YBRmark |
YBRmark L Plate Warrior
Posted: 09:33 - 26 May 2017 Post subject: YBR125 Custom starter was arcing |
First post My YBR125 Custom, 10 plate, was producing an arcing noise on the starter.
Took it off, cleaned out the carbon deposits, put it back together and re-fitted to the bike.
However now it sounds as though the bendix gear is not spinning up/engaging.
The battery does not hold much of a charge, enough to spin the starter motor which is failing to engage with the flywheel.
To add to the woes, the bike has been sat in the sun since sun up, and the 'fuel lock' issue when its been left in the sun too long seems to have reared its head.
So, plan to replace the battery and store it under the trees during the day to cool off - any tips on why the bendix motor might decide not too play if the starter motor has been removed and refitted? Can it just be down to a weak battery on its last legs ? Cheers. ____________________ Keep on Biking |
Tracer1234 |
Tracer1234 World Chat Champion
Posted: 17:45 - 26 May 2017 Post subject: |
Im not to sure about some of your issues. There are far more knwledgable guys that will help you trouble shoot.
What I do know is the starting in the sun issue is to do with the fuel pump, and this part was re-called by Yamaha, so you can get a new one supplied and fitted free at a dealer Had the same issue on my old ybr, and was sorted no problem.
Good Luck. ____________________ Riding: Yamaha MT-09 Tracer Occasionally Riding: 08 Suzuki SV650, Potato: 2011 Yamaha YBR Custom.
CBT 04/14. A: Mod 1 & 2 13/04/15 |
neptune8 |
neptune8 Nova Slayer
YBRmark |
Tracer1234 |
The last post was made 6 years, 326 days ago. Instead of replying here, would creating a new thread be more useful? |
