AndyJay |
AndyJay L Plate Warrior
yen_powell |
yen_powell World Chat Champion
Copycat73 |
Copycat73 World Chat Champion
Kawasaki Jimbo |
Pete. |
Pete. Super Spammer
Posted: 18:47 - 11 Sep 2017 Post subject: |
It's more than likely the relay for the fuel pump immobiliser circuit failing. Get in there and bypass it before it leaves you stranded. ____________________ a.k.a 'Geri'
Rogerborg |
Rogerborg nimbA
Kawasaki Jimbo |
Posted: 20:33 - 11 Sep 2017 Post subject: |
It was my own bike, honest. It is shockingly easy to do. In fairness it takes a while and special tools to get into the case, and unless you're the owner it'll likely be wailing like a banshee throughout. I know you know the website, I'm just wary of broadcasting it. I'm surprised there are any System 3s still alive. |
Pete. |
Pete. Super Spammer
Posted: 20:40 - 11 Sep 2017 Post subject: |
All you need is a battery drill and a few small drill bits. Just make out you're going to drill out the screws and the drill will catch the security pip and snap it off. Sometimes the drill snaps. Once the pip is out use a standard torx bit to remove the screw.
After that, follow the attached PDF to bypass the relays. Just un-plug the big connector to kill the whole alarm and join the pairs of wires in each of the two immobiliser circuits. ____________________ a.k.a 'Geri'
Rogerborg |
Rogerborg nimbA
Posted: 22:23 - 11 Sep 2017 Post subject: |
Kawasaki Jimbo wrote: | I know you know the website, I'm just wary of broadcasting it. |
Well, let's keep it between you, me, anyone who can Google, or who reads the post between ours. ____________________ Biking is 1/20th as dangerous as horse riding.
AndyJay |
Pete. |
Pete. Super Spammer
Posted: 23:58 - 11 Sep 2017 Post subject: |
You can't fix 'em and parts haven't been available for years now. It's not the bike's fuel pump relay that fails it's the little relay inside the alarm that switches the circuit.
I've had two go wrong and I had to rescue Kris when his went wrong too. When I got stranded I talked to a tech at Datatool who said that the liquid can leak out of the ball that senses movement (inside the potting on the board) but I believe at least one of mine was a joint on the board because it would work if you twisted the board slightly.
Do yourself a favour and get it bypassed and disabled before it leaves yo stranded somewhere. ____________________ a.k.a 'Geri'
sickpup |
sickpup Old Timer
Pete. |
Pete. Super Spammer
Posted: 05:42 - 12 Sep 2017 Post subject: |
It was Kris that had the failed relay and yes it did pack in whilst he was riding. Wasn't the fuel pump though as his bike was carbed.
Fuel pump not priming is a sign of a fault/not ready condition on the FI system, it need not be wired into the actual fuel pump relay. On a Suzuki for instance, the fuel pump wont prime if the RUN switch is off. ____________________ a.k.a 'Geri'
weasley |
weasley World Chat Champion
Rogerborg |
Rogerborg nimbA
sickpup |
sickpup Old Timer
supZ |
supZ World Chat Champion
AndyJay |
MORTYandrick |
MORTYandrick Banned
Pete. |
Pete. Super Spammer
Posted: 20:34 - 12 Sep 2017 Post subject: |
The fact that there are still units working doesn't alter the fact that their failure rate is high. In my case I've had 2 - both failed. Kris had one - failed. A guy on the 'busa site couldn't get his bike started up in the city. I went to look at it - Datatool failed. Several members on here have had them fail.
Anyone need a spare fob to program? I've got a few somewhere. I should hang them on the wall like spitfire pilot swastikas to record dead Datatools. ____________________ a.k.a 'Geri'
sickpup |
sickpup Old Timer
Rogerborg |
Rogerborg nimbA
sickpup |
sickpup Old Timer
weasley |
sickpup |
sickpup Old Timer
The last post was made 6 years, 219 days ago. Instead of replying here, would creating a new thread be more useful? |
