Xbox One removable/portable hard drive
M.C
PostPosted: 20:54 - 30 Aug 2017    Post subject: Xbox One removable/portable hard drive Reply with quote
I'm currently using a 1TB WD Passport drive that's nearly full, what I don't like about it is it has a really bright blinking LED (I know I can cover it up), but also if you turn the mains off then on the drive starts and stays spinning (even though the console's turned off) Confused It means I have to keep the drive unplugged, I'd like something I can plug-in round the back and forget about.
So basically I'm after a 2TB+ drive that doesn't do that Razz Any recommendations?
PostPosted: 10:29 - 31 Aug 2017    Post subject: Reply with quote
It''l be still spinning because the USB port is powered when the console is off/stand by. There may be an option in settings to turn this off.
owl
PostPosted: 11:03 - 31 Aug 2017    Post subject: Reply with quote
this, look under power settings on the console, you can make it turn off completely rather than standby, takes a bit longer to boot up but should turn the drive off
PostPosted: 11:14 - 31 Aug 2017    Post subject: Reply with quote
I think my PS4 actually has an option to just turn the power to the port off in stand by.
owl
PostPosted: 11:59 - 31 Aug 2017    Post subject: Reply with quote
yep, looks like same option on xbox under power settings > turn off storage when xbox is off
https://windowsitpro.com/site-files/windowsitpro.com/files/uploads/2016/06/20/xboxonepower.jpg
if that's on and not working it may be a compatibility issue with the drive like you said
M.C
PostPosted: 13:15 - 31 Aug 2017    Post subject: Reply with quote
I tried that before but it seems to be a 'feature' of the drive, same thing happens if it's plugged into the PC and I turn the power off/on at the plug.
The last post was made 6 years, 237 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.69 - MySQL Queries: 17 - Page Size: 48.9 Kb
