Sv650s 2002 running bad
Roycbr600
PostPosted: 06:23 - 24 Jun 2017    Post subject: Sv650s 2002 running bad Reply with quote
Hi all, I hope someone can help? For the past week Sv has been running terrible it Start coughing and backfire while on A roads assumed it was bad petrol so carried on to work.
After work getting back on A roads starts doing it again I notice the frame of the bike is really hot to touch almost to burning point the bike cuts out try and start it, it's cracking over but not firing so call recovery.
Next day pulled multimeter out tryed starting bike again and battery was 15v so check rr and 1 point there was no reading ordered a new one put in tryed to start it again, after a few attempts and full throttle bike started black smoke so get the throttle to idle speed seems OK ish. Let go of throttle bike cuts out.
Start the bike again tryed to rev slowly would backfire and more black smoke.
Cleaned the carbs gave a service still no joy.
Any ideas I can try?
It's a 2002 Sv650s done 24,000
Roy goddard
sickpup
Old Timer
PostPosted: 07:29 - 24 Jun 2017    Post subject: Reply with quote
Sounds like its only running on one cylinder.
Keir
PostPosted: 20:46 - 24 Jun 2017    Post subject: Reply with quote
front cylinder plug or lead corroded to bits? not the best design.
Current : '08 Yamaha FZ1s
Roycbr600
PostPosted: 00:15 - 27 Jun 2017    Post subject: Reply with quote
changed the front plug and checked connection all was fine and both downpipes are getting hot
Roy goddard
Roycbr600
PostPosted: 04:16 - 02 Jul 2017    Post subject: Reply with quote
so just a update cleaned the carbs and seems to be ruuning better but now im leaking fuel the top of float bowls, guessing from removing gasket is there somethink i can use for the old gasket or just order new ones?
Roy goddard
Tankie
PostPosted: 07:42 - 02 Jul 2017    Post subject: Reply with quote
Go and remove the float bowls, check they are flat across the joint, if not carefully grind flat using a fine sheet of emery on a flat surface, eg glass
The last post was made 6 years, 299 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.76 - MySQL Queries: 17 - Page Size: 47.99 Kb
