sporkwings |
sporkwings L Plate Warrior
Rogerborg |
Rogerborg nimbA
Posted: 08:04 - 18 Aug 2017 Post subject: |
You can just go down a couple of teeth on the front and then adjust the chain to suit, as long as you've got plenty of adjustment left. I'm running -1 on the front of my Nazi Tractor, it's fine.
If you want absolute parity on teeth, you can go down on the front and up on the back to match. JT sprockets offers a wide variety of options:
https://www.jtsprockets.com/catalogue/model/1152/
But if you're replacing both sprockets, why not do the chain to match? And if you're going to do that, you can get any combination of sprockets and chain links that you want.
Are you asking about the ideal final drive ratio? Ideal for what purposes? Stunting, beating Fireblades off the lights? ____________________ Biking is 1/20th as dangerous as horse riding.
haroman666 |
haroman666 World Chat Champion
sporkwings |
Posted: 12:11 - 18 Aug 2017 Post subject: |
Thanks for the answer!
There is a brand new chain on, why I don't want to change it, if not necessary.
I am used to ride a Yamaha Xt600 as a commuter bike, but I sold it and got this Kawasaki er-5 in the trade, but I guess I miss the extra kick the Yamaha had, when I ride in the city.
I know it is two completely different bikes, but I think that I could settle if I just get a bit more acceleration out of the Kawasaki.
So then, the rule is, if I understand correctly, one tooth down on front, one up on the back, and the chain should fit over without taking off/applying chain links, is that right?
[quote="Rogerborg"]You can just go down a couple of teeth on the front and then adjust the chain to suit, as long as you've got plenty of adjustment left. I'm running -1 on the front of my Nazi Tractor, it's fine.
Are you asking about the ideal final drive ratio? Ideal for what purposes? Stunting, beating Fireblades off the lights?[/quote] |
Rogerborg |
Rogerborg nimbA
Posted: 13:28 - 18 Aug 2017 Post subject: |
Sure, but you can just go down a tooth (or more) on the front rather than buying a rear sprocket as well if it's in good condition. If it needs replacing anyway, fair enough. ____________________ Biking is 1/20th as dangerous as horse riding.
RhynoCZ |
RhynoCZ Super Spammer
Rogerborg |
Rogerborg nimbA
RhynoCZ |
Posted: 15:53 - 18 Aug 2017 Post subject: |
Alright, might not be overdrive, but everything else still stands. I've noticed this on the CB-1 and my neighbor's Ninja 250.
When I got the CB-1 there was a very short final drive gear ratio (+6 or even more teeth back - 44 teeth total). The bike did 190+km/h quite effortlesly reving the engine up to the limiter in the 6th gear. Then, I put it much closer to the factory final drive gear ratio, 4 teeth smaller rear sprocket (the factory was between 36 an 38 teeth, I couldn't get 38, so got 40). The bike was not capable of doing 190km/h, not even in the 5th gear, and it got a bit sluggish, BUT the fuel economy improved significantly, plus not revving it up to the top all the time reduced the engine temperature (the fan was pretty happy to kick in with the short ratio). ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
Kickstart |
Kickstart The Oracle
RhynoCZ |
The Shaggy D.A. |
The Shaggy D.A. Super Spammer
Posted: 12:28 - 19 Aug 2017 Post subject: |
Not if you select gears by the conditions and preference, rather than its number. ____________________ Chances are quite high you are not in my Monkeysphere, and I don't care about you. Don't take it personally.
Kickstart |
The last post was made 6 years, 243 days ago. Instead of replying here, would creating a new thread be more useful? |
