MORTYandrick |
 MORTYandrick Banned
 Posted: 18:40 - 09 Sep 2017 Post subject: |
Not really.
In most cases, there is only a single cable/strap going between the battery negative and ground, all the other companants earth through the frame. So for a continuity test, the battery need not be connected.
The answer is in the question really. You are checking "continuity to ground" and the whole frame on a bike is "ground". So you are checking for continuity between the measuring point and any piece of bare metal on the engine or frame rather than the battery negative. (the metal facing of the ignition lock is a good one. I usually stick the negative terminal of my meter in the key "gate")
A simple visual inspection will normally tell you if the battery to ground connection is good. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
Pete. |
 Pete. Super Spammer
 Posted: 19:50 - 09 Sep 2017 Post subject: |
I check fuel injectors with a PP9 battery. Pull the injector, put a couple of wires on the terminals and then to the battery. It'll click and the pintle will pull in if it's working. ____________________ a.k.a 'Geri'
MORTYandrick |
 MORTYandrick Banned
Islander |
 Islander World Chat Champion
 Posted: 21:24 - 09 Sep 2017 Post subject: |
It suggests that the body of the injector is electrically isolated from the terminals so there is no continuity to ground from either terminal. That sounds ok to me but I'm not an expert.
However there is resistance between the terminals and that's where the current would flow - into one and out of the other. Again, that sounds ok to me.
What does the test procedure expect to find for a good injector?
Pete's suggestion for testing the injector is a good one - he knows what he's talking about.  |
MORTYandrick |
 MORTYandrick Banned
Islander |
moonzoomer |
 moonzoomer World Chat Champion
MORTYandrick |
 MORTYandrick Banned
 Posted: 22:50 - 09 Sep 2017 Post subject: |
Stinkwheel much love I was touching on the shiny frame was grey so I was deceived. It worked with ignition and some other bolt.
Also it says in the manual- I'll type below that shouldn't be grounded
Islander This is my injector.
The manual says:
After checking resistance between terminals (was 10.3 ohms all good as in spec) ,
Check there is no continuity to earth on the black/white terminal on the injector.
So I put the leads on those pins you see inside in the pic. ____________________ Keep it concise. |
Pete. |
 Pete. Super Spammer
 Posted: 23:11 - 09 Sep 2017 Post subject: |
The two pins in the injector are simply either end of a solenoid pull-in coil (because that's all an injector is - a solenoid with a needle valve on the end). When you energise the coil it pulls the armature in and open the injector. I never saw one that had continuity to ground/the body and if it did then it would cause a short if it were ever wired backwards which is a hazard for a fuel system part so I doubt that there are any. ____________________ a.k.a 'Geri'
MORTYandrick |
 MORTYandrick Banned
Islander |
MORTYandrick |
 MORTYandrick Banned
 Posted: 14:12 - 10 Sep 2017 Post subject: |
Oh my goodness, I think it's making sense now- I crawled to this point not really knowing what was going on but understanding pieces of comments.
I think I also misunderstood everything:
Stinkwheel: In the back of my mind I was thinking but "why is chassis ground it's just a piece of bloody metal" but I realise the last bit of your first post is just as important.
what you meant was:
All we want to test is connection to chassis is good.
By that visual check When we reconnect the battery to chassis- the chassis will be grounded.
By transitivity the connection to ground of everything will be good.
My last questions on this bit is:
1)
How can we visually check the battery connection to chassis is good visually without the multimeter?
2) what if you have some sort of crash and there's damage to the chassis and now some bits of go missing or something and not all of the chassis is interconnected so causes electrical issues- how can it
be diagnosed? (sorry if this is far fetched and the chassis is too solid for this to ever happen...)
3) when I have to "check the battery voltage at the black/white wire terminal in the wiring connector now the battery must be connected right?
To Islander I'm so stupid- I got mixed up with the terms the manual was using.
Could you please clarify the following is right:
1) the injector body is the first two pics
2) The injector terminals are the pins in the second pics.
3)The wiring terminal are the pins in the wiring connector in the last pic.
Assuming that's alright.
I very stupidly was connecting 2) to chassis instead of 3) to chassis because I was mixed up with 2) and 3). I really don't know what I was thinking when obviously it would infinite resistance with a disconnected injector
Oh and I also forgot to add I was supposed to be doing this with the wiring connector disconnected from the the injector.
When you were saying "It suggests that the body of the injector is electrically isolated from the terminals"
You obviously assumed the injector body was connected to the engine right?
If I had told you also I took the injector body was also removed from engine then that suggestion would not have been true would it? ____________________ Keep it concise. |
Pete. |
 Pete. Super Spammer
 Posted: 16:49 - 10 Sep 2017 Post subject: |
Exactly what problem are you trying to fix? It sounds like you're trying to go too deeply into things that probably have no fault at all. ____________________ a.k.a 'Geri'
MORTYandrick |
 MORTYandrick Banned
 Posted: 17:31 - 10 Sep 2017 Post subject: |
I am trying to fix nothing. I am trying to learn- these are all checks to make in the manual IF something is wrong.
Look at my profile  ____________________ Keep it concise. |
Pete. |
 Pete. Super Spammer
MORTYandrick |
 MORTYandrick Banned
Pete. |
 Pete. Super Spammer
MORTYandrick |
 MORTYandrick Banned
 Posted: 18:36 - 10 Sep 2017 Post subject: |
I didn't imply there was ever a problem I didn't say this this or this isn't working-it's not like I tried to deceive anyone- sorry if it seemed that way - wrong way to phrase it in the quote then?
All I'm going through are checks through my manual. Why the hostility?
The only time when I can look into it is when the bike stops working and I have no choice cos I'm stuck?
I confessed I had little clue. That's the whole point of coming to the Workshop isn't it? You didn't have to say that directly.
How is it idle curiosity?
Really didn't expect that reply... ____________________ Keep it concise. |
Islander |
MORTYandrick |
 MORTYandrick Banned
 Posted: 19:45 - 10 Sep 2017 Post subject: |
cheers very much for the answer
peace out. ____________________ Keep it concise. |
neptune8 |
 neptune8 Nova Slayer
MORTYandrick |
 MORTYandrick Banned
Pete. |
 Pete. Super Spammer
 Posted: 19:26 - 11 Sep 2017 Post subject: |
Of all the things on a bike or fuel system that could go wrong, the injector must be just about last on the list. It's one of the most reliable components you could find on a bike. ____________________ a.k.a 'Geri'
The last post was made 7 years, 301 days ago. Instead of replying here, would creating a new thread be more useful? |
