winz |
winz World Chat Champion
Posted: 09:58 - 27 May 2017 Post subject: CBR1100XX Not starting, possible reg/rec issue? |
Hi All,
So I was riding from Bristol to Brighton yesterday and I pulled over a few times, the last time I got back on the bike and it wouldn't start. Phoned the AA and waited for 2 hours and they came and charged the battery and off I went again.
It seems like the battery isn't getting charged when riding, I've read that these bikes suffer from reg/rec failure, could replacing this be a quick/simple fix? I've got to get back tomorrow and think I have totally fucked it being bank holiday.
EDIT, just to add, I have just managed to start it, but I am only thinking this as the battery still has some charge left in it. ____________________ Current Bikes: BMW K1200S
Previous: Honda CBR929RR, Honda CBR1100XX, Honda CB600F |
jaffa90 |
jaffa90 World Chat Champion
........ Borekit Bruiser
ADSrox0r |
ADSrox0r World Chat Champion
Posted: 10:49 - 27 May 2017 Post subject: |
You'll need to test the alternator output to see if that's working. You can do a reverse diode test on the R/R with most cheap multimeters but that only tells you half the story. It's almost definite that one or both are toast. The unfortunate part is that a faulty alternator can (and often does) take down a working R/R and vice versa. Likewise a toasted R/R can kill a healthy battery so in the end you replace the whole charging circuit. Continuing to use the bike with either a fucked R/R or stator ends up getting more expensive than needs be and can even end up frying any weak points in your wiring.
Swap the R/R for a decent mosfet and if you need to replace the stator it's best to replace with an original Honda rather than some bargain bucket winding that will only last you 10k miles if you're lucky.
The VFR suffers from the exact same troubles but once I'd replaced everything and upgraded to a 'fet R/R I've never looked back.
I also strongly recommend a voltage monitor for the VFR/Bird. I fitted one of these and it sits there and tells you in an un-intrusive way if your charging circuit is over/under volting and when the engine is off it indicates your battery voltage (Useful for winter mornings when zub zero temps nip the battery, you can see if she's a gonner before you even turn the key)
https://www.sparkbright.co.uk/sparkright-eclipse-battery-voltage-monitor.php ____________________ Current bikes: '08 VFR 800 VTEC(yo) , '07 ZZR1400 Winter hack: '95 Aprilia 650 Pegaso Currently lusting after: RC30
ADSrox0r |
Posted: 10:52 - 27 May 2017 Post subject: |
I also recommend printing out this fault finding flow chart that tells you what to test and what voltages to expect at various rev ranges etc.
https://racetechelectric.com/files/pdf/rte_troubleshooting_flow_chart.pdf
If you need to limp home and can get her bumped off then disconnect the lights, try not to let the fan come on if you can avoid it. ____________________ Current bikes: '08 VFR 800 VTEC(yo) , '07 ZZR1400 Winter hack: '95 Aprilia 650 Pegaso Currently lusting after: RC30 |
Kawasaki Jimbo |
ADSrox0r |
winz |
ADSrox0r |
Posted: 15:03 - 27 May 2017 Post subject: |
For ref, Argos have a bog standard one on sale at £14.99
https://www.argos.co.uk/product/7015603
It'll do the job for what you want, not terrific but most of us that are in the electrical trade end up with a Fluke (many hundreds of ponds) for calibrated accuracy. ____________________ Current bikes: '08 VFR 800 VTEC(yo) , '07 ZZR1400 Winter hack: '95 Aprilia 650 Pegaso Currently lusting after: RC30 |
P. |
P. Red Rocket
ADSrox0r |
winz |
winz |
winz |
Posted: 14:48 - 30 May 2017 Post subject: |
So I have done some testing and I have found this wonderful little PDF on here: https://www.bikechatforums.com//files/bike_charging_bible.pdf.
Reading across the battery terminals was 12.6v, so a little low. With revs it barely changed.
Checked the Stator > reg\rec, Was giving consistent readings of 0.6Ω when off. 10v on idle but didn't jump under load.
Need to do some more tests but had work to do. More to come... ____________________ Current Bikes: BMW K1200S
Pete. |
Pete. Super Spammer
Posted: 15:06 - 30 May 2017 Post subject: |
Check the loom plugs first. Actually un-plug them and inspect the terminals. If they are covered in green/black crud clean them up, if melted cut them back and choc-block them.
Your stator should output about 60VAC with the engine running at fast idle, could be a lot more or a bit less. The reg/rec should be putting out high-14's VDC. ____________________ a.k.a 'Geri'
ADSrox0r |
winz |
winz |
Posted: 13:23 - 24 Jun 2017 Post subject: |
So little update, I used the bike last weekend and there wasn't any issues (at least with the bike).
Just got outside to test the reg rec/stator again and the bike won't even start.
https://www.dropbox.com/s/stfje3cc0d00dc9/bb.mp4?dl=0
Anyone have any idea what that noise could be?
Think it's time for a professional to have a look, or at least someone that know what they are doing.
EDIT, just to add, just check the battery, 11v, that noise has stopped, when trying to start goes down to 10v, going to pick up a battery now.
EDIT EDIT, new battery fitted and it turns over, testing commencing in the morning. ____________________ Current Bikes: BMW K1200S
winz |
Posted: 11:28 - 26 Jun 2017 Post subject: |
So after some more investigating..
https://i.imgur.com/sjpEGLw.jpg ____________________ Current Bikes: BMW K1200S
P. |
P. Red Rocket
winz |
Keir |
Keir World Chat Champion
Posted: 13:52 - 26 Jun 2017 Post subject: |
id probably put a new one onanyway - and a genuine Honda one at that.
They are a known weak point so might as well fix it all at once rather than risk another failure. ____________________ Current : '08 Yamaha FZ1s
Previous: '99 Honda CBR 600FX, 03 ZX636 B1H, 99 Fazer 600 (red), 02 GSX-R 600 K2, 00 SV650s (red), 2008 ZX10R, 97 Bandit 1200N, 04 ZX6RR K1H, 04 GSX-R 1000, 98 Fazer 600 (gold), 05 Madness 110 Pit bike, 04 CR125R, 00 SV650s (black), 06 KTM 625 SMC, 99 SRAD 600 track bike, 03 SV650, 98 Bandit 1200N, Bandit 600SY, 03 GSX-R 600 K3, 01 GSX-R 600, 01 Fazer 600 (black), VFR 400 NC30 x3, 78 Honda Dream, 00 Speedfight 50 |
ADSrox0r |
P. |
P. Red Rocket
The last post was made 6 years, 305 days ago. Instead of replying here, would creating a new thread be more useful? |
