Tyre pressures
PostPosted: 19:17 - 09 Oct 2017    Post subject: Reply with quote
Tracer1234 wrote:
Polarbear wrote:
I have remote reading tyre pressure senders on my Trophy which is nice (posh cunt me) Cool
What I do find interesting is how much the tyre pressures rise when the tyre gets warm. I've seen an increase of 5 psi when hammering it and loading the tyres up.
Even just pootling around increases it a couple of psi from cold.
does the reading come through to your phone, or something else.
No, its built into the bike. Comes up on the display when riding.
Triumph Trophy Launch Edition
Kawasaki Jimbo
PostPosted: 19:48 - 09 Oct 2017    Post subject: Reply with quote
Stick with what the tyre manufacturers websites recommend for your particular bike (they've mostly standardised at 36psi front, 42 psi rear) unless you're running the exact same tyres recommended by the bike's manual. My 2003 R1 has 36/36 in the manual but if more modern tyre construction relies on a rear pressure of 42psi to get the same profile and sidewall stiffness then running them at 36psi is like having a flat tyre. I stick with 36/42 on both bikes and then adjust the suspension if I don't like the comfort or handling.
Contrary to what you often hear I suspect that lowered pressures are not intended to achieve a larger contact patch. The track riders only do that because they anticipate increased tyre temperatures compared to road riding. Once the tyres on track are super hot they're back up to the same pressure as a road rider's, meaning that the profile, contact patch and sidewall stiffness is the same and is correct. Rossi-aping wannabees using the same low starting point on the road won't get up to a consistently high temperature, and thus won't reach the correct pressure or tyre profile. It's counter-productive.
Regarding tyre gauge accuracy, RIDE magazine occasionally survey the matter. Check on-line for past articles.
Ten years ago petrol station air lines with a bar meter on the nozzle probably were inaccurate. As soon as the nozzle and integral meter was dropped on the floor its accuracy was lost until the next calibration, if indeed it ever was re-calibrated. In this age of Health & Safety things will have changed.
As I have said before I run a petrol station. As a rule if you pay for your air then the machine is owned by an offsite company eg "airserve" what you are paying for is accuracy, and this is guaranteed by an audit trail. The parent company will service the air vend machine once a month and check the gauge is accurate up to the max working pressure of the pump. They then issue a certificate stating the date, time of test, who tested and machine serial number.
Source: https://forums.moneysavingexpert.com/showthread.php?t=4981572&page=2 2014.
t121anf
PostPosted: 21:14 - 09 Oct 2017    Post subject: Reply with quote
Any recommendations for a digital gauge, mines recently broke.
johnsmith222
PostPosted: 21:24 - 09 Oct 2017    Post subject: Reply with quote
Either a halfords cheapie, or something like the analogue gauge that venhill sell:
https://www.venhill.co.uk/media/catalog/product/cache/1/image/9df78eab33525d08d6e5fb8d27136e95/v/t/vt32_l.jpg
Courier265
PostPosted: 21:42 - 09 Oct 2017    Post subject: Reply with quote
Tracer1234 wrote:
Possibly, / highly likley a stupid question. Does one go by the recommenced pressure on the type itself, or the bike manufactures?
I go by the sticker on the chain guard, normally the pressure stated is actually spot on. HOWEVER when changing your brand of tyre you might have to play around with the pressures.
Fazer The Bastard wrote:
Courier265 wrote:
I check mine daily
Overkill. Rolling Eyes
Weekly checks will be fine.
oh yes well commuters don't need to check them daily.... in my line of work daily is NOT overkill.
B0ndy
PostPosted: 21:57 - 09 Oct 2017    Post subject: Reply with quote
SophR so good wrote:
Courier265 wrote:
Very Critical
The colour change valve caps seem ok but I'm not convinced mine wasn't letting air slowly out
These are good until they bind to the valves and they become useless because you can't get air in anyway, same with the naff anodised ones.
https://www.electricscooterparts.com/images/accessories/VCP-035-HOW-IT-WORKS.png
CBF 125 -> CB400SF -> GSX600F -> ZX6R (G1) -> GSXR1000 K4 -> ZX6R (B1H Stunt bike) -> VFR800 -> R1 5PW -> Sprint 1050 -> Fireblade 929 -> ZX10R C2H
The last post was made 6 years, 199 days ago. Instead of replying here, would creating a new thread be more useful?
Page 2 of 2
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.76 - MySQL Queries: 17 - Page Size: 54.72 Kb
