TomReilly |
TomReilly Traffic Copper
Posted: 19:21 - 21 Jun 2017 Post subject: Oil Leak |
Hello all, after passing my test and being able to ride my GSF 600S '03 Bandit, I have discovered an oil leak.
It drips a drop ever minute or two when warm, doesn't leak when cold unless its extremely slow.
I've only ever done simple tasks such as an oil and filter change with the help of a video.
This leak appears to be way above the oil filter though, at the front end of the engine.
I have some pictures, from first just trying to show you where I am aiming at the engine to last where I THINK the leak may be coming from.
My bike trainer suggested buying a second hand engine as it would save money rather than it be repaired, which is what I am planning upto now but I thought I may try post here in case somebody has a brainwave to what it may be, I hope the pics can help identify it and many thanks for helping
So very front of bike
https://i1197.photobucket.com/albums/aa430/Rilo_UK/2_zpsdiyxfwyt.jpg
https://i1197.photobucket.com/albums/aa430/Rilo_UK/1_zpshljjc95y.jpg
Just behind that radiator/oil cooler
https://i1197.photobucket.com/albums/aa430/Rilo_UK/3_zpseklyqryu.jpg
And then a little higher, this is the highest point where I can see oil, this circled tube is coated all around with a slippery substance which I think is the oil?
https://i1197.photobucket.com/albums/aa430/Rilo_UK/4_zpsudj68ay2.jpg ____________________ Motorcycle riding can be really cozy. If you want to be a little closer to your passenger, brake a little quicker for the next stop. |
TomReilly |
Posted: 07:44 - 29 Jun 2017 Post subject: |
Guess not,
If anyone spots a GSF 600 2000 - 2003 Engine let us know ____________________ Motorcycle riding can be really cozy. If you want to be a little closer to your passenger, brake a little quicker for the next stop. |
skatefreak |
skatefreak World Chat Champion
Posted: 09:46 - 29 Jun 2017 Post subject: |
Can you afford to have the bike off the road for a while?
If so and you're planning to throw another engine in there then you've little to lose by having a butchers at it yourself.
You'll need tools to change the engine either way so put a little money into some tools (probably cost as much if not less than paying someone to change the engine for you), whip the engine out and start having a poke around.
You will get plenty of help if you're getting your hands dirty and will learn a lot in the process. We like to see stripping engines round here you see . |
mudcow007 |
mudcow007 World Chat Champion
Polarbear |
Polarbear Super Spammer
TomReilly |
Posted: 11:06 - 29 Jun 2017 Post subject: |
I've always liked the idea of fixing things myself but this would be something cometley new to me and I spent 1200 to get the bike, yeah bit pricey.. so I'm a bit intimidated at the fact of trying myself. I don't really need to bike atm its more for pleasure. I live with my mum still and she paid a lot of money on the front and back garden so I can't be getting the flags stained, and the bike doesnt fit in the back either its stored in the entry so I dont really have room to work on it myself.
I will purchase some carb cleaner tonight and completley clean the engine and will take it for a quick 10 min spin unless idling would be okay. And to Mudcow, no I am a complete engine novice I'm not familiar with the valves or where they are sorry. If it helps my trainer thinks that the top end of the engine would need to be rebuilt but he didnt give me much to go off only had a quick look.
When I refilled the oil I put slightly over the max line (not intentional) and its still sat on/just above the line. How will this effect it?
So I will update you guys after cleaning and more clear pictures are taken. ____________________ Motorcycle riding can be really cozy. If you want to be a little closer to your passenger, brake a little quicker for the next stop. |
mudcow007 |
TomReilly |
Posted: 13:34 - 29 Jun 2017 Post subject: |
My man worry is that a previous owner has welded the exhaust on and it now has a crack all the way around so I want to replace the exhaust ASAP because it sounds like dragging a wolverines balls over glass. Do I have to see to the engine first if the leak isnt major? ____________________ Motorcycle riding can be really cozy. If you want to be a little closer to your passenger, brake a little quicker for the next stop. |
P. |
P. Red Rocket
skatefreak |
TomReilly |
Posted: 13:55 - 29 Jun 2017 Post subject: |
Yeah..
Bought it welded, not cracked.
Still mistake on my part, I'm only 20 and lots to learn, definitely wont be making that mistake again, my first proper bike. ____________________ Motorcycle riding can be really cozy. If you want to be a little closer to your passenger, brake a little quicker for the next stop. |
mudcow007 |
TomReilly |
Chris45 |
Chris45 Nitrous Nuisance
Posted: 14:39 - 29 Jun 2017 Post subject: |
Doesn't look too bad and given all the hassle of replacing an engine I would leave it and get your money's worth first.
Some of those old Brit bikes were always dripping oil, it was a rite of passage I guess with some of the Bonnies although no doubt I'm gonna get told otherwise.
If you're feeling up to it, try changing the rocker cover gasket first, as it does seem to be weeping from that area.
Overfilling the crankcase with oil is only an issue if you've brimmed it And you don't sound like that sort of thick twat...
Filling the crankcase just above the Max is the norm with me, but not a drop more.
If the bike is working well and there are no other issues, enjoy it.
Hope this helps. ____________________ Honda CG125>Suzuki GT185>Honda CB 250N>Suzuki GSX400>Honda CX500B>Kawasaki GPZ305> Kawasaki GPZ550>Kawasaki GPZ500S+BMW 650GS |
TomReilly |
Posted: 15:00 - 29 Jun 2017 Post subject: |
I didnt realize I could get access to the rocker without removing the engine. Muddycow has gave me a brief proccedure of what to do and it does sound simple enough as I've had the fuel tank off a few times already. Definitely going to try have a look at that top gasket. But yeah I didnt brim it, it does seem correct levels now but for how long. But everything works great, just the exhaust letting it down and I do feel a loss of power since first riding it as the weld broke as I was using it. That doea help and reassure me a little though, I'll try get some pennies worth.
On another note, I'm after a new exhaust if anyone has any spares, not after anything fancy just as long as its not the stock steam roller thats attached to it. ____________________ Motorcycle riding can be really cozy. If you want to be a little closer to your passenger, brake a little quicker for the next stop. |
mudcow007 |
Posted: 16:33 - 29 Jun 2017 Post subject: |
when you say exhaust, which bit do you need....?
Headers
Link pipe
or
end can |
Tdibs |
Tdibs Traffic Copper
chris-red |
Posted: 17:38 - 29 Jun 2017 Post subject: |
£1200 for an 14 year old knackered bandit
Clean it all up and cover the area in Talcum powder it should who where the leak is coming from.
Replacing an engine for an oil leak is insane, especially without even looking at it properly. ____________________ Well, you know what they say. If you want to save the world, you have to push a few old ladies down the stairs.
The last post was made 6 years, 300 days ago. Instead of replying here, would creating a new thread be more useful? |
