External Hard Drive for Video Editing
Fifteen15
PostPosted: 07:23 - 05 Jul 2017    Post subject: External Hard Drive for Video Editing Reply with quote
My laptop is a 2016 HP Spectre x360 - i5 6th Gen, 8GB RAM, 256GB SSD. I use Adobe Premiere Pro but when I start adding multiple effects, transitions etc then it starts bogging down the laptop and it becomes slightly laggy. Also export times for a 7 minutes 1080p video can take up to 2 hours. I'd imagine editing 4k would not be possible - or extremely difficult/stressful with my set up.
What's the bottleneck here? the CPU or the RAM, or both?
Also, I'm planning on buying an external hard drive to store all my media from and edit straight from the external hard drive, keeping it separate from my main SSD in the laptop. Any recommendations? Will an SSD be worth the extra cost in terms of speed and reliability, or will a SSHD do?
"Pain is weakness leaving the body, and blood makes the grass grow faster...but I'll wear my gear anyway"
P.
PostPosted: 07:35 - 05 Jul 2017    Post subject: Reply with quote
Laptop is the bottleneck.
Change to PC with decent specs and you'll have less issues.
Fifteen15
PostPosted: 07:37 - 05 Jul 2017    Post subject: Reply with quote
Yeh thought as much. I am away from home 5 months of the year so a PC isn't really an option.
As for external hard drives, as my 256GB SSD is filling up, is an SSD worth the extra $$?
P.
PostPosted: 07:43 - 05 Jul 2017    Post subject: Reply with quote
For my main drive, yes. For constant writing and access, so file storage, no. I use actual drives for that.
doggone
PostPosted: 07:55 - 05 Jul 2017    Post subject: Reply with quote
When you're rendering you could check task manager to see what's maxed out - CPU most likley.
Adding external drive won't help except it's a good place to keep your videos rather than fill up main drive.
Recent versions of Premiere have inbuilt ability to use smaller proxy files which helps a lot especially with 4K
RhynoCZ
PostPosted: 09:22 - 05 Jul 2017    Post subject: Reply with quote
Buy a micro PC perhaps? Nuc, Brix, ... some of those run a desktop CPU = so much woof, so much power. OR, something like Asrock DeskMini 110, which you may fit with any 65W TDP Skylake/Kabylake CPU. With a locked i7 you would get a rendering powerhouse in a very small package.
This thing: https://www.youtube.com/watch?v=KQrSgX2ybTQ
Plug it in any Tv and you're good to go. Thumbs Up
Fifteen15
PostPosted: 09:51 - 05 Jul 2017    Post subject: Reply with quote
Interesting set up. Didn't know these things existed. But for what I'm after, it needs to be an ultra portable set up i.e. no extra keyboard, monitor etc. Tbh I'm not that bothered about my laptop slowing down when using Adobe. It's only right at the end - the last 10 minutes of editing as I add all the effects. Other than that I can edit everything I need to without any real problems, I made the thread more to see if an external SSD would make any significant difference - which it won't Smile
oldpink
PostPosted: 21:33 - 05 Jul 2017    Post subject: Reply with quote
I do a lot of video editing and work from a PC as anything going to an external drive will bottle up even with USB3 esp as Adobe creates very large files if you have multiple efx or layers involved
one option would be to increase you internal SSD's capacity with a 1tb USB drive to back up to once you finish the editing
I have 2 x 2Tb drives with a large cache and high data rates dedicated to video editing
and even these are filling up quickly
Im-a-Ridah
PostPosted: 01:44 - 06 Jul 2017    Post subject: Reply with quote
Laptops tend to be dual core, so pretty mediocre for video editing. You say you are away for 5 months a year so I'm guessing you are a student. If so, my advice would be to use a uni computer, they will have serious good computers for this kind of thing already. More RAM might help a bit, external hard drive not so much. What you really need though is more cores.
If you are in the army or navy or something then an external computer probably isn't an option as its likely to draw a lot of power. You don't need a screen or keyboard though, you can use remote desktop to run the encoding remotely on the PC. Remote desktop can be local in a physical sense, so just between two computers at each end of an ethernet cable, but it will take a bit of effort to set up.
ScaredyCat
PostPosted: 08:19 - 06 Jul 2017    Post subject: Reply with quote
If your video editing software allows you to use proxy media use that while editing. If rendering is an issue you could do export the video with some layers / effects and then build a 2nd project using that export and adding the layers / effects yo temporarily disabled to that.
Honda CBF125 ➝ NC700X
Honda CBF125 ↳ Speed Triple
PostPosted: 09:28 - 06 Jul 2017    Post subject: Reply with quote
Buy a mac?
Just saying. Sounds like a job for a mac.
PostPosted: 12:32 - 06 Jul 2017    Post subject: Reply with quote
Is there anything that actually makes Macs better at this sort of thing or is it just the marketing image?
owl
PostPosted: 13:23 - 06 Jul 2017    Post subject: Reply with quote
same reason why an iphone runs better with 2gb of ram than an android with 8gb Rolling Eyes
PostPosted: 13:28 - 06 Jul 2017    Post subject: Reply with quote
So it doesn't then Laughing
Fizzoid
PostPosted: 13:30 - 06 Jul 2017    Post subject: Reply with quote
They used to be, now, not so much
ScaredyCat
PostPosted: 14:39 - 06 Jul 2017    Post subject: Reply with quote
FCPX costs ~£200 one off payment (Motion is ~£50) - I'd buy both.
Adobe Premiere costs £20 a month. I refuse to rent software.
The only thing I miss from Premiere is Mocha but you can buy add-ons from Coremelt for FCPX to give a cut down Mocha. Magnetic time line is nice in fcpx and it's really easy to use.
M.C
PostPosted: 14:50 - 06 Jul 2017    Post subject: Reply with quote
Couple of bits of software if you're into video editing or music production (FCP and Logic), reasonably priced as well. I'm not an Apple fanboy at all but people do miss the point of them, they perform rather well considering their products are almost always lower spec'.
I wouldn't invest in a Mac but I do have OS X running on my (hackintosh) PC. That's a whole world of issues to get it it running, but personally preferable to buying expensive Apple hardware. Also I get a warm feeling knowing Steve Jobs' probably turning in his grave Smile
Some laptops are compatible with OS X/macOS.
techathy
PostPosted: 18:13 - 06 Jul 2017    Post subject: Reply with quote
Actually I've found that since windows 10 has been released on similar spec laptops OSX no longer offers a performance advantage. Combine that with Dell 'premium business' laptops typically cheaper & have better thermal management (meaning for sustained high load work they're faster).
Bikes: '17 Zero FX ZF6.5, '16 BMW R1200 RS, '12 Triumph Daytona 675
Im-a-Ridah
PostPosted: 19:02 - 06 Jul 2017    Post subject: Reply with quote
It seems to be a historical thing, but today it doesn't really apply. Professionals in the field are more likely to use a Mac, so the support is probably better, but you pay a premium for that too. Arts universities are also filled with Macs and student with Macbooks.
Pirated software is free.
The last post was made 6 years, 288 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.21 - MySQL Queries: 17 - Page Size: 112.28 Kb
