe racer (go do some research first), then you'll find most people will appreciate the build, even if it's not a thing they would do themselves. I can appreciate a well build chopper even though there's not a chance you'll find me on one.
'Streetfighters' get the same treatment... it's not usually a 'fighter, it's a race rep that someone binned and hasn't got the time, skill or wallet to bring back. Usually badly done, though not to the extant that Hipster bikes are, it's visually unpleasant, rather than fucking dangerous.
If you're modifying frames, get and learn to use properly, a fucking welder, and Rustoleum is your friend. ____________________ '98 VFR800 (touring) - '12 VFR800 Crosrunner (Commuting) - '01 KDX220 (Big Green Antisocial Machine) |
WD Forte |
Dave70 |
Dave70 World Chat Champion
Rogerborg |
Rogerborg nimbA
Posted: 14:42 - 02 Jun 2017 Post subject: |
Presumably OP has flounced, or ended up in a ditch?
If not, then at a minimum, I'd run a length of threaded rod across and just bolt (well nut) it together until funds allow for messing it up properly. ____________________ Biking is 1/20th as dangerous as horse riding.
The last post was made 6 years, 322 days ago. Instead of replying here, would creating a new thread be more useful? |
