Ayup_Mi-Duck |
Ayup_Mi-Duck Renault 5 Driver
Posted: 14:26 - 03 Jul 2017 Post subject: ZZR600 list of issues (multiball!!) |
Hi there guys.
if you know the answer to any of these, please feel free to enlighten my stupid mind.
1. warped front disk. any other option than buying a new one? can they be made true again?
2. engine cuts out for 0.00001 of a second when I go over a sharp bump in the road. any ideas what that could be. lights, the lot go off in the blink of an eye and back on.
3. backfire sometimes after the cutout. could just be unspent fuel? or symptomatic of somert else?
4. fan not working. fan tested as ok. temp sender works. water is flowing round the system, but in traffic, the fan doesn't come on. was just going to put a switch on it. if so, where should I run power from and where should I earth to?
5 lastly, I have a v small oil leak from the crevice between the water pump and the sumpy area. is this common? if so, should I just ride it into a wall?..
went to matlock on sat. I had the worst kept/ just worst bike there. it was ace
https://preview.ibb.co/iDOSNv/1498990786715_2390127201_88272608_v1.jpg
https://preview.ibb.co/iDOSNv/1498990786715_2390127201_88272608_v1.jpg |
Rogerborg |
Rogerborg nimbA
Posted: 14:45 - 03 Jul 2017 Post subject: Re: ZZR600 list of issues (multiball!!) |
Ayup_Mi-Duck wrote: | 2. engine cuts out for 0.00001 of a second when I go over a sharp bump in the road. any ideas what that could be. lights, the lot go off in the blink of an eye and back on. |
Loose wire. If everything is going off, I'd start with the battery and main earth connections, then to the fusebox.
Ayup_Mi-Duck wrote: | 5 lastly, I have a v small oil leak from the crevice between the water pump and the sumpy area. is this common? if so, should I just ride it into a wall? |
I have had some success with Wynns Engine Stop Leak down the years. The usual caveats that obviously it will make your clutch both stick and slip and your engine to assplode and inject the Bad AIDS into your wounds. ____________________ Biking is 1/20th as dangerous as horse riding.
Ayup_Mi-Duck |
wr6133 |
wr6133 World Chat Champion
Posted: 21:39 - 03 Jul 2017 Post subject: Re: ZZR600 list of issues (multiball!!) |
1. warped front disk. any other option than buying a new one? can they be made true again? |
I'd replace it. Sure it's warped though?
Quote: | 2. engine cuts out for 0.00001 of a second when I go over a sharp bump in the road. any ideas what that could be. lights, the lot go off in the blink of an eye and back on. |
There is an earth point if you lift the tank and look down you'll see it. It gets drowned in shite, it may be that.
Quote: |
3. backfire sometimes after the cutout. could just be unspent fuel? or symptomatic of somert else? |
Bike has AIDS
Quote: | 4. fan not working. fan tested as ok. temp sender works. water is flowing round the system, but in traffic, the fan doesn't come on. was just going to put a switch on it. if so, where should I run power from and where should I earth to? |
Probably not got hot enough. Mine wouldn't kick in till about 2/3rds-3/4's of the way up the temp gauge.
Quote: | 5 lastly, I have a v small oil leak from the crevice between the water pump and the sumpy area. is this common? if so, should I just ride it into a wall?.. |
Bike has Ebola.... trace exactly where the leak is coming from. |
Ayup_Mi-Duck |
Posted: 10:39 - 04 Jul 2017 Post subject: Re: ZZR600 list of issues (multiball!!) |
wr6133 wrote: | Ayup_Mi-Duck wrote: |
Bike has AIDS
Shit... Ebolaids..... looks like its shotgun behind the tab for it then.
or ill look at your advice and work thru it all
mrs is away this weekend (shes probably knocking off, but it gives me time to sort the bike!) so I will get it to bits.
TA! |
Chuffin Nora |
Chuffin Nora World Chat Champion
Ayup_Mi-Duck |
The last post was made 6 years, 297 days ago. Instead of replying here, would creating a new thread be more useful? |
