Beep Test...
Tracer1234
PostPosted: 02:31 - 03 Sep 2017    Post subject: Beep Test... Reply with quote
So, a bit of a random one, but I come seeking, once again, BCF's eternal wisdom.
I need to pass a fitness test. Now, the link below is the beep test we use. I need to get to level 86.
Anyone on here have any experience with passing beep tests and can give any pointers as to the best technique and training ideas / sessions that would be amazing?
I am currently around level 66, and I have just under a month.
Beep Test
TYIA. Thumbs Up Thumbs Up Karma Karma
RhynoCZ
PostPosted: 08:47 - 03 Sep 2017    Post subject: Reply with quote
Not sure, but if you need clean urine, I'm your man. Thumbs Up
andyscooter
PostPosted: 08:54 - 03 Sep 2017    Post subject: Reply with quote
run faster
hth Laughing
grr666
PostPosted: 09:44 - 03 Sep 2017    Post subject: Reply with quote
My sister went running everyday in the woods with her dogs. Are you joining the old bill?
Going
PostPosted: 09:51 - 03 Sep 2017    Post subject: Reply with quote
Get the tape, get the correct distance and practice. That's all. By the time of the test you should roughly know when to hit the line with the beep. Easy.
wr6133
PostPosted: 09:53 - 03 Sep 2017    Post subject: Re: Beep Test... Reply with quote
Run/walk each level at the speed needed to pass. If you hammer out the early ones 10 times faster than needed you are just wasting energy you need at the later levels.
Tracer1234
PostPosted: 15:23 - 03 Sep 2017    Post subject: Reply with quote
There will be no drug tests involved, so anything to boost performance isn't out of the question lol.
Ok, so the advice given so far seems to match with what my plan is Smile
Practice practice practice. HIIT Training and probably a bit more practice.
P.
PostPosted: 18:34 - 03 Sep 2017    Post subject: Reply with quote
Replace beep test media with longer beeps, safe.
M.C
PostPosted: 20:52 - 03 Sep 2017    Post subject: Reply with quote
I can too Shifty Money upfront... no refunds.
ScaredyCat
PostPosted: 22:05 - 03 Sep 2017    Post subject: Reply with quote
Plot twist, RhynoCZ is actually a pregnant woman.
Honda CBF125 ➝ NC700X
Honda CBF125 ↳ Speed Triple
Tracer1234
PostPosted: 22:06 - 03 Sep 2017    Post subject: Reply with quote
Well it would certainly be a better ending that the kappaGamma ending thats for sure.
M.C
PostPosted: 22:58 - 03 Sep 2017    Post subject: Reply with quote
Off topic but you brought it up Whistle what has been happening (I lost interest a while ago)? KappaGamma once touted by the Adams failed to deliver a rival product?
Tracer1234
PostPosted: 23:37 - 03 Sep 2017    Post subject: Reply with quote
Im not sure anyone knows. kappaGamma thing disintegrated in a rather anti-climatic. Regardless if it was ever real or not, it definitely did the job of poking and prodding the Adam into a deeper world of confusion.
trevor saxe-coburg-gotha
PostPosted: 06:56 - 04 Sep 2017    Post subject: Reply with quote
well that's cleared that up
zark
PostPosted: 09:09 - 04 Sep 2017    Post subject: Re: Beep Test... Reply with quote
you get like 2 warnings before you're disqualified, right?
so "walk" 2 - take the warnings - run one, warnings reset to zero.
rinse and repeat.
CBT - Oct 13. Theory - July 14. Mod 1 & 2 - June 15.
Rides a Fazer like an idiot... Edit: Now ride a Fazer Thou...
TaffyTDM
PostPosted: 09:21 - 04 Sep 2017    Post subject: Re: Beep Test... Reply with quote
[quote="zark"]
rinse and repeat.[/quote
You still have to catch up within the shuttle so reality is you will be sprinting the third, which will tire you quicker.
If you are able to listen to iPod whilst doing it (many test based qualification regimes won't let you though) get some angry music on to pass the time, a big part of it is overcoming the monotony of the beeps and the pointlessness of running back to where you started.
Other than that, build your pace gradually, keep a fixed point on the target wall that will keep your head up and breathing well, and instead of turning on your heel at the line jog around an imaginary roundabout. Seems like more work but is a big help in keeping the rhythem. Interval training on the mill or jogging and sprinting between alternative lampposts I found works well. Aim to be comfortable at twice the time your target level takes to reach.
Loui5D
PostPosted: 10:23 - 04 Sep 2017    Post subject: Reply with quote
Interval training helps bring up your stamina.
Walk for 3 minutes sprint for 1 then rinse & repeat slowly lessen the walking time & increase the sprint time.
PostPosted: 11:14 - 04 Sep 2017    Post subject: Reply with quote
If it's for army selection, it's probably more important that you keep hammering at it until you barf than achieving the actual level.
But as others have said, cross the line on the beep, don't go faster than you need to.
When your arse starts to drop out, remember to concentrate on breathing out, the breathing in will happen by itself.
Tracer1234
PostPosted: 11:30 - 04 Sep 2017    Post subject: Reply with quote
Thank you all for tips and advice Smile Ill keep you posted as to how I get on! Thumbs Up
AshWebster
PostPosted: 13:26 - 04 Sep 2017    Post subject: Reply with quote
its all about efficiency.
don't run over the line, start to slow down in advance so that you don't waste energy on stopping after the line. don't panic if you miss one, just up your effort % accordingly. slow breathing.
(source) boxing training / always being last remaining on the bleep tests
good luck
Honda cg125 J reg peice of shit ---> CB650F ---> 2016 CBR600RR
Ford KA ---> 93' MR2 ---> 94'MR2 ---> 98' Subaru WRX STI Ver 3 (track car)
P.
PostPosted: 13:47 - 04 Sep 2017    Post subject: Reply with quote
Lets talk about efficiency.
Hows your Merc?
el_oso
PostPosted: 14:59 - 06 Sep 2017    Post subject: Reply with quote
What amount of time does it take to get to level 86?
I'd make sure you can at least run continuously for that amount of time plus maybe 50% more. Don't worry about the speed, just make sure you don't stop. I'd be doing these longer runs once or maybe twice a week.
This reminds me that I need to do a lot more training, can't run for shit.
Duke 390
Car: Jeep Wrangler 4.0L
AshWebster
PostPosted: 17:02 - 06 Sep 2017    Post subject: Reply with quote
Hows your Merc?
surely time will tell? bit early to judge after a week
40-60 mpg depending on length of journey and no problems yet.
thx1138
PostPosted: 17:20 - 06 Sep 2017    Post subject: Reply with quote
keep your head up, it helps breathing, dropping your head hinders breathing
thx1138
PostPosted: 19:46 - 05 Oct 2017    Post subject: Reply with quote
I just got in from doing a beep test.
We were using some tennis courts in the park at dusk, and marked it out with coloured glow sticks.
20metres with 10 beeps per level. I made it to the end of level 8 or 89x20metre sprints, it was the turns that did for me. Couldn't make it to the line for the beep, could have kept running though.
second time, I gave up at level 7
then we did group relays at 50metres. I ran to and from the venue as well.
In conclusion, beep tests are tough. Laughing
The last post was made 6 years, 204 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.45 - MySQL Queries: 17 - Page Size: 135.85 Kb
