Abusive Dulwich Paragon member
Bike Chat Forums Index -> The Cycling Forum Goto page 1, 2  Next
sickpup
Old Timer
PostPosted: 22:57 - 26 May 2017    Post subject: Abusive Dulwich Paragon member Reply with quote
Had a toxic female cyclist kick off at me yesterday, my crime was to cross a solid line into a cycle lane when it became obvious she was going to pull out from between traffic in front of me.
So the bike has a camera on the front and I made some memes because I was bored.
https://www.bikechatforums.com/download.php?id=99692
https://www.bikechatforums.com/download.php?id=99693
https://www.bikechatforums.com/download.php?id=99694
M.C
PostPosted: 23:27 - 26 May 2017    Post subject: Re: Abusive Dulwich Paragon member Reply with quote
So you weren't in the cycle lane before that?
sickpup
Old Timer
PostPosted: 23:39 - 26 May 2017    Post subject: Re: Abusive Dulwich Paragon member Reply with quote
No, didn't need to be. Beech street used to be 2 lanes each way, now it has one wide lane and a cycle lane so loads of room.
Of course Toxie wouldn't have known either way considering she couldn't have seen through the cars.
M.C
PostPosted: 23:53 - 26 May 2017    Post subject: Reply with quote
Let's see the video of the cyclist getting their rage face on.
sickpup
Old Timer
PostPosted: 00:09 - 27 May 2017    Post subject: Reply with quote
It's a photo, testing the wrist band remote on roadhawk ride +
defblade
PostPosted: 06:46 - 27 May 2017    Post subject: Re: Abusive Dulwich Paragon member Reply with quote
Where you on a push bike or a motor bike?
Because, tbf, if it was a motorbike, then, yes, it was a crime Wink
sickpup
Old Timer
PostPosted: 10:24 - 27 May 2017    Post subject: Re: Abusive Dulwich Paragon member Reply with quote
A Motorcycle.
I'm impressed, you managed to remove all context with your comment such as the cyclist causing another vehicle to deviate its speed or direction after crossing a give way line Wink
Kawasaki Jimbo
PostPosted: 10:37 - 27 May 2017    Post subject: Reply with quote
Later that day; https://www.koolnews.gr/sites/default/files/styles/950x650/public/tora-tora/sexilikia.jpg?itok=mlcIEZf0
Copycat73
PostPosted: 18:42 - 27 May 2017    Post subject: Reply with quote
here.
caveat emptor
defblade
PostPosted: 09:39 - 28 May 2017    Post subject: Re: Abusive Dulwich Paragon member Reply with quote
A Motorcycle.
There's no give way lines in those pictures. Do you mean earlier on in the ride?
Anyhow, a cycle lane with a solid line is a mandatory cycle lane - not mandatory for cyclists to use, but motorised traffic must not enter it.
So the cyclist is not wrong to kick off at you.
Though if it was me on the pushbike you'd have had "the nod" instead while I spent the whole half a second for you to go past Very Happy Life's too short to rage Cool
M.C
PostPosted: 10:32 - 28 May 2017    Post subject: Re: Abusive Dulwich Paragon member Reply with quote
Pretty much ignored in London, lower thames street was unbelievably dangerous, solid white line yet motorbikes/scooters used to whizz down the cycle lane at speed. It's segregated now.
Copycat73
PostPosted: 19:59 - 28 May 2017    Post subject: Re: Abusive Dulwich Paragon member Reply with quote
would that be to keep the sanctimonious in or the pious out ? Wink
caveat emptor
sickpup
Old Timer
PostPosted: 10:53 - 01 Jun 2017    Post subject: Re: Abusive Dulwich Paragon member Reply with quote
And yet did you ever see an incident?
No I mean right at that point. Note the way I said she 'pulled out between traffic'
https://i945.photobucket.com/albums/ad297/750RK/Odds%20and%20ends/Beech%20st.jpg
Yes it is mandatory but mandatory is a transient thing. If for example you have to pull into it to get round an obstruction or to avoid riding over the top of a cyclist then that is fine.
Except they are in the wrong. They ignored a give way line and pulled out in front of another vehicle causing them to deviate in their speed or direction.
Incidently Beech st is this wide at that point...
https://i945.photobucket.com/albums/ad297/750RK/Odds%20and%20ends/Beech%20wdth.jpg
But it now has a solid white line repalcing the split white line that carries on straight not angling to the right at the keep clear road markings.
This has been an interesting thread. If a car pulls out on a motorcyclist there is uproar, because a cyclist did it and started screaming people look for fault in the motorcyclist. So why the about face?
M.C
PostPosted: 13:45 - 01 Jun 2017    Post subject: Re: Abusive Dulwich Paragon member Reply with quote
I was nearly taken out multiple times, and would have been had I not been aware of what was around me. I generally disagree with (the need for) most of the segregated cycling they've introduced, except on that section of road, and it was bikers that made it dangerous. Shame as it has really f**ked up was already a congested road.
Normally BCF would be asking why you were filtering on the left like a pansy cyclist Wink Is that what Mrs Paragon was doing?
sickpup
Old Timer
PostPosted: 13:55 - 01 Jun 2017    Post subject: Re: Abusive Dulwich Paragon member Reply with quote
So thats a no then.
Very good answer. You managed to completely ignore the question and try and insult me.
Filtering on the left as vehicles leave a clear line there so Motorcycles can filter without entering the cycle lane.
M.C
PostPosted: 14:09 - 01 Jun 2017    Post subject: Re: Abusive Dulwich Paragon member Reply with quote
sickpup wrote:
So thats a no then.
You may have noticed the large amount of segregated cycling going up around London, I'm pointing out that's one area where there was a problem, and an example of how bikers ignore road markings.
You do have a sandy vagina (for future reference's that's an insult Wink). BCF normally has little sympathy for people filtering on the left...
Now I know you're lying, when does that ever happen in London Laughing
sickpup
Old Timer
PostPosted: 14:31 - 01 Jun 2017    Post subject: Re: Abusive Dulwich Paragon member Reply with quote
And that comment alone shows just how recently you joined this forum. Thumbs Up
M.C
PostPosted: 14:46 - 01 Jun 2017    Post subject: Re: Abusive Dulwich Paragon member Reply with quote
Early 2013? Can't remember the guys name (can't be arsed looking either) but there was a guy who had an accident filtering on the left, and I recall there being zero sympathy. I'm not judging, I do a sneaky bit of filtering on the left in the right situation.
sickpup
Old Timer
PostPosted: 15:00 - 01 Jun 2017    Post subject: Re: Abusive Dulwich Paragon member Reply with quote
That isn't to what I am referring. Thumbs Up
defblade
PostPosted: 07:04 - 02 Jun 2017    Post subject: Re: Abusive Dulwich Paragon member Reply with quote
No, it's not. That's just justification you made up in your head. I might still do it myself and I wouldn't kick off at you in the original situation, but it is not legal.
I still don't understand about the give way thing. Looks like it's for a crossing?? And that traffic at that point should have been "keeping clear" which would have given the cyclist room to move, see and join at a gentler angle instead of having to make a narrow right angle turn on to the cycle lane.
I'm not bashing the biker instead of the cyclist, I'm bashing the person/people who is/are wrong.
In this case the biker for using the mandatory cycle lane at all (legally wrong) and the cyclist for wasting time and air being shouty about it (morally wrong, or at least utterly pointless).
Fizzoid
PostPosted: 09:21 - 02 Jun 2017    Post subject: Re: Abusive Dulwich Paragon member Reply with quote
Even if it was to avoid a collision?
sickpup
Old Timer
PostPosted: 09:22 - 02 Jun 2017    Post subject: Re: Abusive Dulwich Paragon member Reply with quote
I didn't say it was legal I said it was fine.
You seem to be saying I am breaking the law and should have hit the cyclist which is rather odd.
The is covered by the defence of Duress in particular the defence of necessity which is governed by the Graham test.
The elements of the Graham test:
R~V~Graham wrote:
1. The defendant must have a reasonable belief in the circumstances;
2. This belief must have lead the defendant to have a good cause to fear death or serious injury would result if he did not comply; and
3. A sober person of reasonable firmness, sharing the characteristics of the defendant, might have acted as the defendant did.
If you can't understand a simple T junction then you need to hand your license back and take some lessons.
Only still traffic needs to keep clear, moving traffic has right of way.
No you're definately trying to bash me. I only entered the cycle lane to avoid a cyclist that ignored a give way (a fact that you're blindly ignoring) therefore the cyclist is in the wrong and I have a defence against the offence of crossing the solid white line.
Pete.
PostPosted: 10:11 - 02 Jun 2017    Post subject: Re: Abusive Dulwich Paragon member Reply with quote
TBF I have, a bad one too I had to do the first aid bit.
I pulled up at a red light on Fish Hill St just after the lights went red, waiting to turn on to Lower Thames St. Lights on Lower Thames St went green, biker on a Fazer in the (solid line) cycle lane was obviously just approaching the lights when they went green on him, he gave it a squirt of throttle and the black cab at the front turned left into the road I was waiting in. Biker smashed hard into the cab (top of rear tyre got level with the cab roof) and got a broken hip/leg for his troubles.
a.k.a 'Geri'
Copycat73
PostPosted: 16:41 - 02 Jun 2017    Post subject: Reply with quote
just read this .. and the message from OP. is clear and well put forward ..
but the messenger still needs shooting ..
caveat emptor
sickpup
Old Timer
PostPosted: 17:28 - 02 Jun 2017    Post subject: Reply with quote
Why?
The last post was made 8 years, 348 days ago. Instead of replying here, would creating a new thread be more useful?
Post new topic   Reply to topic    Bike Chat Forums Index -> The Cycling Forum All times are GMT + 1 Hour
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.47 - MySQL Queries: 13 - Page Size: 141.23 Kb
