Trying to fit a 90's shifter. Am I being retarded?
apple tango
PostPosted: 13:31 - 09 Sep 2017    Post subject: Trying to fit a 90's shifter. Am I being retarded? Reply with quote
Afternoon,
I bought a 1990's shifter off Ebay as modern ones are bloody expensive..and I'm a tight arse.
I'm not sure if I'm being stupid or what, but the bolt which came with it seems way too long. Here are some pictures to explain.
Here is the shifter:
https://i63.tinypic.com/fc412q.jpg
This is the clamp thing the bolt screws into:
https://i66.tinypic.com/2qmkhw0.jpg
Holding the shifter against the clamp:
https://i68.tinypic.com/30nb420.jpg
That's where the bolt goes in:
https://i64.tinypic.com/34e5jtl.jpg
Here is the bolt screwed in. As you can see it's way too long:
https://i64.tinypic.com/2myupg1.jpg
https://i65.tinypic.com/20kanbl.jpg
Pretty sure this isn't right.
So, am I being stupid somehow, or do I need to cut the bolt down? Which I can't be bothered to do tbh. I've tried adding loads of washers, but that hasn't worked either.
CBR125 -> Bandit GSF600 '99 -> SV650 02
UnknownStuntm...
PostPosted: 13:37 - 09 Sep 2017    Post subject: Reply with quote
Not the original bolt. Cut it down to size. EDIT: actually, you probably won't get enough torque on that one, get a hex head with the same thread. About 6-8Nm is right for handlebarish stuff, and you'd have to be lucky and quite meathanded to get that into a standard machine screw, like what you got there.
apple tango
PostPosted: 14:02 - 09 Sep 2017    Post subject: Reply with quote
Thanks.
I bought some hex head bolts today which fit perfectly, however there isn't enough room to fit a spanner or socket wrench into where the head of the bolt sits:
https://i65.tinypic.com/1izgag.jpg
PostPosted: 14:03 - 09 Sep 2017    Post subject: Reply with quote
Agreed. Change it out for a button head or socket head cap screw of an appropriate length. Looks like an M6.
apple tango
PostPosted: 17:04 - 09 Sep 2017    Post subject: Reply with quote
Thanks. Bought a pack of button head ones but it's slightly too long so I've ended up cutting it down. Hopefully will do the trick!
UnknownStuntm...
PostPosted: 20:20 - 09 Sep 2017    Post subject: Reply with quote
Yeah, that's what I meant by hex head, as in hex key. Good show.
155mph
PostPosted: 14:41 - 11 Sep 2017    Post subject: Reply with quote
Without stating the obvious, have you checked that the ratchet system is operating OK? Usually that is what goes bust. Also that shifter only appears to be rated for 8-speed cassette.
The last post was made 9 years, 46 days ago. Instead of replying here, would creating a new thread be more useful?
Post new topic   Reply to topic    Bike Chat Forums Index -> The Cycling Forum All times are GMT + 1 Hour
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.6 - MySQL Queries: 13 - Page Size: 53.02 Kb
