How strong battery do I need for electric start?
lingeringstin...
PostPosted: 10:43 - 18 Aug 2017    Post subject: How strong battery do I need for electric start? Reply with quote
I'm rewiring my bike to fit an electric start, electronic ignition 250 twin engine.
Previously I could run with any 12v battery that would fit in the hole because the bike was kick start and was easy to get going. But now I'll be needing a battery to turn a starter and my first impressions are to try to buy the biggest, most powerful but cheapest battery I can find that will fit the box.
There are loads of batteries that MIGHT fit in the box but really I have no idea what amps and shit would be best. And I might want to fit some fancy pants bright lights or something at some point.
Any clues?
doggone
PostPosted: 10:49 - 18 Aug 2017    Post subject: Reply with quote
Provided it's not a reluctant starter any 12V bike battery should be fine with that smallish engine.
You're probably more likely to find charging system is not up to running the extras mentioned for very long.
RhynoCZ
PostPosted: 11:01 - 18 Aug 2017    Post subject: Reply with quote
It's all about the starting current. If you get an average 8Ah (and more) battery, the starting current will be more than sufficient.
What would be the best? Well, the highest starting current obviously, with reasonable capacity. Higher the capacity, bigger the battery though.
I'd try something like 10Ah, 150A (more, means ''better''). I'm not familiar with your motorcycle though, and maybe a smaller battery would do the job as well.
Have a look at YTZ10S, that's what I would try first.
redeem ouzzer
PostPosted: 11:25 - 18 Aug 2017    Post subject: Reply with quote
Do you need it? Electric start is weight and drag. Fuck it off and use a house alarm battery.
Be a REAL MAN!
Teflon-Mike
tl;dr
PostPosted: 13:49 - 18 Aug 2017    Post subject: Reply with quote
Some of the Chinky bikes make do with a 6 or 7 Ah battery, I think the Super-Dreams, which were hugely over-rated for belt and braces 'you can rely on THIS e-start' honda thinking, is only a 9Ah....
If you are pondering equipment upgrades, the starter's out such an issue, as the out-put of the genny.... which has to keep the battery full.
lingeringstin...
PostPosted: 02:04 - 19 Aug 2017    Post subject: Reply with quote
The biggest problem I've got is the funny shape of the MZ battery box on my bike. Originally it was a 6v system with kick start so it didn't have a very big battery. I used to get by with things like house alarm batteries. For at least the last 10 years I've been using two Maplin's 6v batteries wired up for 12v because they usually have them on sale for half price every winter.
So far the only thing I've found that will fit the battery box is about 5 or 6 amps at most, which will probably be OK for this 250 twin engine.
temeluchus
PostPosted: 19:59 - 19 Aug 2017    Post subject: Reply with quote
There are very small lithium starter batteries that weigh next to nothing.
https://www.tayna.co.uk/YTX4L-BS-Shido-Lithium-Motorcycle-Battery-LiFePO4-LTX4L-BS-P10440.html
you could remove the gubbins,thats mostly a plastic housing to make it fit a battery box. Lithium cells can discharge much greater current for a given capacity compared to lead acid batteries.
PostPosted: 20:49 - 20 Aug 2017    Post subject: Reply with quote
And have a dreaded fire risk if charging is not regulated properly. 😦
I'm no' sayin' ye canny dae it. But something to consider. 😊
temeluchus
PostPosted: 20:55 - 20 Aug 2017    Post subject: Reply with quote
hence linking the premade Wink The case is mostly empty space, so one could gut it, repackage and put it wherever without having to tinker with circuitry.
The last post was made 6 years, 249 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.8 - MySQL Queries: 17 - Page Size: 65.75 Kb
