Torque settings for cbf125 clutch
Wullie1967
PostPosted: 22:32 - 11 Jul 2017    Post subject: Torque settings for cbf125 clutch Reply with quote
Hi doing my clutch on Honda cbf125 I need torque settings for pump and clutch plate or even pictures of Haynes manual page please
PostPosted: 23:02 - 11 Jul 2017    Post subject: Reply with quote
If you mean the four bolts on the plate that squishes the clutch springs then they are m6 bolts so 7lbs/ft or 10nm. You should use threadlock (low strength). 7lbs/ft is less than you think you can easily achieve it with 2 fingers on a normal 10mm spanner.
If the pump bolts are also m6 then do the same.
The last post was made 8 years, 273 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 1.14 - MySQL Queries: 14 - Page Size: 31.4 Kb
