CBR oil level
fatjames
PostPosted: 21:00 - 26 Jul 2017    Post subject: CBR oil level Reply with quote
Evening all.
2004 CBR600f
Oil level?
On the centre stand its above the glass. On the side stand it's under the glass.
Too much? Not enough?
Haynes just says when the bike is level, which I assume means on the centre stand..
Oil light flashed when I start her up, but quickly goes out.
arry
PostPosted: 21:27 - 26 Jul 2017    Post subject: Reply with quote
On the main stand, top of the glass. It's probably fine.
jaffa90
PostPosted: 22:37 - 26 Jul 2017    Post subject: Reply with quote
Oil level on yours should be checked with engine cold and on level ground with the bike upright,(balanced) the level should be in between the lower (min) and upper (max) line in the plastic glass.
PostPosted: 23:21 - 26 Jul 2017    Post subject: Reply with quote
Wot arry said Thumbs Up
Triumph Trophy Launch Edition
john24ssj
PostPosted: 09:31 - 27 Jul 2017    Post subject: Reply with quote
manual says to check it on the centre stand
Bikes: Honda CBR600Fi, Kawasaki ER5
PostPosted: 10:32 - 27 Jul 2017    Post subject: Reply with quote
If it's clear over the top of the sight, I'd get a tube down into the sump and remove some. Even if you can't pump your sump, if you shove it in, cover the top with your thumb and then whip it out, you'll get some relief.
jaffa90
PostPosted: 11:41 - 27 Jul 2017    Post subject: Reply with quote
Top of the glass /plastic is not fine,
you need to see if the level goes up or down.
arry
PostPosted: 12:46 - 27 Jul 2017    Post subject: Reply with quote
The maximum marker for the sight glass on a CBR is at the top of the glass.
In what way is it not being at the top of the glass not fine? Thinking
RR here, but:
https://image.slidesharecdn.com/2012ownermanualhondacbr600rr-151124194158-lva1-app6891/95/2012-owner-manual-honda-cbr600rr-59-638.jpg?cb=1448394193
jaffa90
PostPosted: 13:39 - 27 Jul 2017    Post subject: Reply with quote
arry, just read what you have posted,
No mention of centre stand and the level is between lower and upper.
As my first post.
Also the level can go up with a faulty injector or coolant leak.
arry
PostPosted: 15:27 - 27 Jul 2017    Post subject: Reply with quote
Centre stand = main stand.
Top of the glass = where the max marker is.
jaffa90
PostPosted: 16:36 - 27 Jul 2017    Post subject: Reply with quote
I give in. Rolling Eyes
arry
PostPosted: 18:01 - 27 Jul 2017    Post subject: Reply with quote
OK. Um, sorry.
Still not sure what you're getting at though.
fatjames
PostPosted: 13:06 - 28 Jul 2017    Post subject: Reply with quote
I think it's got a bit too much oil in.
I'll syphon a bit out on the weekend. Or do an oil change if I can be arsed.
Thanks all for your help.
Fizzer Thou
PostPosted: 11:45 - 29 Jul 2017    Post subject: Reply with quote
I have found that a more reliable way of checking the oil level is to let the engine run for several minutes and after switching the engine off,leave it for about two minutes and then check the level.This is how both KTM and Honda (XR400) explain how to check the levels as stated in the manuals.
A few years ago I was out for a ride with several others.One had a problem with the engine not being too responsive,so we stopped in a quiet village to investigate.When it was noticed that there was oil dripping out under the bike and there was a smear from the oil filler cap,the question was asked if the owner had put any oil in recently.When it was admitted that there was only a small amount left in the oil can so the rest was poured into the sump,we leant the bike over so as to try and ascertain an oil level,as none could be seen in the sight window.With the bike near enough at over 45 degrees,a level was seen.We drained about 500ml from the sump.
The engine ran a lot better Thumbs Up Wink
Always have a 'Plan B'
cb1rocket
PostPosted: 13:02 - 29 Jul 2017    Post subject: Reply with quote
dry sump systems, so is checked differently
Honda H100S2 Rebuild - https://www.bikechatforums.com/viewtopic.php?t=253852
Fizzer Thou
PostPosted: 19:58 - 31 Jul 2017    Post subject: Reply with quote
Nope.The KTM is wet sump,but the manual still states to check the level with the engine warmed up.
The XR400 is dry sump.
arry
PostPosted: 20:41 - 31 Jul 2017    Post subject: Reply with quote
To be fair there's no easy route through. My KTM is dry sump and to be checked whilst warm. My Enfield is wet sump and to be checked whilst warm.
The last post was made 6 years, 269 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.95 - MySQL Queries: 17 - Page Size: 96.9 Kb
