Sun Wukong |
Sun Wukong World Chat Champion
CaNsA |
CaNsA Super Spammer
pompousporcup... |
Loui5D |
Loui5D Brolly Dolly
Sun Wukong |
pompousporcup... |
pepperami |
pepperami Super Spammer
Sun Wukong |
Posted: 16:33 - 19 Sep 2017 Post subject: |
Robby fiddled a lot with carbs to sort out balance. Have been looked at many time.
One float valve was sticking so I fiddled with it a lot and got it pinging nicely, but a concern.
Float heights have been changed by both Robby and I, I will be checking those when I strip her tomorrow.
I've come dangerously close to checking the clearances many times, but have been dissuaded every time by friends helping me. Thing is its shims, so I think no one wants to hel if it needs it its only got 23k and more than potent once actually going so unlikely to be them - but annoying I can't state definitively.
Any electrical causes? ____________________ Top cat
"Hard times lead to hard people. Hard people lead to good times. Good times lead to weak people. Weak people lead to hard times." Smegballs
"Oh and STE balloons would be one of the nicer things we would receive at the office, the amount of dog turd in jiffy bags is not funny." Jsmith86 |
Sun Wukong |
nowhere.elysium |
nowhere.elysium The Pork Lord
Posted: 16:44 - 19 Sep 2017 Post subject: |
Sun Wukong wrote: | I've come dangerously close to checking the clearances many times, but have been dissuaded every time by friends helping me. Thing is its shims, so I think no one wants to hel if it needs it its only got 23k and more than potent once actually going so unlikely to be them - but annoying I can't state definitively.
Any electrical causes? |
Shims are a bit of a pain, but not that big of a deal to work with.
Realistically, at 23K it shouldn't be anywhere near far enough out of spec to cause idle failure.
Electrical is highly unlikely - you'd be seeing other things going wrong before that would be the best option.
Have you replaced the vacuum line? Repairs of such things typically aren't worth the hassle, least of all, given that a vacuum line is usually under three quid. Also, are the inlet rubbers in good nick? ____________________ '10 SV650SF, '83 GS650GT (it lives!), Questionable DIY dash project, 3D Printer project, Lasercutter project |
chris-red |
Sun Wukong |
nowhere.elysium |
bypass2 |
bypass2 Spanner Monkey
Nobby the Bastard |
bypass2 |
Sun Wukong |
Posted: 09:39 - 20 Sep 2017 Post subject: |
pompousporcup... |
Nobby the Bastard |
pompousporcup... |
Sun Wukong |
Sun Wukong |
Posted: 17:29 - 20 Sep 2017 Post subject: |
Videos uploaded
Started on button first time from cold (not used since Monday ie 48 hours plus)
Vid 1 here
Some sweary so careful at work.
Does not start again after letting it bog out, which is what it does on the road too (ie when warm). At roundabouts/traffic lights etc, throttle must be blipped slightly to keep her going.
After video cuts off, I went outside to not die from fumes. Came back one minute later and she started first time. Choke on full, and after some time eventually would stay on the choke without me blipping the throttle.
Vid 2 here
Warmed up enough to have filled the shed with much non-air, stalls as soon as choke is turned off.
As mentioned in vid and normally, turning the idle speed up sadly is not the answer... although it is damn tempting I admit. When I do that, about 15 minutes after setting off she is revving very high and being a dick going in to roundabouts etc.
This was the initial state of play some time ago.
https://www.bikechatforums.com/viewtopic.php?t=320727
Fixing airleak in vacuum hose, removing scottoiler, new sparks and air filter, balancing carbs and further fiddling with float height etc helped it a lot.
This cut out thing is new, and frustrating. ____________________ Top cat
Teflon-Mike |
Teflon-Mike tl;dr
Posted: 18:44 - 20 Sep 2017 Post subject: |
I tappets have never been done, and from memory the GS uses old fashioned screw and lock-nuts that are easy to 'do' but awkward to get at, and need doing often... then tryng to dodge that issue looking for carb issis is a bit of an ostritch act, to my mind, looking for more convoluted jobs and fixes to avoid the easy and obvious!
Bite the bullet.. tickle tappets.. THEN see whats what. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
Nobby the Bastard |
Sun Wukong |
The last post was made 6 years, 211 days ago. Instead of replying here, would creating a new thread be more useful? |
