kramdra |
kramdra World Chat Champion
Posted: 22:07 - 18 Sep 2017 Post subject: Wheel bearings, fitting, last tap? |
One side is already in, the spacer is in and there is 0.5-1mm gap between the inner race and the spacer. One tap will get it done. Too little, it wont budge. Too much and the outer race is skewed with excessive preload on the inner race. If too much the race will need to be knocked out and should be replaced I did get them about right, tighter than I'd like but it will do. Any tips to prevent this? I was thinking that four equal thickness 0.2 or 0.5mm feeler gauges could shim the gap, tapped in and then pulled out to get the correct clearance. Or drive it in with a large screw and nut. I have tried this and usually goes off center.
Thanks |
temeluchus |
Matt B |
Matt B World Chat Champion
kramdra |
smallfrowne |
smallfrowne Scooby Slapper
Posted: 14:05 - 19 Sep 2017 Post subject: |
When you're pressing it in with threaded bar/screw and a nut, when does it go wonky? I've whacked bearings with a hammer until they were far enough in that they didn't go wonky when I switched to a press (vice, threaded bar).
But yeah temporary shimming seems like an ok idea, but you still have to wiggle the spacer to test it anyway so it's still trial and error, ie tighten press a bit/tap with the lump hammer, check it, tighten it a smidge, check it... think ah shit, oops, that'll probably be ok won't it, will it? hmmm. And call it a job jobbed . Shims might stop you from going too far I suppose. ____________________ '90 VFR750; '89 NC30; '95 DR650; '89 CD250U; ~'82 CG125; ~C90 |
The last post was made 6 years, 221 days ago. Instead of replying here, would creating a new thread be more useful? |
