zx9r woes
almostthere
PostPosted: 19:19 - 19 Aug 2017    Post subject: zx9r woes Reply with quote
Just bought a zx9r b2 its been standing for about 5 years, so I've had the carbs cleaned fresh fuel and new fuel pump.
it starts on the button it runs well on choke at first then as it warms up starts to miss off choke and just dies when trying to pull away, any ideas?
Beer, It's the reason I get up every afternoon
www.mfairco.uk
RhynoCZ
PostPosted: 19:27 - 19 Aug 2017    Post subject: Reply with quote
Last time I had such issue, there was water in my fuel. The second time I experienced this, was the ignition coil just being too old to work when hot. Thinking
CaNsA
PostPosted: 19:33 - 19 Aug 2017    Post subject: Reply with quote
Check all the HT leads.
almostthere
PostPosted: 20:07 - 19 Aug 2017    Post subject: Reply with quote
cheers I'll check the leads in the morning, Ive got a set of gsxr 600 stick coils would I be able to use them if the coils are fucked ?
www.mfairco.uk
V2
PostPosted: 00:16 - 20 Aug 2017    Post subject: Reply with quote
Also don't assume the carbs are clean just because you've had them cleaned, Last time I had running issues like that with the zx6r the carbs took 3 goes through the ultrasonic cleaner before it ran well again!
johnsmith222
PostPosted: 23:49 - 22 Aug 2017    Post subject: Reply with quote
I had a similar problem where I had a slight air leak due to a gap between the airbox halves when putting it back together.
if the bike has sat for 5 years, I would go over everything maintenance wise, especially stuff like spark plugs, air filter, checking for air leaks, change oil/coolant etc, and do valve clearances. In the process of doing that then you might come across something problematic.
I just did similar for my 9R which sat up for nearly 2 years.
Check if there's a downpipe that's not getting as hot as the others as quickly. Might help identify the problem.
bypass2
PostPosted: 00:12 - 23 Aug 2017    Post subject: Reply with quote
faulty/restricted petrol flow from the petrol tap. have you cleaned the petrol tap.
Kawasaki Jimbo
PostPosted: 00:45 - 23 Aug 2017    Post subject: Reply with quote
stickybackbob
PostPosted: 22:55 - 02 Sep 2017    Post subject: Reply with quote
Fuel pump relay? Try by-passing the fuel pump by connecting the petrol tap directly to the carbs.
Johnnythefox
PostPosted: 23:02 - 02 Sep 2017    Post subject: Reply with quote
if runs on choke then pilot jet is ok, dies off choke, main jet blockage?
Fizzer Thou
PostPosted: 19:33 - 04 Sep 2017    Post subject: Reply with quote
I would be looking at the 'O' rings 92055 between the inlet manifolds and the cylinder head
https://www.cmsnl.com/kawasaki-zx900e1p-ninja-zx9r-2000-europe-uk-fr-is-nr_model12958/partslist/E1111.html#results
If one or more of those have split it will weaken the mixture considerably
Always have a 'Plan B'
The last post was made 6 years, 235 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.46 - MySQL Queries: 17 - Page Size: 68.35 Kb
