ws4936 |
ws4936 World Chat Champion
CaNsA |
CaNsA Super Spammer
ws4936 |
andym |
andym World Chat Champion
Posted: 01:57 - 09 Jun 2017 Post subject: |
After being told I had air in my braking system (many times), I bought one of these for a couple of quid:
https://wemoto.files.wordpress.com/2011/04/banjobleed-100-2.jpg
I fitted it at the highest point (next to the master cylinder), bled the brakes (as well as stripping, cleaning and fitting new seals, washers and brake pads), and still get a spongy brake lever after a few seconds |
ws4936 |
P. |
P. Red Rocket
Robby |
Robby Dirty Old Man
Rogerborg |
Rogerborg nimbA
skatefreak |
skatefreak World Chat Champion
Posted: 09:54 - 09 Jun 2017 Post subject: |
Put a rag under the top banjo, get a spanner on it and bleed it there in the same way as you would at the bleed nipple. You can often have a large bubble of air in there. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
davethekwak |
davethekwak Nitrous Nuisance
Baffler186 |
Baffler186 World Chat Champion
Posted: 12:07 - 09 Jun 2017 Post subject: |
I would echo Paddy and RogerBorg's advice. Slowly squirting fluid in from the bottom usually does the trick, if you can get someone to tap the caliper and the line whilst you do it, then all the better.
You must ensure a tight seal on the nipple though. It is possible, as I found out, to have a tight enough seal on the nipple for it not to leak, but it will suck a tiny amount of air in.
Once the reservoir fills up, you can seal off the system, suck some fluid out the reservoir and push some more fluid in if you want. If absolutely nothing will firm the lever up then check your threads and washers at each end of the line, as you might not have a perfect seal. Again, if your system has a tiny leak, it can be enough to let air in but not still not be sufficient to notice any fluid leaking out. ____________________ Current: 2009 SV650 S, 1990 Kawasaki GT550
Previous: 2009 CBF125, 1998 GSF600, 2004 FZ6 Fazer, 1978 CB400a Hondamatic |
bikenut |
bikenut World Chat Champion
Posted: 14:47 - 09 Jun 2017 Post subject: bleeding brakes |
Is the very tiny hole at the "pressure" end of the master cylinder res floor blocked??
I assume the master cylinder was striped down, lubed by brake fluid on re assembly and "primed" on fitting??
Airated fluid ( tiny bubbles, like an aero choc bar but fluid if you understand me ) must be allowed to "clear" which can take some time.
With a fully master cylinder res, and the lever blade pumped, any air bubbles from the tiny "recouperating hole" ??
If system has fluid in it and the caliper pistons are pushed home, fluid will be forced thru the small hole in the res floor, back to the res.
The master cylinder is a pump, but by virtue of the small recouperating res floor hole, fluid will drain down thru an open bleed nipple.
So with master cylinder fitted to bike ( most brake fluids are an excellent paint stripper ), hydraulics fitted as well as caliper and pads/pipes etc, with a full master cylinder res, open nipple and wait of fluid to "come out" of the bleed nipple/nipples.
With fluid come out of each nipple, start at the furthest from the master cylinder. Both nipples closed, pump say 5 time the brake lever relatively quickly releasing the blade at each pump, then hold pressure and undo the nipple slowly.
Pressurised fluid will come out untill blade reaches the handle bars, hold it there and do up that nipple.
Release brake lever blade, count to 4, watch fluid level drop a bit ( to replace "pumped" fluid" ), and repeat process. An assistant is a good idea.
The bleed the other caliper.
Do not re use "bleed fluid". A jam jar and some car windscreen washer clear pipe is useful.
Always works for me. :karma:
PS, brake operated anti dive front forks with its own bleed nipple?? ____________________ nuts about bikes |
kgm |
kgm World Chat Champion
Paulf |
Paulf Nova Slayer
MCN |
MCN Super Spammer
Commuter_Tim |
Commuter_Tim World Chat Champion
Posted: 20:05 - 09 Jun 2017 Post subject: |
I'm a pumper too, I use This one
£20, bled my brakes more times than I can count in the last year.
It has also spent a large portion of its life outside in the garden. (I can't be arsed to clean it, and kept getting brake fluid on paint around the house)
It holds pressure pretty much as good as it did the day I bought it, so extremely well. ____________________ The above post is most likely nonsensical.
I ride a Bandit 600... badly. |
ws4936 |
sickpup |
sickpup Old Timer
ws4936 |
Rogerborg |
Rogerborg nimbA
Holdawayt |
Holdawayt Trackday Trickster
Commuter_Tim |
The last post was made 6 years, 303 days ago. Instead of replying here, would creating a new thread be more useful? |
