c_dug |
c_dug Super Spammer
Posted: 22:36 - 08 Aug 2017 Post subject: Struggling to upload images! |
Trying to make a thread but none of my images are working, it's driving me absolutely mad!
This used to be so simple with photobucket but of course they've gone and fucked that, I've tried directly from google photos with no luck, Imgur isn't working for me either.
This is the thread: https://www.bikechatforums.com/viewtopic.php?t=321313&highlight=
Any advice?
Cant work out where I've gone wrong with imgur? ____________________ I am a bellend, I am a man of constant sorrow, I am a gummy bear, I am a rock. |
Ste |
Ste Not Work Safe
Posted: 22:39 - 08 Aug 2017 Post subject: |
https://i.imgur.com/6aNQsS3.png
The images in your "Fuck this shit. No idea why all of my imgur images wont show up either?" post work fine. |
CaNsA |
CaNsA Super Spammer
LOL
Code: | [img]http://goo.gl/photos/v9NSdBpEiDEveQQV7[/img]
[img]http://lh3.googleusercontent.com/M5rDH1Zpuf1p52zwNSI2hhYHz1hBgw0kYimhBMAhHmAAUfn2oBd2FkqFkZR6QAg22yM1N0UG99qArV-Bw4rrSeuRJPyVw8IiTt5eoTAMhq6ckBvPbfpM3giUZ1xLql2nqyyfqoZvibN1UW5ckw3qvo1iM7qvm-iNzxhApQY_CRDpyNW86fHjzVc8wP-VFaEcJy4fLAU_yUOp7z8DkYJ0QKOBnxyM_kbc77ehGb2sAtSTR0QOueKvf8FhiGMmNtuMeznkFBwM6l4SiHY7jB9XHm7RiWW4ZQwEgnXUmVN-mtH1JWm4qGvkNz9cV6Oeed1Q28j2q5WJoQbaj-e2CsAk9rSuovJceAe7qYdXu3CxHP-t3xmEZirRaD9Eu4xqDbNLXNXsJDWDZLhQuoAaUbZww3-GWeHd93seHcQqU09Gdc5FJW_3VC26ynZ4J5jaioEbFmi6ED395442vOS6cnyWpwLgLyL43LZ8PcmlppfeJ3LyFFQjAPakv3oBIxjdNHpTmyVMKAgYtsZoSVhiUKexXcQiVEtr8dbZbA7_rh0OCkKCrQ1WAWPhDhpzPXG3M6i0l8bz_hwc34En2oKFjs6Oy5D6ubZ1NjlPxy261GPcoIBY0LrAsgulk2R0=w883-h662-no[/img]
Until this happened:
[img]http://lh3.googleusercontent.com/R4MmRPNu-N6RzvL7ZN_Q2v8gSHXX_jS5OaXHIjqFhVzski5ujnBzwEirdfkGGGdHnR-d-6Jw4m8m8S9_rN29ecIv_Rr4xuQln4lvm2-ihV2jlYWOqYDgDc5Nn3cBGrV5NNSHnk3EPDavvw9yed7br6KooMirSD1Swd-fbLK5YhEdFzsmix59qj2NZ--nf7JVuKG4XqY-b7_IfX5-JZxPXJcV2TNPMouUqIO5DUQ6_Xtp9uLqft3bciZ1eMLt6iyZ1q-a4piSR9vvHE2UYKSNs2ttIo0C6rcaOKXQAD2tLdtRJmN4RMAJo1hQuSxccGSoeZTscB7wtcLuiS2ZCVISkN4Ae4kp0Hs7-ZzVCwCzYsxrPQcZC2dGfBtzCNX-kHLDNbBS0M6gkDHSV-TVDtjJWdfsRfcF10yhrSdNJPI54g3ZTv14dTDMUZUFe4nFsKnzxY_qn49q8D6BPo7C8_m-1a82WOwnDWwEH12_7g-zjRnCuA5ru9yQ_QOKQrlSnp_D-5ZPledeiHRt6hrXHIHar6MeHlwp5pMj9kheRGfHWyES_j5_jCznJcLvQm3mCoEIT4U1TvAXokQIpWQS-nHMZHI5lXaqxiOOdwJm22IoB1mlP5JdGaBJ=w883-h662-no[/img]
Then I dug out the biggest die I could find, M22, and finished up the other end to make this:
[img]http://lh3.googleusercontent.com/lFSBztgbTIbM3JReBIABbczXF3FUq2_HQ7DBZJYfF7Xv653JJK7U6rqNlx5WX9AUCvkV9AqkiVIraV3GUrmeWLwUGdty1Mo_4jr98aL3QrkkG-a-YsBSBNK5uLfJSHTGQ8hVlRxnv9yRw1OccYVbV7NOrYOIQ0rJ2tobjya2wevn4gJsaSW_JAnlUaVpcK-nJ2j62_YCVY3jPRLTnkgOKbSoYkVGWIaeJuplRPbseL-SDQoaA7N8W2R4qVJEy69NH5N48FSdlQsSzJXMTeYNkxXLPv_7is8cgINv9-n3ftLkZa-uEeuo2reU5huctMHSotvxCWuQWVpP3uicMqQILWEwswMRanDXbcn3j6hbvB6JqtXXri2Uc4EqAs5latGiSyCiC4mdFHlqO2sF8GokJ7kxHXb0brPdkzi7l4e-P9iy6YKmxX1lAdtUqyEUnsrYv_62cKbP031s_oJhxx14bnqeqS7fBmjtV93cIyLVwHWvlw8Dr6MX19FqhakNSd-got4xJwEKq8QtVPdW7XwSKgdCS9DIZ3hMltvDdr_myBvyAJ3RAolafIawQl_bKGwyfp_QUMhWo_c8zP12GOxqQ01x4yBQ3xqysio4pkyT__8xuqP5mkAw=w497-h662-no[/img]
Next I roughly hacked up a bit of ally flat bar to make a holding mechanism, it has a U shaped slot that goes over the flange on the bottle, you can also see the one way valve installed on the end here, it's a 12mm push fit:
[img]http://lh3.googleusercontent.com/8YeHkJ1lHlhgzZvnsWvC3azmbZL0Bp3A2drZbH1DlF5nBNsX6bsV4eoEsoUjqX4MX6D9jplqe0aW1XkDKnHNqVgIRT5Mg1_Az1SiSGundNDy4Rbt3snTDeyBHwm7GBNC2JTUc4k0GhfEw9bXIn8F9El08o2G5Pqz6TPKleadAPGBIeTibii3BtnxAG43LeQVDmXvzI0YHRmM3Zz-BpfUOccwpMyAvieyDlHq-R7b5zBS_n6oUme1NJ96-xp_Za33T45k27XQipBdDmP2SUpoUmRnIghyG_vRLHqCiaMG8BOkzqPhfTKUJp5TAvXl6Kw0Xpt0kDJYw4Ev6UAuWgzOfF7r8QgRX8_k2b937XhiAkgSrnh7j8AKV_2fwe05DG36Xle7XLlBnA-jkmjG1x-eDtVN4q2mgZUNqbDehRv4WO1bugQgn3TUKPoP6NVL0Tf0ax5xkBY3Tv2P9hMKaI6GWqvyAVZ2UJyEJByhNGIrnPGJgbCPSbsFN4n4Qut_wmsBtKu35vp-h3hKBprYpdok7-uCgtru4eP9MRTnv9Q1TsYqPYQsyPMAWNUcVu-STSggOWWxHvE9fXk2adXTHA7td6olEjq1kY3R2hsQjwK6uWvlD8QmE0LX=w497-h662-no[/img]
Next I found a large piece of ally U channel and machined a piece of Nylon to fit in the gap, then attached my flat bar to the top, and drilled and tapped an M22 hole in the end, to create this:
[img]http://lh3.googleusercontent.com/4zL5kTYEPQTPohtNvn50JotSyEOfyNdSLzrUD83sxQ-vTIBdRasjr7KL188LtBt7eFv7Mg1RBVeQHfjpG0riL8Gern3Qp8XdPxta-MoF207OQ5t94kWIKTZ5rmOwiYZU3KmcOuvLz4g4RbqXMBl2wNuLB-T8dntcKVolvUf391mYctlJF9W0-_HXZ8NPEi7jpkjO2XCjid3PwR9CU2KTxegx23O-z6Cq8kaaBAi_qwtPWCj4qobsK6MxBqbo4EGRZI4rA8DKM5JU7udSmF8Ps1q1fzJ8nVdFEPwMRKGJXMBRD-bgieNbpFzDG2x2p5cwXPOhyit2AbPvYA7WR4iuzgB0tIINpj1qazrpsA3Kk9rF6-qlAsTkUIax-ogK9IojGLnUT3_iwA7ZQkgCAOZHz1-QpsOSoBcFww0vI2f4kD_WVSfuIroBB3UdkjI4o_czlbwG74NyDH2j_J_T__LuCH1kLvALAQk0ZxLZHb132D827QbCzZQdepYH8CqSuD545jdDnR_IkUD4dXwfIlKEgSb7CXz2UbBciKzk4gBpkPJ8pTa3M218_Zt1WIcclK5LzxmQUiYcO3NevcpFKgZMSp3wefpAWMyPvcz-IiTYhi4V1EQhfCvm=w497-h662-no[/img]
[img]http://lh3.googleusercontent.com/ltp-Hn9X0iWa71xjy5NNzoCu4ujwvRpjm_dTFp-zYfVBbV02CjrtwzyvAnoEoahhW2tf8sjbbkh5pdITyG3BoH651cNU1qv8ZDggWm8ZEoCiPKHlzK4gw95rouDqcbzWl-xOE_TrB1mtmTx7LbZsUMwCWHYyJnQ9X-GWfQ2HKwCJMYftZ2Xw7Efi5IF3nEg-zwayQzbkkcwQRa2bKWb6em_Q-BPmXsQBruI2Td3rg0E-sXazEx9QIaLLFN712Cu09a2nO9YsiyjvTk4PdqOc_SlVjt23ClXbTE5n3qnBV9ImmE8BT1tV5SD6BhqijDIW9quhqNarEEsIipAlTFyjfpTbXi51Cb98k5I9NjcPfnFeX0YGtY0_5JdRrVT90_IW3AJxlvce6ccu0EmRpFsNtDmL3xPXeIUqXnJTbJ1Wq3qAiIbYorJ2_EOqWZfSkkw_D_7Z_6HRSK9JryNUzAFt_GdYzFIfBi3DZqtclL0aZt0mKk8WzvDtgffpW1PFdOErmVgMjgDqrZlS436EAGpbPFvX7GCHnFdc69Iibf-LoersdpUwsYYkZTj_lijxDcO0k8Zhx6C63-60desGXlfalHzsaR5IuVO4XW89GsxjDF8UaAaPWxVr=w883-h662-no[/img]
[img]http://lh3.googleusercontent.com/AQyZQZv9o_5TMlRGBGtn3tWOegseFsTBpZp6yOixSjX5SJE03bjFv5wt6ViR_0apqbMzDIDctvPyp2RLhzNvTJW1Rpe1URR5ba01llL2ZYms5srTtnmdm51BnULgakbgx9GlGIx4IsfzpoN9tOy-CnJ3NO3RXpzurHY9QN2A-jGrjMbWksMCx_7FHQxE1ynwFyrDDOw5f00pSKmF8-NL6Ya_7OeP9R4BK5Z32hS5G4lmihr4cAYZqjDNHx2Wr0FauYYbGnWko2MYT0lkcjzyzxon_m20uRs4a8OI2iyuycKxt32EGAIvaUAI8R1ZH-EdfINknDJsg75JLtNP7Ym6XahJi7pv9yvlX3LnP0XozC26TwUPD6OIvwx95ng83tjz6wb-KlEPOYekUldlU0k39TRvkHSSdXR-gdP1hT5WTO4lt_8eCr0bAuCF8RMAf0DY9lo0gluNwSbmBSV8zgTXZzH7iNqiNvDBTm4UJJWab_NM6Tre4NrjW9Zfe5BCRfI0e0KcqBluN7So60tJ9ZQelvhkyNz6zvbO5Qs8Oujp1oQ2WmigFtaYrH4i9Kk1F_vAJ4mFmuBcdRShiKDU_ho1o171VqxVmNPY5LXtnyxDNiJ8paMVjkdt=w883-h662-no[/img]
c_dug |
c_dug Super Spammer
CaNsA |
CaNsA Super Spammer
Posted: 22:46 - 08 Aug 2017 Post subject: |
image hosting from imgur.com looks like
Code: | [img]http://i.imgur.com/xxxxxx.jpg[/img] |
c_dug |
c_dug Super Spammer
Posted: 22:48 - 08 Aug 2017 Post subject: |
https://i.imgur.com/a77k4ZG.jpg ____________________ I am a bellend, I am a man of constant sorrow, I am a gummy bear, I am a rock. |
c_dug |
c_dug Super Spammer
owl |
owl World Chat Champion
Posted: 22:56 - 08 Aug 2017 Post subject: |
____________________ Observation is the greatest source of wisdom. |
Howling Terror |
Howling Terror Super Spammer
CaNsA |
CaNsA Super Spammer
Posted: 22:57 - 08 Aug 2017 Post subject: |
c_dug |
c_dug Super Spammer
Howling Terror |
CaNsA |
CaNsA Super Spammer
Howling Terror |
Posted: 23:08 - 08 Aug 2017 Post subject: |
The last post was made 6 years, 256 days ago. Instead of replying here, would creating a new thread be more useful? |
