91 ZZR 600: rear hub/wheel/swing arm affair
Ayup_Mi-Duck
PostPosted: 20:07 - 17 Sep 2017    Post subject: 91 ZZR 600: rear hub/wheel/swing arm affair Reply with quote
Hi there guys.
Could someone please tell me what could have happened here?
the wheel had cocked over to the side and the sprocket bolts have machined out a bit of the swing arm.
think this is just the bearing shitting its pants or could it have been something else?
Im a bit fucked off Sad[/img]
Pump, Pump, Squirt.
RhynoCZ
PostPosted: 20:13 - 17 Sep 2017    Post subject: Reply with quote
What happened there is, that photobucket changed their policy, so now you have to pay them, so you can post your pictures here. Thumbs Up
johnsmith222
PostPosted: 20:14 - 17 Sep 2017    Post subject: Reply with quote
your links need sorted. I think that link would let me upload pictures to your profile for lolz.
I accessed the pictures anyway.
Yup, your bearing has shat it, causing the wheel to sit at an angle.
There's a "tube" that goes between the bearings. This will have been at an angle due to bearing shitting it.
Replace all bearings on the rear wheel, inspect surfaces and you'll be fine.
Ayup_Mi-Duck
PostPosted: 20:21 - 17 Sep 2017    Post subject: Reply with quote
Thank you for the help. its never ending faff lol.
fortunatly i had just been to skeg to get some fish and chips and look at the monsters. managed to get to about 2 miles away from home and it started ticking (eating its slef)....
Thanks again for your help.
Pump, Pump, Squirt.
johnsmith222
PostPosted: 20:25 - 17 Sep 2017    Post subject: Reply with quote
No problem, now I have looked at this post again though, I need to double-check things, especially as I've just read your swingarm being chewed by the sprocket bolts.
johnsmith222
PostPosted: 20:30 - 17 Sep 2017    Post subject: Reply with quote
While you have the wheel off, check the rear wheel bearings. Those are the bearings that are still attached to the wheel.
If suspect on a bike that age, you might as well replace them. It's these bearings that have a tube between them.
The part that you actually show in your pic is the sprocket carrier bearing. It looks like it's actually this bearing which has killed itself. I can't confirm the condition of the rear wheel bearings.
If i remember correctly, there is a spacer which slides into the sprocket carrier bearing, and sigs against the wheel bearing. Check this is present.
Also, there should be a spacer on the outside of the sprocket carrier, between the swingarm and the outside of the sprocket carrier.
If you have any spacers missing. Get them from cornwall kawasaki.
Any bearings you could get cheaper from wemoto etc.
johnsmith222
PostPosted: 20:35 - 17 Sep 2017    Post subject: Reply with quote
https://imgur.com/a/EWLpM
ive added a black number 1 - this is the spacer that slides into the sprocket carrier bearing.
2 - outside spacer
3 - sprocket carrier bearing.
Ayup_Mi-Duck
PostPosted: 20:40 - 17 Sep 2017    Post subject: Reply with quote
I think you might be on to somethign there. Now I think about it, the wheel was sitting true but the carrier was cocked over/ hanging out.
I replaced the tyre a while back and when removing it, laid the parts out as they came off, i then put them back on as they were. I think I will just buy all the parts, clean it up, give it the lube and see how it goes... hope its not spragged the swing arm out....... that would be mega lolz....
Pump, Pump, Squirt.
skatefreak
PostPosted: 09:43 - 18 Sep 2017    Post subject: Reply with quote
Pix?
Saw a hub carrier eat it's way through a swing arm at a track day... Could have some serious effects of the structural integrity of the swing arm itself...
The last post was made 6 years, 222 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.25 - MySQL Queries: 17 - Page Size: 65.05 Kb
