jpno5 |
jpno5 Borekit Bruiser
A100man |
A100man World Chat Champion
jpno5 |
Teflon-Mike |
Teflon-Mike tl;dr
Posted: 13:46 - 23 Sep 2017 Post subject: |
Err.. sorry, but I have to comment on the incongruity.. on post in reply to Snod Blatter about using a remote-start enabled alarm in substitute for a Key & Barrel ignition switch, you suggest using an extremely complicated hobby-board solution involving a wi-fi enabled strawberry waffle!!! YET are baffled by a simple side-stand cut-out switch?!?
Could it be you are you some-what over thinking problems a little? ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
jpno5 |
Posted: 23:59 - 25 Sep 2017 Post subject: |
haha i did say i know next to nothing about electrics, i'm a programmer, i've also done a bit around the house in regards to home automation with relays, bypassing everything on the bike would be easy. I'm not baffled by the switch as such, it's where the fault seems to lie.
just trying to understand if there was anything more to it as it doesn't seem to operate in a way i would expect, i.e bypass the switch, join the wires, start the bike(bump), disconnecting the wires whilst the bike is running, even reconnecting them the bike does nothing. i would expect it to cut out. which makes me think there's an issue further up in the loom. if you know the expected behaviour feel free to chip back in dude
The switch could potentially work in other ways which are pretty common, like i mentioned in a post, send a signal to the cdi in which that holds a binary value as to whether the switch is on or off and that sends the signal once the start button is pushed. That's theoretically a way in which it can be done. I don't know much about bikes hence the reason i'm trying to understand their setup. |
Posted: 00:25 - 26 Sep 2017 Post subject: |
There are usually three switches in a safety cut-out system.
Stand, Clutch and Neutral.
The engine will run in any one of these three conditions: Stand up, Neutral engaged, Clutch in.
As soon as you engage a gear and try to let the clutch out, with the stand down, it'll cut the spark.
Is a very simple logic circuit, done entirely electrically.
In the most common case, there is a circuit on the CDI that needs to be earthed in order to allow the bike to run. It can earth either through the sidestand switch in the UP position, the neutral switch in the on position or the clutch switch in the pulled in position.
These switches are also involved in the starter motor lockout on most bikes.
As I hope you've gathered. the sidestand switch is usually open when down and closed when up.
Messing with that switch and the wires connected to it will do nothing if you're in neutral. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
WD Forte |
WD Forte World Chat Champion
temeluchus |
The last post was made 6 years, 231 days ago. Instead of replying here, would creating a new thread be more useful? |
