rudyperon |
rudyperon L Plate Warrior
kramdra |
kramdra World Chat Champion
Posted: 23:27 - 19 Sep 2017 Post subject: |
Yes, I've straightened many levers but it needs to be done carefully and with knowledge of the metallurgical consequences of doing so.
You need to heat it to within a ballhair of molten so the metal becomes plastic. You re-bend it once and once only, don't try for perfection.
Then you need to heat the metal to near plasticity and slowly cool several times to re-anneal it becaue it has effectively been cold-worked.
If you rub soap on the metal. It'll burn to carbon. When the carbon starts to burn off, you are pretty much at the correct temperature.
After having done all this, I then try to break it.
Replacement Brembo levers are £35. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
c_dug |
c_dug Super Spammer
Posted: 16:06 - 08 Oct 2017 Post subject: |
Sorry to dig up a dying thread, but I had a go a straightening my clutch lever today, with surprising results in both success and colouration:
https://i.imgur.com/gNlpkSJ.jpg
Just thought I'd share. ____________________ I am a bellend, I am a man of constant sorrow, I am a gummy bear, I am a rock. |
Tankie |
Tankie Crazy Courier
The last post was made 6 years, 199 days ago. Instead of replying here, would creating a new thread be more useful? |
