Replacing grease seals on Rear wheels, Necessary?
Falco
PostPosted: 20:57 - 18 Aug 2017    Post subject: Replacing grease seals on Rear wheels, Necessary? Reply with quote
Changing the rear wheel and sprocket carrier bearings this weekend, and forgot to order new dust/grease seals (I've seen them called several things, but they are the thick rubber ones that go on the right above the wheel bearing and the sprocket carrier on the right).
Assuming they aren't totally trashed am I OK to re-use them or is that asking for premature bearing failure? New ones are due mid week, but I want/need to use the bike before then.
I tell you what, mathematically, I'm having it
PostPosted: 21:15 - 18 Aug 2017    Post subject: Reply with quote
You might get away with it for a couple of days, but I wouldn't do it long term.
PostPosted: 08:54 - 19 Aug 2017    Post subject: Reply with quote
I have virtually never replaced them. But then I would use sealed wheel bearings which should make them pretty redundant anyway
Katy
Falco
PostPosted: 15:10 - 19 Aug 2017    Post subject: Reply with quote
Katy
When you say sealed do you mean this sort:
https://i.ytimg.com/vi/dQbKXbhyFQs/hqdefault.jpg
PostPosted: 17:23 - 19 Aug 2017    Post subject: Reply with quote
^^ Yes, that is a sealed bearing^^
Triumph Trophy Launch Edition
Falco
PostPosted: 21:07 - 19 Aug 2017    Post subject: Reply with quote
The seals turned up today (considering they were ordered early Friday morning its pretty impressive) so it all worked out quite nicely.
Thanks for the help
The last post was made 6 years, 249 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.7 - MySQL Queries: 17 - Page Size: 49.53 Kb
