lingeringstin... |
lingeringstin... Trackday Trickster
Posted: 02:23 - 10 Aug 2017 Post subject: some Chinese engine information |
I've been taking apart some Chinese twin engines and have discovered a few things.
For starters the Honda twin "Benly" clones are almost identical between the 125 and 250. They use the same engine cases, clutch, alternator, starter and they look almost identical except the 125 has a physically smaller top end.
The 125 engine studs are shorter than the 250 ones.
The 125 has a 41mm stroke and uses 13mm gudgeon pins. The 250 has a 53mm stroke and uses 15mm gudgeon pins. As far as I can tell either crank will probably bolt in to either bottom end.
So if you were converting a 125 into a 250 you'd need the 250 crank, cam chain gubbins, barrels and pistons, engine studs and head (or use the 125 head for high compression).
I am not sure if the 125 and 250 gearboxes are the same. I had already built my 250 engine before I acquired a 125 engine for spares and didn't have the opportunity to compare the gearboxes. But after seeing how similar the two engines were in every other respect I decided to build 125 as a spare engine but with a few design changes.
The 250 engine I recently rebuilt is a 253FMM. I've subsequently taken apart two different Chinese 125 engines now, one was an AJS Regal Raptor DD244FMI and the other one was a Jinlun 125 JL244FMI. The AJS had a 360 crank and the Jinlun had a 180 crank. Other than that they were identical.
In the photo below the head on the left is from an AJS Regal Raptor 125 engine. The inlets are about 22mm. The head on the right is from a Jinlun 125 twin, unknown model, and the inlets are about 19mm. Other than that they are the same.
https://s28.postimg.org/nf7wt7t99/111.jpg
The bolt pattern on the 125 heads is exactly the same as the 250, so you should be able to bung a 125 head onto a 250 motor to make higher compression. I don't see why this wouldn't work, the 250 pistons are basically flat top so it should work fine. I am not sure if the 125 and 250 cams are the same profile but they use the same tappets and maybe even the same valves. I haven't been able to check into this yet but I do know either cam fits either head. Both the 125 and 250 heads appear to be exactly the same height so the 250 cam chain and cam chain tensioner should work fine for putting a 125 head on a 250 engine.
125 head on 250 barrels:
https://s27.postimg.org/eau0gcvqb/image.jpg
The 250 barrels actually fit onto the 125 bottom ends. They just slid straight onto the AJS 125 bottom end, and were just slightly tight on the Jinlun bottom end but it's only by a very small bit that could be dealt with in a few minutes by some heavy sandpaper. Either head should fit but the 250 barrels are 15mm taller than the 125 barrels, so to fit them to a 125 bottom end (using the 125 crank) you'd need to shorten the 250 barrels by 15mm to cope with the shorter crank stroke of the 125. And this is where it gets interestingly complicated.
I intend to make a hybrid engine using a 125 bottom end with a 360 crank and am going to fit shortened 250 barrels to it, bored out to 56mm and using YX140 pit bike pistons because they have 13mm gudgeon pins to fit the 125 crank. I will use the AJS head with the larger inlet ports.
I'm going with the 360 crank on the 125 bottom end simply because I'm using a single carb and I've read somewhere that a 180 crank is a bit harder to get to run right with a single carb due to the funny inlet timing of the 180 crank.
This should make about a 200cc short stroke twin engine something akin to a Honda 185/200 Benly. I know it sounds like a lot of work when I've already got a perfectly good 250 engine sitting there but I am just doing this to prove it can be done. In theory I should get about 17 or 18 horsepower out of it. The 250 long stroke engine only makes about the same horsepower so there probably won't be much difference between them. They will both have identical motor mounts and use the same carb and exhaust so either one can be fitted to my bike without changing anything, they'll just bolt right in. This should be an interesting experiment. Pics to follow as I get to it.
Well, somebody's got to do it...
Rogerborg |
Rogerborg nimbA
Posted: 09:02 - 10 Aug 2017 Post subject: |
Thanks for posting this. So many times it's been asked, so few times answered. ____________________ Biking is 1/20th as dangerous as horse riding.
lingeringstin... |
jjdugen |
jjdugen World Chat Champion
Polarbear |
Polarbear Super Spammer
Posted: 21:09 - 10 Aug 2017 Post subject: |
It is interesting from a mechanics point of view but Chinese 125's and 250's?
Go sit in a corner with Linuxyeti and dribble over the damn things ____________________ Triumph Trophy Launch Edition |
lingeringstin... |
lingeringstin... |
lingeringstin... |
Posted: 12:44 - 13 Aug 2017 Post subject: |
I just thought I should mention this as there's bound to be somebody out there thinking this is useful Chinese bike information.
The 125 and 250 heads use different exhaust collars. The exhaust stud spacing on the 125 is closer together than on the 250, and they use different size exhaust gaskets. You have to use the right exhaust collars for the engine size.
I didn't think of it at first because the Quadzilla 250 two-into-one exhaust I have will fit either head. This is because the actual spacing of the exhaust ports is the same, which makes sense as the heads have the same bolt pattern and are pretty much identical apart from actual size and combustion area. Not sure about the valves yet but at a glance they look the same size.
The quad bike exhaust I have will fit either head so long as I have the right collars for the engine it's going on, which are easy to get as it's all Honda copy stuff and readily available.
ALSO...
I still think there's some difference between the 125 and 250 gearboxes but since I don't have a 250 apart at the moment I can't say how they differ.
This occurred to me again when I was trying to order an output shaft seal and forgot what size they are so I looked up a parts drawing to see if I could find the measurements.
The gearbox parts diagram here:
https://www.fowlersparts.co.uk/parts/view/91201030033
...says it's for all kinds of Honda 125, 185 and 200 engines but no mention of any 250's so I suspect there must be some slight difference in the gearboxes but I also suspect that with minimal modification (or none at all) either gearbox will probably fit either bottom end as they share the same dimensions for engine cases and use the same clutch, gear shifter and oil pump.
I suspect it's all down to slightly different gearing between the 125 and 250 but that isn't really an issue for me since sprockets on my amalgamated contraption are easily available in all kinds of sizes.
I'll be seeing the nice man at the machine shop soon to have him shave down and bore out some 250 barrels so i can put them on a 125 bottom end to make some kind of Chinese 200 twin engine for no apparent reason whatsoever. I still have some parts to get for the build so we'll see how it goes once I've got all the bits together.
And then of course there's still all the wiring to do and the motor mounts to make and the footpegs and pedals adapting and the exhaust making and the carb-sticking-on somehow and the battery getting and the butt scratching and the "Eureka!" shouting and the inevitable dammits, shites and feck I broke it's.
Hammertime! |
c_dug |
c_dug Super Spammer
Tankie |
Tankie Crazy Courier
lingeringstin... |
lingeringstin... |
The last post was made 6 years, 255 days ago. Instead of replying here, would creating a new thread be more useful? |
