Nsr125 just purchased with crank case full of mystery fluid
Bike Chat Forums Index -> General Bike Chat Goto page Previous  1, 2, 3
stirlinggaz
PostPosted: 14:14 - 23 Sep 2017    Post subject: Reply with quote
spitfire123 wrote:
One of the reeds on the block (middle one out
Of 1 side of the bank) wasnt sealing 100% , so I've flipped them over . Seem a bit better, But can't see this being the cause ?
I've also just looked at the price of starter motors
There like £100 plus !
Hi,
I have found, the once the thin, brittle reeds get damaged, it'll never run right again.
Replace with a decent c/f set. No need to go all big brand expensive (like v3 or v-force or whatever they're called) I went with the ones Alain (bcf resident nsr guru) recommended, on both my jc22's.
starter motor is common weak point (along with most of the electrics tbf) but they can be refurbished.....but depends on what condition it's in.....open it up (starter motor) & have a look?
Won't do any harm, especially if you've prepared yourself for coughing up 130 quid they cost to replace.
Sorry, not actually helping much am I?.......al get ma coat.....
cheers,
GAZ
ThoughtContro...
PostPosted: 14:59 - 23 Sep 2017    Post subject: Reply with quote
Take it out and check it turns over when connected straight to the battery. I had shitty corroded wiring in the last few inches of the starter motor cable which acted like a high resistance drop that just made the solenoid click.
If it is the motor, it's likely just the brushes, which should be cheap enough to replace, if that is what it needs. The commutator might just need cleaning and any carbon dust blowing out.
Prize cunt
spitfire123
PostPosted: 16:54 - 23 Sep 2017    Post subject: Reply with quote
Right
Took the start motor out
Had it apart , replaced the brushes and it now works
, after swapping the reeds round it started then cut out but starts more often now than before
Then cuts out
So I'm assuming reeds ?
Fucking thing
You won't be able to eat my dust......As it'll settle before you get there.
spitfire123
PostPosted: 16:58 - 23 Sep 2017    Post subject: Reply with quote
https://www.ebay.co.uk/i/391535362862
There the only reeds I can find that are a reasonable price
Rest are £40 odd quid!
Probabllem is there from z Germans so it's going to be atleast a week for delivery Crying or Very sad
spitfire123
PostPosted: 18:49 - 23 Sep 2017    Post subject: Reply with quote
Hi,
Who's this nsr guru?
cheers,
GAZ
spitfire123
PostPosted: 23:18 - 24 Sep 2017    Post subject: Reply with quote
Reeds and carb orderd
Watch this space
stirlinggaz
PostPosted: 18:24 - 26 Sep 2017    Post subject: Reply with quote
Hi,
Alains. French nsr dude.
Wrote a very helpful guide ("nsr tips") which I recommend every nsr owner download.
He's a member on here & tbh, I'm surprised he hasn't posted/replied sooner, he usually does.
cheers,
GAZ
spitfire123
PostPosted: 23:15 - 26 Sep 2017    Post subject: Reply with quote
stirlinggaz wrote:
Hi,
cheers,
GAZ
Hopefully he comes along soon .
Update
Replaced reeds with upgraded carbony ones .
Made fek all difference !
Got a 2nd hand carb comming in post to try , if that doesn't work , I'm at a dead end !
Spit
skatefreak
PostPosted: 09:05 - 27 Sep 2017    Post subject: Reply with quote
Just for future reference... these bikes bump so easily you wouldn't believe.
My starter crapped out on me and I just bumped it for about a year Rolling Eyes.
Got it down to two steps and Bosh ring'a ding ding ding Laughing (sounds nothing like an NSR I know...)
spitfire123
PostPosted: 14:37 - 27 Sep 2017    Post subject: Reply with quote
It's in the workshop so abit hard for me Laughing
I re-built the starter anyways Thumbs Up
spitfire123
PostPosted: 13:17 - 28 Sep 2017    Post subject: Reply with quote
Update
Carb fitted , ran for 15 seconds this time , cut out , same problem.
Have now noticed the plug has an irregular spark, Cdi ???
skatefreak
PostPosted: 09:53 - 29 Sep 2017    Post subject: Reply with quote
Mak sure you get that new reed tested before spending more monies.
Without it sealing you will be losing pressure in the crank case and it will mess up the flow through the engine/ports causing who knows how much trouble...
Irregular spark could be coil, ht lead, cdi etc.
Get a multi meter in there to get an idea of whats going on where...
Have only really played with the charging side so can't be of much use tbh but I would expect resistance on HT lead, check for impulse from cable going to coil, resistance through coil?
spitfire123
PostPosted: 20:48 - 11 Oct 2017    Post subject: Reply with quote
Update
Changed stator and pickup , Cdi and plug
It ran well for the 1st 30 seconds or so then died , as if the kill switch was pressed.
Now starts more easily but hasn't solved the problem
I've now got a doner engine
I'm thinking I'll just chuck that in and give it a go ?
Out of ideas
The reefs did fuck alll
secretagentmo...
PostPosted: 16:06 - 12 Oct 2017    Post subject: Reply with quote
spitfire123 wrote:
Update
Out of ideas
How will replacing the mechanical parts fix an electrical problem?
The last post was made 6 years, 198 days ago. Instead of replying here, would creating a new thread be more useful?
Page 3 of 3
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.16 Sec - Server Load: 0.61 - MySQL Queries: 16 - Page Size: 90.12 Kb
