lingeringstin... Trackday Trickster
Posted: 01:03 - 16 Aug 2017 Post subject: Shortened 250 barrels for 125 bottom end |
So here we are with the next step in my experimental Chinese engine. The 250 barrels have been shortened by about 15mm to fit to a 125 bottom end. Here's the modified 250 next to some standard 125 barrels.
We did try to see if the 250 liners could be pressed out last week but they wouldn't shift so I'm hoping they're either cast in or at least such a tight fit they won't move now that the upper lip of the liner has gone.
https://s29.postimg.org/43cprlclz/image.jpg
https://s18.postimg.org/nfsoi12zt/image.jpg
https://s30.postimg.org/z1tb4ybf5/image.jpg
https://s12.postimg.org/rbv43oln1/image.jpg
I'll be getting some slightly bigger pistons for it but only around the 54-55mm size for now. If this experiment works I'd like to keep enough liner for rebores.
I've left a 180 crank at the machine shop and asked the guy to split it and see if it can be put together as a 360 crank. It might be possible but then again who knows what a Chinese crank is made like?
I still haven't decided which head to use but I'll probably go for a 125 head with a 250 cam and needle roller cam bearing modifications. |
Robby Dirty Old Man
jjdugen World Chat Champion
