Waaarrrggghhh |
Waaarrrggghhh Nitrous Nuisance
Rogerborg |
Rogerborg nimbA
Posted: 13:28 - 21 Jun 2017 Post subject: |
I'm not aware of any endemic issues on them that are still likely to be found in an extant bike.
There was a problem with the rear axles, and some examples suffered from piston slap. They both manifested early so I'd expect them to have been remedied.
You've got the inherent risk of electrical snafus on an 11 year old CANBUS bike. I don't think it's likely to go wrong, but if it does you could be up for eye-watering bills. Belts won't be cheap either.
I can't speak to how they ride, but the 800 is a decent engine and (in my detuned version) can return in excess of 65mpg in stop-start, and well over 70 in the open. No character though, but that's not what they're for.
Worth a look, but I'd want to buy a well looked after private example rather than an overpriced dealer trade-in that might have been chopped in to get rid of it. ____________________ Biking is 1/20th as dangerous as horse riding.
Waaarrrggghhh |
kgm |
kgm World Chat Champion
Rogerborg |
Rogerborg nimbA
Posted: 15:08 - 21 Jun 2017 Post subject: |
Waaarrrggghhh wrote: | Do you think I could get bored of the bike very quickly? |
Well, you could. It depends what you want from it.
I can't speak to the handling, but I don't expect it to be hugely different from my GS. Not light, but the under-seat tank helps to keep the weight down low.
It's not a thrilling engine, but it's got useful roll-on torquepowers at legal speeds. Off the line, my 800 can make my eyeballs hurt. I far prefer it to the IL4s that I've tried, which only get fun when they're already going fast.
I'm not using mine much at the moment because it's too good for my commute. I guess that's a type of boring. But every time I bust it out for a longer run, I'm struck with just how competent it is. Belt drive and a bit of a fairing would doubtless be even better.
Worth a try. I reckon you'll be impressed rather than enthused. ____________________ Biking is 1/20th as dangerous as horse riding.
Waaarrrggghhh |
Polarbear |
Polarbear Super Spammer
Rogerborg |
Rogerborg nimbA
Waaarrrggghhh |
Rogerborg |
Rogerborg nimbA
Posted: 19:38 - 21 Jun 2017 Post subject: |
Waaarrrggghhh wrote: | something about rear axles and batteries dying. |
Yes, there was a problem with the rear axle bearings, but they were recalled and so should be sorted.
Batteries, maybe. Mine does have a minor issue in that the cranking current from the battery is no longer quite sufficient to give a totally smooth start. It can hesitate on the first compression stroke causing the dash to reboot. It can be ameliorated by putting it in gear, pushing it up to compression and then giving it a rock forwards before starting. Or by just holding the button down and not caring. The battery is 5 years old, I wouldn't call that a major issue. It's never had any problem actually starting, even in the coldest weather. ____________________ Biking is 1/20th as dangerous as horse riding.
Stephenniall |
Stephenniall Two Stroke Sniffer
The last post was made 6 years, 308 days ago. Instead of replying here, would creating a new thread be more useful? |
