MarkJ World Chat Champion
Posted: 13:54 - 15 Aug 2017 Post subject: Crankcase seal blown - things to check? |
Hi, I've got a K7 GSXR 1000, just noticed that one of the joints between the lower and middle crankcase pieces is leaking oil so the gasket compound has failed.
I'm in the process of removing the engine to split the cases and re-seal, but is there anything else I should be checking? I've read that a blocked crankcase filter can cause pressure buildup which can cause seals to fail. Is there anything else I should check while I'm in the engine? Is there a way to test a crankcase filter?
Cheers |
Pjay World Chat Champion
Evil Hans World Chat Champion
