Wheezybiker |
Wheezybiker Nitrous Nuisance
Rogerborg |
Rogerborg nimbA
Posted: 16:39 - 08 Oct 2017 Post subject: |
They are fairly important, but getting within a couple of PSI (indicated) will be fine given the vagaries of gauges and that the pressure will change with temperature anyway.
You'll be amazed how flat a bike tyre can get before it shows any signs, and what you can get away with riding on. It's only when you sort the pressure that you realise how badly the bike's being handling. ____________________ Biking is 1/20th as dangerous as horse riding.
Wafer_Thin_Ham |
Wafer_Thin_Ham Super Spammer
Courier265 |
Courier265 World Chat Champion
NJD |
NJD World Chat Champion
Posted: 17:47 - 08 Oct 2017 Post subject: Re: Tyre pressures |
Wheezybiker wrote: | Are valve caps that change colour if pressure is wrong accuratelymade or just a gimmick |
Probably a gimmick. I suspect your slightly overthinking the entire thing.
Go down to Argos and get yourself a track pump. This model looks to be the replacement for the one I have. You can buy any, of course, but either way for the return I've got out of mine whatever I paid for it was worthwhile. The longest part about the job is getting the valve's in the right place to get a secure and easy-on easy-off to pump them up. One big push should be more than enough.
I hadn't used my bike for almost two weeks and found very little variation in the reading when compared to topping them up daily. I did accidentally go for a ride the once without pumping them up and instantly noticed the difference: it could have been that the tyres under inflated and not warmed up was what I was actually noticing and would have been, theoretically, fine when warmed up but pumping them up daily keeps me happy from the get go.
Do keep in mind, though, that the U.K roads are not like a freshly tarmacked Module 1 test pad. There's certain roads I use that, from time to time, make me thing I've got a puncture or alike and then have to slap myself post-ride for remembering what route I had just taken.
Same as checking all the lights function before riding: takes moments to do so is worthwhile.
I wouldn't bother with garage tyre machines. I used to use one but found that it often left me with more problems than it did solve. I found other people like to damage the machine on a regular basis; I wouldn't trust others looking after the machine that dictates part of your safety on the road one ounce. ____________________ The do it all, T̶h̶e̶ ̶b̶r̶o̶k̶e̶n̶ ̶o̶n̶e̶,̶ ̶T̶h̶e̶ ̶b̶i̶g̶ ̶l̶u̶m̶p̶,̶ ̶C̶h̶o̶n̶g̶ ̶N̶o̶o̶d̶l̶e̶ |
Beehive Bedlam |
SophR so good |
SophR so good Trackday Trickster
Wheezybiker |
Posted: 18:26 - 08 Oct 2017 Post subject: |
Thanks for the replies
I am obviously overthinking it
I have track pumps and am quite happy to pump them up as required I was more interested in gauges and there accuracy and whether for example if I lost a 1 or 2 psi it would mean big problems in handling etc
Thanks again for the replies my mind is more at ease and I'll concentrate on riding |
M.C |
M.C Super Spammer
NJD |
recman |
recman World Chat Champion
The Shaggy D.A. |
The Shaggy D.A. Super Spammer
Posted: 19:12 - 08 Oct 2017 Post subject: |
You can usually feel it if they need attention. Tyres are only going stay the same or go down - if it starts feeling vague or soggy, it's time to put air in. ____________________ Chances are quite high you are not in my Monkeysphere, and I don't care about you. Don't take it personally.
trevor saxe-coburg-gotha |
RhynoCZ |
RhynoCZ Super Spammer
ThatDippyTwat |
Freddyfruitba... |
Tracer1234 |
Tracer1234 World Chat Champion
RhynoCZ |
andym |
andym World Chat Champion
Posted: 05:45 - 09 Oct 2017 Post subject: |
Tracer1234 wrote: | Possibly, / highly likley a stupid question. Does one go by the recommenced pressure on the type itself, or the bike manufactures? |
Depends on the bike, the tyre and the terrain imo. I usually go by the handbook - but e.g. my cb500 with Avon Ditch Finders oops sorry Road Riders would probably be "perfectly" "fine" at 29 front 33 rear. However, put some vaguely acceptable tyres on them, like Michelin Pilot Activs and Leeds Tyres will fit them with 36 psi front and back. I prefer 34 front and back. Run them at 29/33 and they will feel garbage.
On my KLX 24 psi front and back will be okay for a roughly speaking road orientated tyre, but then a bit soft for something like, say, a Michelin AC10. However, once you get into mud, that feels too hard so you might want to let a fair bit out. ____________________ "Life is a sexually transmitted disease and the mortality rate is one hundred percent."
Mobylette Type 50 ---> Raleigh Grifter ---> Neval Minsk 125 |
The Shaggy D.A. |
johnsmith222 |
johnsmith222 World Chat Champion
TbirdX |
TbirdX Crazy Courier
Polarbear |
Polarbear Super Spammer
Posted: 16:38 - 09 Oct 2017 Post subject: |
I have remote reading tyre pressure senders on my Trophy which is nice (posh cunt me)
What I do find interesting is how much the tyre pressures rise when the tyre gets warm. I've seen an increase of 5 psi when hammering it and loading the tyres up.
Even just pootling around increases it a couple of psi from cold. ____________________ Triumph Trophy Launch Edition |
Tracer1234 |
The last post was made 6 years, 199 days ago. Instead of replying here, would creating a new thread be more useful? |
