m i k e |
m i k e Could Be A Chat Bot
Posted: 15:40 - 03 Sep 2004 Post subject: GPZ brake pads and rear shoes |
Right i'm currently looking at buying new front disc pads and new rear shoes for the crappy drum brake, i'm looking at some EBC ones on mandp.com but there's so many to choose from! I was wondering whether anyone knows of any to get for it, as it's confusing the crap out of me!
The possibilities:
Front Disc Pads:
FA230R Front Brake Pads
FA258R Front Brake Pads
FA256HH Front Brake Pads
FA283HH Front Brake Pads
FA119R Front Brake Pads
FA128R Front Brake Pads
FA349R Front Brake Pads
FA105R Front Brake Pads
Rear Brake Shoes:
H3 series shoes (example: H315G Brake Shoes at £19.99)
K7 Series brake (example: K710G Brake Shoes at £22.99)
Cheers,
Mike ____________________ Bom Chicka WAHHH WAHHHHHHH! |
Guest |
Guest Brolly Dolly
m i k e |
Posted: 17:08 - 03 Sep 2004 Post subject: |
Oops!
1987 GPZ 500s is the bike, sorry about that!
Guest |
Guest Brolly Dolly
Posted: 17:27 - 03 Sep 2004 Post subject: |
I see what you mean, their site lists hundreds of pads and shoes when you enter your bike details.
I've got an old M & P catalogue that uses their parts codes - front pads Kevlar are EBC4129 and HH's are EBC4129HH (surprisingly )
Can't find a way of matching those numbers ot the EBC product codes unfortunately, looks like a trip to the local bike shop. |
m i k e |
Posted: 17:35 - 03 Sep 2004 Post subject: |
Yup so i'm a bit stuck! Thanks for your help anyway though mate, Hopefully the trusty oracle can shed some light on the case! I'm in no rush for the parts as it is because the bike's off road!
Scooby |
Scooby Scrappy Doo
m i k e |
Posted: 18:00 - 03 Sep 2004 Post subject: |
If you can mate, that's be bloody brilliant as there isn't any local bike shops around me
Cheers mate!
Scooby |
Scooby Scrappy Doo
m i k e |
Posted: 18:03 - 03 Sep 2004 Post subject: |
Yeah I know what you mean but as far as I know nope, if it helps there's pictures in my profile. It's an 1987 GPZ 500 S (A1 model). Thats about it really I think
Kickstart |
Kickstart The Oracle
m i k e |
Posted: 18:23 - 03 Sep 2004 Post subject: |
Keith you've gone and done it again, that was just what I wanted to hear and i'm pretty sure I remember seeing those model numbers on mandp.com! Sintered pads? Are these better I don't have a clue what sintered means
Guest |
Guest Brolly Dolly
Posted: 20:07 - 03 Sep 2004 Post subject: |
Get sintered pads!, they will wear out your disc a little more quickly but pattern front discs are pretty cheap, they make the brakes a lot more responsive and are not affected by the wet.
The drum brake on the GPZ500 is much better than the rear disc, the disc ones spit out pads as there is nothing to hold them in properly, they don't work very well and replacement discs are 140 quid!! Having owned both, the drum is definatley better.
If you have not already done so, I recommend that you order a braided steel brake line for the front disc brake when you order the pads (about 15-20 quid). The difference this makes to the feel and efficiency of the brakes makes it the best modification you could do to that bike, second comes progressive fork springs then getting phosphor bronze bushes and grease nipples fitted to the uni-trak casting. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
m i k e |
Posted: 20:39 - 03 Sep 2004 Post subject: |
Right I guess I'll be giving MandP a ring soon then for some sintered pads, the braided hoses I already have Then I lost you after the words 'best modification you could do to that bike..'
Thanks again for all your help guys!
Posted: 22:50 - 05 Sep 2004 Post subject: |
Progressive fork springs: These replace the standard springs in the front forks. Progressive springs are wound so the coils get tighter along its length. This means that the front suspension gets 'progressivley' stiffer the more it is compressed and stops the bike nosediving under braking. Made a marked improvement to the handling too.
Unitrak bushes: If you put your GPZ on the mainstand, then standing behind it get hold of the back wheel in both hands and pull it upwards, you will find there is quite a lot of free play before you start compressing the suspension. This is the case with all GPZs and is due to wear in some plastic bushes in the unitrak casting (the bit that the rear shock bolts on to), an MOT tester COULD fail your bike for this. The only way to fix it is to replace the bushes with new ones (45 quid!) which will be worn again within 500 miles. Most people just live with it and it doesn't seem to affect the handling.
I have a friend who is handy with a lathe who made me new bushes out of phosphor bronze (self lubricating metal) and put grease nipples in the casting so I can lubricate the bushes without stripping the bike. This is how it should have been made in the first place. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
Kickstart |
The last post was made 19 years, 230 days ago. Instead of replying here, would creating a new thread be more useful? |
