GSXR Starting Issues
Renton
PostPosted: 09:28 - 17 Jul 2017    Post subject: GSXR Starting Issues Reply with quote
GSXR 1000 K6
I normally use the bike every day with no issue.
Last month I serviced it including 4 new plugs and it was running fine afterwards.
Then last week, I hadn't used the bike for 5 days and it sounded a little weak starting up. This has improved with a return to daily use, but there sounds like a scratching noise while under the ignition button.
Any ideas?
This is my motorcycle. There are many others like it, but this one is mine.
Without me, my motorcycle is useless. Without my motorcycle, I am useless.
jaffa90
PostPosted: 10:58 - 17 Jul 2017    Post subject: Reply with quote
Sounds like the battery is not holding / storing charge for more than a day or two.
Renton
PostPosted: 11:07 - 17 Jul 2017    Post subject: Reply with quote
I tried removing the battery to put it on charge but the alarm went mental at me. It took a while but I found the necessary procedure to do it.
So I'm all fine for changing the battery should I need to, but my concern is the scratching type noise while under the starter button. Could this be a blown coil on the stator rotor, or does that not move?
jaffa90
PostPosted: 13:10 - 17 Jul 2017    Post subject: Reply with quote
It`s a direct feed to the starter motor from the battery, if the battery is low it will click/ratchet the starter relay switch.
Renton
PostPosted: 14:00 - 17 Jul 2017    Post subject: Reply with quote
Is Motobatt still the battery of choice these days?
Last time I replaced a bike battery that's the one everyone on here recommended.
P.
PostPosted: 14:21 - 17 Jul 2017    Post subject: Reply with quote
Motobatt for me, just added one to my GSXR1000.
PostPosted: 14:30 - 17 Jul 2017    Post subject: Reply with quote
Yuasa is fine Thumbs Up
Triumph Trophy Launch Edition
P.
PostPosted: 16:15 - 17 Jul 2017    Post subject: Reply with quote
Indeed, I got quoted 70+ for a Yuasa locally or just ebay a Motobatt for £48.50 Laughing
The last post was made 6 years, 278 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.12 - MySQL Queries: 17 - Page Size: 56.58 Kb
