kramdra |
kramdra World Chat Champion
Posted: 14:57 - 08 Sep 2017 Post subject: Throttle grip glue |
That embarrassment as I pass somone at 120 then two minutes later they see me roll to a stop and change my throttle grip at the side of the road It happens to me quite often.
I need a better glue. I've tried many, each will last for 3-6 months. Needs to be good with the temperature of heated grips as I will be using them soon. |
supZ |
supZ World Chat Champion
kramdra |
CaNsA |
CaNsA Super Spammer
chris-red |
kramdra |
mudcow007 |
mudcow007 World Chat Champion
Posted: 17:04 - 08 Sep 2017 Post subject: |
My heated grips are held on with hairspray. All the grips on both my and my wifes bikes are. That's 5 bikes currently. So the question becomes what are you doing with your throttle?
Anyway. Gorilla glue (the clear, brown polyurethane stuff). Don't expect to get it off again. Ever. You'll be looking at buying a new throttle twist if the grip wears out. If you're very lucky, you might be able to cut the grip off in tiny pieces.
Degrease the twist grip and inside of the handgrip with a high flashpoint solvent.
Apply the glue thinly to inside of the grip with a stick, keeping it a good 10mm away from the cable end. Don't get it on your fingers or clothes, they will go black.
Slightly roughen the throttle twist with sandpaper and wipe it with a damp cloth (the glue needs moisture to start the curing process).
Fit the grip. Wrap string round and round it tightly along the full length. Do NOT fit the bar end weight.
After 2 hours remove the string. Cut off any excess that has frothed out from the inside with a knife. The fit the end weights.
Polyurethane glue cures solid but with a slight foaming/expansion. It'll fill all the gaps between the surfaces and will foam out of the end a little (hence the gap at the cable end). By compressing it with the string (You could use gaffa tape too I suppose), you make the bonding interface extremely tight, it expands less, thing higher density foam but it will still retain some flex. It might bulge the rubber grip up if you don't compress it as it's curing. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
MCN |
MCN Super Spammer
ADSrox0r |
ADSrox0r World Chat Champion
The last post was made 6 years, 231 days ago. Instead of replying here, would creating a new thread be more useful? |
