Posted: 13:29 - 14 Sep 2017 Post subject: Fabricating mudguard stays? What from? |
I'm going to be making my own stays to fit alloy mudguards to my latest enfield project. mainly because they would cost around £70 to buy (each end) and to hell with that for a bit of bent steel tube.
Pretty much just a piece of steel tube bent into a U-shape with the ends flattened out and bolted to some captive lugs on the forks. It's not going to be particularly load bearing although the rear ones should be able to cope with a small luggage rack being bolted to the mudguard/stays with a tent/drybag on it. The front ones act as a slight fork brace in place of a heavily braced steel mudguard (hence the U-shape rather than some bits of flatbar).
I can borrow/hire a pipe bender for the day to make the shapes and I can amateurishly splatter-weld the lugs on to attach the mudguards themselves.
Two main questions really:
1) I'm not au-fait with the various grades of steel/iron tubeavailable. I can collect pretty much any length, size and grade from my local steel stockholders but they do like you to know exactly what you're ordering. Probably wants to be around 15mm OD but what grade and wall thickness should I ask for?
2) The ends. Is there a "proper" way of dong this? Should I just be flattening them in a vice and drilling holes. Or hammering them flat? Or is it more refined than that? I pictured crushing it using a bit of steel rod along one side in the vice so it has a flat back and a slightly 'B' shaped profile on the front?
Or should I make some lugs from flatbar and weld them into the ends of the tube? ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
MCN |
MCN Super Spammer
Ariel Badger |
Ariel Badger Super Spammer
Wheezybiker |
Wheezybiker Nitrous Nuisance
lingeringstin... |
lingeringstin... Trackday Trickster
Ariel Badger |
MCN |
MCN Super Spammer
The last post was made 6 years, 225 days ago. Instead of replying here, would creating a new thread be more useful? |
