mudcow007 |
mudcow007 World Chat Champion
mudcow007 |
Posted: 17:52 - 27 Aug 2017 Post subject: |
after looking at my own photo, if i was to cut the pipes then fit a few of these on
https://www.screwfix.com/p/male-coupler-15mm-x/69358
then i could screw the flexi's to these couldnt i?
i can see cutting the pipes to be a bit of an issue though |
MCN |
MCN Super Spammer
Posted: 17:54 - 27 Aug 2017 Post subject: |
Those two copper doofurs will unscrew from your existing mixer. (The Hex will unscrew from the underside of the mixer body.)
You need to buy two 15mm fittings c/w Nuts and Olives.
Cut the two doofers off above where they have been sweated onto the hot/cold supply.
Wire wool the top 20mm of the supply.
Fit your straight 15mm fitting over the cleaned end.
Nip the nut tight onto the fitting. (You do not need to go mental the brass olive is soft.)
Remove the nut and olive from the other end of your straight fitting.
Install your flex hose nut over the fitting.
Edit:
Buy a wee pipe cutter. Cheap as chips.
https://www.screwfix.com/p/monument-tools-automatic-pipe-cutter-15mm/12468
Edit II
You have to turn your water off at the mains and isolate your hot water supply at the hot cylinder or boiler.
You will then have to open all your taps and let the water drain.
It could take ten minutes to drain down.
Then you may have to go here to get your hot running again.
https://www.diynot.com/diy/threads/drained-cold-water-tank-no-water-to-taps-now.255388/ ____________________ Disclaimer: The comments above may be predicted text and not necessarily the opinion of MCN. |
Ste |
Ste Not Work Safe
chris-red |
Posted: 10:43 - 29 Aug 2017 Post subject: |
Cut the pipes.
Put on these
Then fit flex pipes to those and screw the flex pipes to the tap. (Note you may have screw the pipes to the tap first as depending on the tap fitment only the valve end spins freely.)
Sack off Screwfix and go to your local plumbing merchant, you can walk in there with the tap tell them what you want to and they will get the bits, and you can check in in the shop to see how it all fits together and ensure you have the right bits. I bet it will be noticeably cheaper too. ____________________ Well, you know what they say. If you want to save the world, you have to push a few old ladies down the stairs.
MCN |
MCN Super Spammer
Posted: 11:49 - 29 Aug 2017 Post subject: |
chris-red wrote: | Cut the pipes.
Put on these
Sack off Screwfix and go to your local plumbing merchant, you can walk in there with the tap tell them what you want to and they will get the bits, and you can check in in the shop to see how it all fits together and ensure you have the right bits. I bet it will be noticeably cheaper too. |
This is correct.
Regulations require isolation to be installed. ____________________ Disclaimer: The comments above may be predicted text and not necessarily the opinion of MCN. |
Freddyfruitba... |
Posted: 16:05 - 29 Aug 2017 Post subject: |
OP, please can you provide the Screwfix link for your new tap and preferably a photo of its connections?
MCN wrote: | Buy a wee pipe cutter. Cheap as chips. |
Definitely - don't even consider grovelling around behind that sink with a hacksaw
chris-red wrote: | Put on these
Then fit flex pipes to those and screw the flex pipes to the tap. |
Bzzt! Unlikely that the flexi pipes will connect direct to the isolation valve - a short length of copper would most likely be needed between them; but there are better options; let's see what the OP's connections are before guessing though.
MCN wrote: | Regulations require isolation to be installed. |
Um, nope. But definitely a very good idea to to do so anyway. That said, there appears to be one of those nasty self-plumbing washing machine valves on the incoming cold pipe, so unless that gets moved/replaced (also a good idea!) the OP may well be a bit stuck for space working under there, especially given his level of experience.
Ste wrote: | You don't need to turn the water off and drain it all. Using some freeze spray on the pipes is much easier and the excitement of getting it all done before the ice melts is much more adrenaline filled then the boring option of turning the water off. |
Meh! Freeze spray is for wimps (only kidding, OP!) ____________________ KC100->CB100N->CB250RS--------->DL650AL2->R1200RS->R1250RS |
mudcow007 |
Posted: 16:28 - 29 Aug 2017 Post subject: |
slight update
hit a snag, the pipes that come from the bottom of the new taps are way to long to under my sink. looking at the picture i posted the legs would easily go past the soldered "T junction" at the bottom of the picture
then i would need to fit isolator valves aswell as the flexis to the supplier. how much room to peeps have under their sinks?!
Taps
https://www.screwfix.com/p/swirl-fresco-deck-sink-mono-mixer-kitchen-tap-chrome/21923 |
Freddyfruitba... |
MCN |
MCN Super Spammer
Ste |
Ste Not Work Safe
Posted: 21:22 - 29 Aug 2017 Post subject: |
Once you've had to waste time on plumbing where someone else decided to save a little bit of time and money by not fitting isolator valves, you'll appreciate how useful they are.
On a similar topic... push fittings! Just don't!! |
Freddyfruitba... |
mudcow007 |
Posted: 10:23 - 30 Aug 2017 Post subject: |
Will take photos of the mess that is my under-sink tonight
cheers chaps |
The last post was made 6 years, 238 days ago. Instead of replying here, would creating a new thread be more useful? |
