NJD |
NJD World Chat Champion
Posted: 22:52 - 28 Jun 2017 Post subject: Front brake fluid change halp (Kwak ZR7-S) |
Evening, morning, afternoon.. all the aforementioned and more.
More mechanical tasks, the joys.
Front brake lever on the Kwak is far too spongy so I'm going to bleed both calipers and see how much that does or doesn't improve performance. Couple of questions before I attempt (since I've only done the rear and that's a more basic set up):
(a) Is there anything to know about bleeding the front brakes before doing it (ie: how to avoid rounding of the screws in the fluid resivour .. as I've read that's common)
(b) Do I need to do one caliper first or just whatever one takes my fancy and then the other?
(c) I assume that once the fresh fluid starts flowing through the one caliper I can then, providing there's no air in the tube coming through with the fresh fluid, tightening it up and then start on the other caliper?
(d) Once both calipers have no air coming out of tube and fresh fluid flowing through keep pumping the lever until firm and then a ok to go for a test run straight away? (I've seen or read people cable tie'ing to bars and leaving overnight)
As I say I've done the rear not so long ago but just want to ensure I'm not missing anything since the front is a double setup although same calipers and brake lines etc so shouldn't be troublesome at all.
.. Further investigation may be needed after fluid change given how useless they are. Dangerously ineffective to the point not riding the bike is the safer option. Got the time to look the brakes over and change the fluid so see what fun awaits me.
Plan to leave the calipers in place and bleed then ride so should be less work than last time (the rebuild on the rear).
Oh, finally, the fluid below is OK to use? Had Halfords try to sell me car fluid at first then the wrong type when I ordered online and then gave me a different coloured bottle to the one I ordered. Reviews on Amazon state used on R6 and a Honda so should be fine, right?
https://s12.postimg.org/opxfb7sb1/castrol.jpg
Cheers all. ____________________ The do it all, T̶h̶e̶ ̶b̶r̶o̶k̶e̶n̶ ̶o̶n̶e̶,̶ ̶T̶h̶e̶ ̶b̶i̶g̶ ̶l̶u̶m̶p̶,̶ ̶C̶h̶o̶n̶g̶ ̶N̶o̶o̶d̶l̶e̶ |
sickpup |
sickpup Old Timer
Kickstart |
Kickstart The Oracle
Posted: 23:08 - 28 Jun 2017 Post subject: |
I would doubt fluid alone will stop the brakes being spongy. Old fluid will get water in it will mean they can get spongy with heat (as the water boils). Air can get in there, but generally over time will work its way back out slowly. More likely the calipers need a strip and clean.
I tend to do each caliper and then repeat.
M/c screws can round off. Chances are they are JIS screws and most people do not have a screw driver for them and instead use a Philips one which contributes to the issue.
Car fluid and bike fluid are the same. There are some specialised fluids (eg, some race fluids have a low DOT rating as despite a high dry boiling point they have a low wet boiling point - great on track when the fluid is changed every meeting or so, useless on the road where the fluid gets changed very occasionally).
Katy ____________________ Traxpics, track day and racing photographs - Bimota Forum - Bike performance / thrust graphs for choosing gearing |
NJD |
wr6133 |
wr6133 World Chat Champion
NJD |
sickpup |
sickpup Old Timer
wr6133 |
NJD |
Baffler186 |
Baffler186 World Chat Champion
Kickstart |
NJD |
Posted: 13:32 - 29 Jun 2017 Post subject: |
Went out and gave the calipers a quick clean, nothing overly extensive.
Slider (pictured below) was sticky on one of the calipers so pushed that backwards and forwards and moves alright now.
https://s22.postimg.org/tc6jea9ht/slide.jpg
Beside that perhaps the seal (pictured below) was the only other thing I noticed. Past its best? (all the others look alright).
https://s22.postimg.org/vvqddnpgh/image.jpg
Pads (both look near the same on either side):
https://s9.postimg.org/th1rk0hm7/image.jpg
I'll leave further action for another day given my half asleep antics to do the most basic of jobs today, not my day.
Rolled it down the path backwards, as a basic test, and felt better although is one of those over imagine an issue when something happens or get noticed moments.
Possible test run on another day then whatever, if anything, comes after that depending on how it feels. ____________________ The do it all, T̶h̶e̶ ̶b̶r̶o̶k̶e̶n̶ ̶o̶n̶e̶,̶ ̶T̶h̶e̶ ̶b̶i̶g̶ ̶l̶u̶m̶p̶,̶ ̶C̶h̶o̶n̶g̶ ̶N̶o̶o̶d̶l̶e̶ |
smallfrowne |
smallfrowne Scooby Slapper
Posted: 14:26 - 29 Jun 2017 Post subject: |
Did you do the rebuild on the rear? I ask because if you did then I'm wondering why you aren't popping the pistons out and cleaning up the caliper further if you didn't then you're almost at that point now anyway.
By the looks of it the caliper is pretty mucky and some of the muck will have got behind the dust seals (the one that looks wonky/twisted in the picture). I'd pop the pistons out (easier said than done if they're stuck) and clean inside the caliper and the piston surfaces. Then I'd be taking the seals out carefully with a pointy prodding device and cleaning out behind them.
I'm currently doing the same job on a set of 2 pot slider nissins for a Vfr750. A surprising amount of shite and corrosion lurked behind the dust seal that caused excessive friction - reducing the braking force/piston movement to not a lot. Plus the pistons were covered in gunk as well, below the line of the dust seal.
That dust seal on yours might not be quite fucked, but is in need of attention I'd say. ____________________ '90 VFR750; '89 NC30; '95 DR650; '89 CD250U; ~'82 CG125; ~C90 |
NJD |
NJD |
Posted: 17:01 - 30 Jun 2017 Post subject: |
Righto.
Still deciding if needs to be left alone or is safe to use until I get time to do the rebuild (might try it out tomorrow) but while I ponder that does anyone have any suggestions on what piston removal tool kit would be suitable in the event that a piston gets stuck while attempting to pump them out?
I see plenty on eBay for £30-40 but does anyone have a direct link to one I can trust not to be a plastic useless copy? I'm not willing to spend £70, £90, £100 + that some of them seem to require.
I'd prefer the tool kit over pliers on the grounds when I went to the shop he told me he used on of them toolkits and the longest bit about waiting to get it out was the walk to and from the workshop, so that tells me all I need to know.
Many thanks.
(links on previous thread have shot up in price.. on the toolkit). ____________________ The do it all, T̶h̶e̶ ̶b̶r̶o̶k̶e̶n̶ ̶o̶n̶e̶,̶ ̶T̶h̶e̶ ̶b̶i̶g̶ ̶l̶u̶m̶p̶,̶ ̶C̶h̶o̶n̶g̶ ̶N̶o̶o̶d̶l̶e̶ |
ZX-7R |
ZX-7R Banned
wr6133 |
kramdra |
kramdra World Chat Champion
ZX-7R |
ZX-7R Banned
NJD |
kramdra |
NJD |
Posted: 01:09 - 02 Jul 2017 Post subject: |
kramdra wrote: | Use the master cylinder. |
Will do.
I only ask about the tools because the rear piston got stuck half out and I lost pressure. Ended up taking the Banjo of the bike (at the non-caliper end) and taking it all to the shop (couldn't snap caliper Banjo bolt with caliper out and couldn't put it back on because piston blocked ability to do it all back up on the disc) to get the piston out and if I had the tools I could safe myself a lot of time. Once I've got this episode over with I'll see how many times I further need to do the task and base my investment on that.
I've had a look at the bike and I could have sworn it was a straight run up for the Banjo from the caliper to the master cylinder but the manual (picture below) seems to suggest otherwise, I'll look again tomorrow. I'm going to re-build both sides anyway so even if the right side (with the folded seal) does get stuck and looses pressure I can work on the other and then I'll just take the Banjo out of it's fitting (at the non caliper end), when I figure out what's what, and take it to the shop again and ask for help. Not overly bothered about getting loads of air in the system (undoing Banjo at non caliper end will do) because happened with the rear so I've got the worst out the way the first time, just plug the gap with some tissue or just let all the fluid out, see what's what.
https://s22.postimg.org/jr9omqilt/brk1.png
Bleeding post re-assembly should be easy because there's no bleed nipple on the master cylinder just on the calipers so is a case of doing one by one until no bubbles, easy.
Waiting for seals before I touch anything, saves me forgetting what's what. ____________________ The do it all, T̶h̶e̶ ̶b̶r̶o̶k̶e̶n̶ ̶o̶n̶e̶,̶ ̶T̶h̶e̶ ̶b̶i̶g̶ ̶l̶u̶m̶p̶,̶ ̶C̶h̶o̶n̶g̶ ̶N̶o̶o̶d̶l̶e̶ |
wr6133 |
NJD |
kramdra |
Posted: 15:01 - 02 Jul 2017 Post subject: |
res screws will be M4x12 countersunk. They get over tightened which with the countersunk taper will require a lot of torque to undo, more than a JIS/phillips or normal 2.5mm hex socket head will transmit.
www.ebay.co.uk/itm/362012480989
The head wont deform on a 10.9 or 12.9 so it will always come out. Anything else will be single use, including A2-70 stainless. |
The last post was made 6 years, 297 days ago. Instead of replying here, would creating a new thread be more useful? |
