A license
richfar
PostPosted: 17:05 - 16 Jul 2017    Post subject: A license Reply with quote
Can anyone clarify this please my lad has an A2 license for over two years he is 21, does he have to pay for an instructor to take his A license or can he just book his test put L plates on his MT 700 and go
Thanks
arry
PostPosted: 17:20 - 16 Jul 2017    Post subject: Reply with quote
The bike has to meet the A licence criteria. If it can do that then fair game.
https://www.gov.uk/motorcycle-test/motorcycles-mopeds-you-can-use
M.C
PostPosted: 20:59 - 16 Jul 2017    Post subject: Reply with quote
He'll need to 'de-restrict' it in the test centre parking lot. Or at least pretend to Wink
PostPosted: 21:53 - 16 Jul 2017    Post subject: Reply with quote
The MT07 will fit the category unrestricted. You do face the getting back after module 1 with the unrestricted bike.
PostPosted: 11:36 - 17 Jul 2017    Post subject: Reply with quote
If the local DVSA Derek cares. Given that the onus is on the rider to show that an A bike is restricted for A2, it'd be a bit rich to question whether it's at full power for A tests.
It's only £15.50 for the mod 1 to find out.
Oh, in addition to L plates front and rear, there can't be any engine management lights showing and the bike must not be obviously unroadworthy (which pretty much means tyre tread). He needs to be wearing 'suitable clothing' (because DVSA think they can create laws and have a very poor understanding of how duty of care works).
He does not have to be wearing hi-vis, but Derek will be so used to seeing it that I'd throw on a £1 shop bib rather than arguing the toss or failing the Attitude Test (which of course does not exist).
angryjonny
PostPosted: 12:25 - 17 Jul 2017    Post subject: Reply with quote
Chain is often an issue too. I ended up doing my test on the instructor's bike because the chain was a bit touch-and-go on my school-bike. The same examiner had (apparently) previously refused to do a test because one of the bikes had had a respray and hadn't had its badges/decals reapplied, so he couldn't be sure what model it was and therefore if the capacity/power were correct for the test.
Instructors/schools will have an idea of who are the troublesome examiners etc when it comes to box-ticking. Doing it on your own, you're winging it a bit, so the only safe route is to make sure everything is A1-tip-top.
M.C
PostPosted: 14:47 - 17 Jul 2017    Post subject: Reply with quote
Actually forgot a friend had to borrow a pair of boots (from the instructor) to do his test. But my thin jean chinos were fine (they were the closest thing I had to jeans) Neutral
arry
PostPosted: 15:35 - 17 Jul 2017    Post subject: Reply with quote
Social housing and chinos. I have the sad. Razz
DRZ4Hunned
PostPosted: 15:40 - 17 Jul 2017    Post subject: Reply with quote
I was about to do my A tests on my Fazer but a lorry put a stop to that... Now I'm dubious as to whether the examiner will deem it road worthy after I have bodged it all back together. Crying or Very sad
DRZ400-SM
FZS600
arry
PostPosted: 15:42 - 17 Jul 2017    Post subject: Reply with quote
If you're dubious they will almost certainly be. But it would depend on attitudes on the day. Nobody has that insight.
15 quid for MOD 1 probably won't break the bank.
richfar
PostPosted: 10:37 - 18 Jul 2017    Post subject: Reply with quote
Thanks for info all sorted now.
stevo as b4
PostPosted: 11:17 - 18 Jul 2017    Post subject: Reply with quote
Do you actually have to so called de-restrict your MT07 for example to take a full A test on it though? Is there a different bhp minimum level and cc to take a full test on now?
In the 33bhp days I think you needed a minimum 46bhp bike to do DAS on, but there wasn't a cc limit, so you could pass your test on an RGV250 if you wanted or a 650 cc Transalp etc.
arry
PostPosted: 11:32 - 18 Jul 2017    Post subject: Reply with quote
Yes. It's all in the link I posted above.
PostPosted: 11:37 - 18 Jul 2017    Post subject: Reply with quote
595cc+ and 40kW+ at the moment.
The issue is riding in with an A2 licence limiting you to 35kW, then saying that the bike is 40kW+. It's not really any of DVSA Derek's business, but best not to waggle it in his face.
M.C
PostPosted: 16:41 - 18 Jul 2017    Post subject: Reply with quote
Isn't there also a weight requirement coming in soon? That's just great Neutral
Edit:
This amending Directive raises the minimum standard from 40kw to 50kw and introduces a minimum mass weight requirement of 180kg. The European Commission argues that this is to provide for a test on a machine that is much more representative of its class and to introduce a more definite difference between a category A2 motorcycle and a category A motorcycle. The UK was not convinced by this argument and argued against this change during negotiations. Only the Netherlands supported our view. The Commission with a majority of Member States supporting it chose to introduce the change from July 2013. The UK was however, successful in getting the change delayed until 31 December 2018.
arry
PostPosted: 16:49 - 18 Jul 2017    Post subject: Reply with quote
Shouldn't imagine that's much of an issue. Can't think of many bikes 595cc plus and sub 180 wet that your average training school will use.
They won't define it properly of course. Then it'll be an issue.
M.C
PostPosted: 18:58 - 18 Jul 2017    Post subject: Reply with quote
It affects a number of bikes, all the bikes with a * in this list: https://www.gov.uk/government/uploads/system/uploads/attachment_data/file/621858/Motorcycle-test-vehicle-list.csv/preview (they've removed the handy filter they had Brick Wall), which's neither complete or accurate as the 690 Dukes will become ineligible, as I believe the MT-07 might (depending on what figures you believe).
arry
PostPosted: 19:38 - 18 Jul 2017    Post subject: Reply with quote
Some obscure BMWs and some lightweight KTM or scrambler here and there. No Biggie.
The one that confuses me is the NC range. Bullshit that's under 180: I'm guessing that star is because of the auto box.
M.C
PostPosted: 20:21 - 18 Jul 2017    Post subject: Reply with quote
It misses out due to the increased horsepower requirement. Yeah they aren't very powerful Neutral
arry
PostPosted: 22:23 - 18 Jul 2017    Post subject: Reply with quote
Ah, missed the power hike piece as well. That's just such bullshit. Nobody on their test is giving it the beans.
PostPosted: 23:01 - 18 Jul 2017    Post subject: Reply with quote
Exactly. You could do your A tests on a 35kW restricted bike and still comfortably exceed any reasonable expectations about "making progress".
It's just Brussels dicking around because they have nothing better to do.
The last post was made 6 years, 282 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.63 - MySQL Queries: 17 - Page Size: 116.55 Kb
