CG125 damaged sump drain hole
mudcow007
PostPosted: 22:07 - 10 Aug 2017    Post subject: CG125 damaged sump drain hole Reply with quote
Just bought a ye olde (92) CG for my bro in law to get through his CBT on (he is 17)
Guy we bought the bike from said it had a slight leak from the plug, i looked at it an thought it must just be the washer - it wasnt
drained the sump tonight an found where the sump bolt screws in, there is a chunk of metal missing
so im not getting any sort of seal
any ideas?
Teflon-Mike
tl;dr
PostPosted: 03:48 - 11 Aug 2017    Post subject: Reply with quote
Guaranteed fix is a new crank case and a whole shed load of engine rebuild.
Bodges?
Anything gloopy wise is gong to have trouble sticking where metal is oily, & I wouldn't want to be doing daft like trying to burn off residue with a blow torch before applying gloop....
I might try a fibre washer and a load of bathroom silicone.. I wouldn't expect it to hold but at least slow oil loss to tolerable level before needing to re-do.
Metal-set, would be a wast, it wouldn't stick, and you'd have devls job flattng it to get a seal to stay.
Lumiweld would be the next best thing; but back to the blow torch, and hassle making seal suface.. can be 'cast' around steel plug threads though so might be worth a try, but I'd probably want the motor out and USD to tackle... and ponder whether be as sure and easy to hack the thing to bits..... of just ditch it and chuck in a Chinky lump from a MOT fail!
Back to top? I'd proably dran the oil; fluch with some paradin, clean up offeding area as est as; wop the lug in all but three turns, leave to drip, clean with thinners; get the mastic gun round it; leave to cure for a couple of hours; tighten plug up to a bit over finger-tight, if it felt like would take it; clean area with thinners, wop more mastic over and around, and HFTB... aint going to get worse, worst cas plug drops oils lost motor siezes, you are back to top and a rebuild with new cases of woping in a chinky take away.
temeluchus
PostPosted: 06:21 - 11 Aug 2017    Post subject: Reply with quote
JBweld would stick to that no problem.
Seeing as you have plenty of thread, PTFE plumbers tape might seal it up pretty well for as long as you need until you can get a new case or a permanent repair.
PostPosted: 09:48 - 11 Aug 2017    Post subject: Reply with quote
Degrease. JB weld. Fit plug with a dowty (bonded seal) washer instead of the usual compression job.
Andy_Pagin
PostPosted: 10:56 - 11 Aug 2017    Post subject: Reply with quote
In a similar vein, a good coating of thread lock on the drain plug may well seal it up, at least it's cheap and zero risk.
Tamsin
PostPosted: 19:36 - 11 Aug 2017    Post subject: Reply with quote
Show us a picture of the casing, I'll see if I have one in stock Cool
Triumph1300
PostPosted: 08:40 - 13 Aug 2017    Post subject: Reply with quote
Clean thoroughly, araldite, or jb weld to build it up, sand back, fibre washer to seal it.
BWJ
Back on a BMW R80RT
Punctuation - the difference between knowing your shit, and knowing you're shit Smile
The last post was made 6 years, 257 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.62 - MySQL Queries: 17 - Page Size: 56.91 Kb
