(video) Unusual noise when running and turning off
prcsc
PostPosted: 20:25 - 19 Jul 2017    Post subject: (video) Unusual noise when running and turning off Reply with quote
Hi there guys,
I have been following this forum for a long time now, but never had the need to really post anything. I have found the forum extremely useful, so thank you all.
A couple weeks back, my ninja started making a weird noise when running. This noise has increased over time. I though it could possibly be low oil pressure, so I decided to change the oil, and oil filter at the same time.
Yesterday I ran the bike and the noise is still there.I have uploaded a video in Google drive - https://photos.app.goo.gl/mJ1b4zCOw1Djcg0z1
If you pay attention, the noise start when I turn the bike on. It's kind of a mixture of soft grinding and low whistle. Please watch until the end because it also makes an unusual noise when turning the bike off. Both noises started at the same time, so pretty sure they are related.
Does anyone have any idea what this could possibly be?
Thanks in advance.
jaffa90
PostPosted: 20:50 - 19 Jul 2017    Post subject: Reply with quote
Sounds like the starter motor pinion to me but wait for more experience peeps on here.
Kawasaki Jimbo
PostPosted: 20:51 - 19 Jul 2017    Post subject: Reply with quote
The stopping noise sounds like a starter motor so I wonder if the starter motor fails to disengage properly and is being spun by the engine. Faulty solenoid? Thinking Not sure though.
prcsc
PostPosted: 17:17 - 20 Jul 2017    Post subject: Reply with quote
What could I try then?
PostPosted: 18:16 - 20 Jul 2017    Post subject: Reply with quote
Definitely starter motor. To me it sounds like its still trying to turn over the engine when you stop the engine until you switch it off.
If you have the kill switch on, can you still turn the engine over on the starter motor? If you can, start the bike then stop it on the kill switch and see if the starter is still turning it over.
Triumph Trophy Launch Edition
doggone
PostPosted: 18:19 - 20 Jul 2017    Post subject: Reply with quote
I'd go with this, simplest of all make sure starter button is springing out.
Once had total panic after sticky mud got in mine and when started next day oil light was on and 'strange noise from engine'.
This was 1000 miles from home in France too.
Pete.
PostPosted: 19:19 - 20 Jul 2017    Post subject: Reply with quote
Don't run your bike like that it will wreck the starter very quickly and the starter gear too, possibly causing broken engine cases.
At first I thought it was the starter clutch not disengaging but it actually sounds like the starter is still under power whilst the engine is running.
Suspect the solenoid first, since it's that which supplies power to the starter.
a.k.a 'Geri'
PostPosted: 19:36 - 20 Jul 2017    Post subject: Reply with quote
I agree with that, but if the solenoid was stuck wouldn't it try to start as soon as you turned the key?
Pete.
PostPosted: 19:41 - 20 Jul 2017    Post subject: Reply with quote
Yes it might unless somehow it's back-feeding power into the pull-in coil. It's very odd for sure, one of those things that is hard to diagnose online but you'd figure out in ten minutes with a multimeter if it was in front of you.
a.k.a 'Geri'
sickpup
Old Timer
PostPosted: 19:58 - 20 Jul 2017    Post subject: Reply with quote
The others have pretty much covered it. I just wanted to say well done on a first post that gave us everything we needed, a good description of the problem and a video. Noobs could learn well from you Thumbs Up
prcsc
PostPosted: 20:33 - 20 Jul 2017    Post subject: Reply with quote
Oh wow, thank you all for the input!
I do have a multimeter. I will do some testing this weekend and report back.
Pete.
PostPosted: 22:34 - 20 Jul 2017    Post subject: Reply with quote
You get out what you put in Smile
Disconnect the starter supply lead from the solenoid and try the button. If the solenoid pulls in but doesn't drop out when the button is released then check the solenoid feed (the small wire that sends power to activate it. If that wire stays live when you release the button suspect the button, or the alarm/immobiliser if it has one fitted.
a.k.a 'Geri'
PostPosted: 10:28 - 21 Jul 2017    Post subject: Reply with quote
Wild thought, does it have one of those Cyclone / NCS alarms with a remote start?
prcsc
PostPosted: 10:48 - 21 Jul 2017    Post subject: Reply with quote
No alarm. I have Hot Grips though, connected directly to the battery.
The last post was made 6 years, 281 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.65 - MySQL Queries: 17 - Page Size: 87.7 Kb
