TheSmiler |
TheSmiler World Chat Champion
Posted: 08:52 - 02 Sep 2017 Post subject: Garage Advice : Replace or Keep |
I'm waiting for the keys on my new house in the meantime I'm getting quotes of work that I want doing when I move in so I know how much I need to save up. Now the house I'm getting has a 17x10ft garage however it is pre fabricated and has an asbestos roof with a solid concrete floor. Now the door will need replacing and so will the front surround. The problem is though it currently doesn't have any electric. Not good when I'm planning on working on the bike in there.
Now I've priced up a new roof and to remove the asbestos roof at £2500 or there about. Electrics to the garage I can't get a quote till I move in. Also priced up a new garage door at £900 from a friend that works for a company that makes them.
However here is the dilemma I want to spend more time in there in the winter so make it warmer and secure. This house is going to be for quite a few years so don't want to make the wrong decisions.
So I'm stuck with 3 decisions
1: Stick with it get electric hooked up to the garage ?
2. Put electric to the garage replace the garage door then replace the garage in the future.
3. Don't bother with electric, make do and then remove and get new garage built.
BCF I'm at your mercy would love some helpful advice on this. ____________________ CB125>CG125>GN125>ER5>K100RS>R1100RS>K100RS
A2 completed 23/07/15 Ready for the Golden Crisp Packet |
Polarbear |
Polarbear Super Spammer
TheSmiler |
grr666 |
grr666 Super Spammer
Posted: 10:11 - 02 Sep 2017 Post subject: |
TheSmiler wrote: |
I've heard some and read some horror stories of people drilling into pre fab garages to put shelves up and cracking a pannel. (yeah I know you shouldn't believe everything). |
That's because you have to use a hammer action to drill concrete, it's unlikely you will get a drill through without
hitting a stone/rebar anyway. Just run a long extension lead into the garage for now. I've had that setup in my shed for years.
Just make sure it's made of arctic cable so it isn't affected by cold conditions,it's easy to make your own custom
length one with a trailing socket on one end and a plug top on the other plus how ever much 2.5mm arctic you need.
This is the stuff Plus one of these
Replacing the building won't be cheap. I'm about to spend about 15k on a similar sized brick outbuilding in my garden,
although to be fair that will have proper foundations and be a cavity wall, insulated type affair built to the same
standards as a house. I'd expect to pay about 5 to 7k for a brand new single skinned brick garage with a new door
and electrics. Don't wreck it if you do get rid, stick it on ebay as a buyer collects and dismantles. Let someone
else pay you to remove it. As for the asbestos, which you will have to dispose of, see what your local council will accept
at the tips, if its dampened first removal shouldn't be too hazardous, obviously gloves, masks and disposable overalls are needed,
plus some of the bags the council supply to package it up again. Try to get the panels off in one lump, grind the bolts off from
the underside if they are seized. Burslem tip acepts bagged asbestos.
https://www.stoke.gov.uk/directory_record/386/burslem_tip
Assuming it doesn't fall through I'll have to pop over for a cuppa while I'm doing the renovation on the property
I'm in the process of buying in Stoke. In fact scratch that. Since it was your purchase that got me looking in the area
anyway, I 'll take you out for some gourmet burger action to say thanks. In the meantime, find us somewhere nice
you fancy going and we'll go out when I'm down there. I can come and cast my eye over your gaff if you like. ____________________ Currently enjoying products from Ford, Mazda and Yamaha
MarJay |
MarJay But it's British!
Raffles |
Raffles World Chat Champion
TheSmiler |
grr666 |
Posted: 20:56 - 02 Sep 2017 Post subject: |
Cool, it's up to you to hunt down a primo burger joint. I'll only be down for a week while I do my renovation.
OMG grill looks decent though. Failing that theres a branch of the Gourmet Burger Kitchen in town. As I said,
it'll be on me so whatever takes your fancy. I know you like a good burger. ____________________ Currently enjoying products from Ford, Mazda and Yamaha
ocatoro |
ocatoro World Chat Champion
Posted: 00:02 - 03 Sep 2017 Post subject: |
the locksmith isn't going to open the door with a wrecking ball, you know.. ?
he'll just remove the lock barrel. which will solve your key and warped barrel issue, he'll then fit a new barrel and supply you with a key for it. no new door required from what you've said.
also, forgive me if i'm wrong. but isn't asbestos only an issue from long term, repeated exposure? like people working with it for 30+ years, like miners getting shagged lungs isn't the same thing as using a bit of coal to make a fire in your house. ____________________ CBT - 17/09/12 * Theory - 23/10/12 * Mod1 - 05/03/13 * Mod2 - 25/03/13 * BOSH!
Current - None but shed project H100 (first bike )
Past - ER5, '93 ZZR600, '92 CB400 SF, ZZR600 (again), yellow Monster 620, Blackbird - black Monster 620ie - '96 ZZR600 |
Pete. |
Pete. Super Spammer
TheSmiler |
Posted: 08:41 - 03 Sep 2017 Post subject: |
grr666 wrote: | Cool, it's up to you to hunt down a primo burger joint. I'll only be down for a week while I do my renovation.
it'll be on me so whatever takes your fancy. I know you like a good burger. |
I'll leave it up to you I rarely know the good food joints in the area anymore. Most of my old haunts have shut up shop. I'm hoping this should be completed by the end of the month.
ocatoro wrote: | the locksmith isn't going to open the door with a wrecking ball, you know.. ?
also, forgive me if i'm wrong. but isn't asbestos only an issue from long term, repeated exposure? like people working with it for 30+ years, like miners getting shagged lungs isn't the same thing as using a bit of coal to make a fire in your house. |
You would be surprised I had a lock smith out before for a bike lock I had lost the key to in the centre of Bristol. He ended up angle grinding through the actual lock to open it. The facet I think it's called that the surround has gone anyway and I've found cheaper quotes to replace the whole thing than to replace that so far. ____________________ CB125>CG125>GN125>ER5>K100RS>R1100RS>K100RS
Polarbear |
ZebraDriver |
ZebraDriver Scooby Slapper
Pete. |
Pete. Super Spammer
Nobby the Bastard |
Posted: 12:12 - 03 Sep 2017 Post subject: |
I agree with the 'temporary power rigged up with an extension lead.' There's no reason why you can't screw strip lights to the wall/ceiling and still have a plug on the end to plug them in to the extension lead.
You could even put a proper switch on the wall for them. When you put in an armoured cable underground, you could just put a junction box approximately when your plug would have been and then just hard wire instead.
I did a similar thing in my loft with a strip light wired to a twin plug socket.
https://i.imgur.com/7JAOW9R.jpg
https://i.imgur.com/GKOPsks.jpg
https://i.imgur.com/xFevZui.jpg ____________________ trevor saxe-coburg-gotha:"Remember this simple rule - scooters are for men who like to feel the breeze on their huge, flapping cunt lips."
Sprint ST 1050 |
Diggs |
Diggs World Chat Champion
Posted: 12:58 - 03 Sep 2017 Post subject: |
I don't know if this fits your situation, but garage door locks like yours can often be undone using a spam-key. Yours looks similar to mine, and my kids can open it in seconds this way... If I were in your position I'd consider something like this in the short term.... https://www.ironmongerydirect.co.uk/product/squire-high-security-garage-door-defender-156965?vat=1&shopping=true&utm_source=bing&utm_medium=cpc&utm_campaign=Shopping%20%3E%20Locks,%20Latches%20%26%20Security%20%3E%20Padlocks%20Chains%20%26%20Security%20Devices&utm_term=4580496722179207&utm_content=156965%20-%20Squire%20High%20Security%20Garage%20Door%20Defender&gclid=CPHawJX7iNYCFZIFGwod05QMnA&gclsrc=ds ____________________ Now - Speed Triple, old ratty GS550, GSXR750M
Gone (in order of ownership) - Raleigh Runabout, AP50, KH125, GP125, KH250, CBX550, Z400, CB750FII, 250LC, GS550, ZXR750H1, Guzzi Targa, GSX750F, KH250 x2, Bimota SB6R and counting... |
Robby |
Robby Dirty Old Man
Posted: 13:17 - 03 Sep 2017 Post subject: |
If it was me, I'd be getting rid of the asbestos roof. I would want to put in some overhead tube lights, and that means drilling into the ceiling to fit them. Also, you'll be getting rid of the asbestos sooner or later, which means you need to have the garage empty. Best to do it before you start filling it with crap.
As for electricity, I don't have any in my garage. I have a leisure battery, and a generator. The leisure battery runs the lights, which are 12v LED strip lights, sold on ebay for caravans. Cost about a tenner each. It also powers an inverter for low power things like my ultrasonic cleaner. The generator is only used for the welder and compressor. You don't need 240v very often.
Sort the roof. Everything else can wait. Do the power and door together, so you can have an electric door.
Get the electrics done by an electrician. Maybe dig the trench for the cable yourself, but let a professional handle the rest of it. Not just for your safety, but you'll be displeased if you burn down your own garage and bikes over some shoddy wiring. Even more displeased when the insurance don't pay out because it was your own shoddy wiring.
Other garage pro-tips from my experience of a council lockup:
1. Ventilation. Make sure it has some. You wouldn't believe how wet they get.
2. Insulation. Nice to have if you're doing a garage project.
3. Flooring. Garage floor paint is great stuff. It means your concrete floor won't generate tonnes of dust. Interlocking rubber tiles on top are even better, but pricey.
4. Shelving. The sort they use in small warehouses, fixed to the wall so it can't fall over. You will end up keeping all kinds of crap on it.
5. Ground anchor. If your concrete is anything like mine, you'll blunt a lot of drill bits fitting it, but it's worth having. |
TheSmiler |
331X2 |
331X2 Crazy Courier
Posted: 09:18 - 04 Sep 2017 Post subject: |
Congrats on the buy.
When I removed the asbestos (type?) roofing sheets from the garage at my old house I was told to double bag them in sturdy rubble sacks and took them to the Veolia transfer station in Nottingham FOC. Regardless of if they're asbestos or not they will be treated as such by any waste disposal place even if you have them tested
Extension lead from the house means that you can safely and legally DIY, I ran my old garage like that for a couple of years before dragging services to it.
The front of mine was completely rotten too, if I was in that position again I would look to have a completely new front made from solid timber with two side hinged doors that can be bolted securely.
If you go for metal roof sheets then allow for anti condensation coating at the very least, preferably insulation. When the weather gets damp/cold it gets like a rainforest inside with plain metal sheeting. |
MCN |
MCN Super Spammer
Posted: 18:01 - 04 Sep 2017 Post subject: |
I bought a pre-fab garage and have electric in too.
It was a bit cold in winter so I hummed and hawed about what to insulate with.
Some people swear that Plywood is easy.
It is very expensive when compared to Gyproc.
I got Insulated Gyproc from Rowan Timber to do my garage.
I planned to Dot-and-Dab the sheets to the walls. Very simply DIY job as it doesn't need to be Show House standard.
The issue was the pre-fab panels are not flat. They have flanges to allow them to bolt together.
The real way would have been to rock-bolt wooden batons to the pre-fab panels then nail the Gyproc to the batons.
Un-daunted by this mere detail I battered on. I applied the adhesive to the faces of the flanges and offered up my first board.
It would not stick.
The adhesive doesn't stick to polystyrene
I resorted to pilot drilling the boards through into the pre-fab panel flanges.
Drilling the pilot holes to the rawl-plug size and rawl plugging the boards to the wall.
It was worth the effort as my garage now heats up within a few minutes after I turn the calor fire on.
If you are going to run power then buy your Armour Cable now and run the power through that.
Later an electrician can use spare a space in your house consumer unit for a low current breaker to feed the garage . Then feed the garage through another small consumer unit.
If you trip a breaker in the garage then you only affect the garage and not the house.
And supplying a small consumer unit lets you split the power. You can have lights on one circuit and sockets on another.
One supply for all can mean having to feel your way out a darkened Trip Hazard Zone in the dark if you blow a fuse.
And if the telly goes off during GOT there will be hell to pay.
It sounds like a lot but it's relatively simple. ____________________ Disclaimer: The comments above may be predicted text and not necessarily the opinion of MCN. |
chris-red |
Posted: 14:47 - 06 Sep 2017 Post subject: |
As for power you can do something Semi Permanent.
Get an External Socket...
https://www.screwfix.com/p/lap-13a-2-gang-dp-switched-plug-socket-with-outboard-rocker/30139
This is water proof even with things plugged in. I'd recommend anyone get one as they are dead easy to install and really handy.
You can mount that easily on the other side of an internal socket (take of the socket off Drill through the wall through the back box and run a spur through the wall to external socket.
In the garage you can run sockets lights etc. If you then get a length of cable and plug the external socket into the garage. Either run it with decent cable outdoor cable and clip it out the way and have it always there or simply plug in when you need too.
Obviously this isn't 'proper' and I wouldn't run anything heavy duty off of it the hole garage will be on a max 13A fuse anyway but it is a bit better then just running an extension lead. If you to a 'proper' job the lights/ plug sockets you should then be able to easily adapt when it is done 'properly'. ____________________ Well, you know what they say. If you want to save the world, you have to push a few old ladies down the stairs.
CaNsA |
CaNsA Super Spammer
Posted: 14:56 - 06 Sep 2017 Post subject: |
Minty |
Minty World Chat Champion
J4mes |
J4mes World Chat Champion
Posted: 17:09 - 06 Sep 2017 Post subject: |
Just take it off yourself,
disposable gloves/coveralls/suitable masks, cheap wellies (or boot covers), run the hose over each board before you disturb it, pass it down to a mate and bag it up.
As a last job, hose yourself down, strip off and bag your disposables up in the same way.
mask and gloves off last.
pompousporcup... |
Posted: 10:01 - 07 Sep 2017 Post subject: |
chris-red wrote: | As for power you can do something Semi Permanent.
Obviously this isn't 'proper' and I wouldn't run anything heavy duty off of it the hole garage will be on a max 13A fuse anyway but it is a bit better then just running an extension lead. If you to a 'proper' job the lights/ plug sockets you should then be able to easily adapt when it is done 'properly'. |
This is what i've done and it works well enough to run 2 strip lights, welder/grinder/circular saw. Other than lights and maybe a PC, you're only ever going to use one major power tool at a time.. unless you have really fancy stuff like mills/lathes etc.
It was cheap to set up and can also be moved/changed as required. Once everything is set up the way i like it then i'l think about getting a sparky in to hook everything up properly with its own breakers etc etc
The most expensive thing was the hammer drill as i didnt have one at the time.
My 2p. Paint the walls asap and get the roof sorted. The rest will follow with time. I certainly wouldnt be knocking it all down just for the sake of it. Its a lot of time and money.
1. Get it water tight. IE get the roof swapped. That's also a relatively easy DIY job. I wish i'd DIY'd mine rather than paying the best part of 2k to have a bunch of apprentices do it.
2. Ensure its ventilated
3. Ensure its secure against any scrotes
4. Get DIY power to it.
5. Paint everything white. Hang posters of naked ladies*/motorcycles
*or men... if thats what you like |
The last post was made 6 years, 231 days ago. Instead of replying here, would creating a new thread be more useful? |
