kramdra |
kramdra World Chat Champion
Posted: 18:20 - 08 Oct 2017 Post subject: 2 stoke hole borer, siezed! overheated? |
Been digging some holes. Using this www.ebay.co.uk/itm/262719926631 Its my first time with 2T and Ive broke it, though it did dig many holes. Looking down the intake and exhaust it has quite a bit of scoring, is this serivicable or fatal? I gave it a good squirt of 4T oil and a wiggle of the rotor free'd it up. I need to make 3 more big holes this week and then a couple weeks before I do any more. Can I continue using it, it now turns over smoothly but I did not try starting. Or should I ebay a new piston/barrel kit to avoid damaging the crank, other bits?
Using 25:1 mix (500ml petrol : 20ml 2T oil) It did not like running without choke so kept it between 3/4 - fully on. Dug several 4" holes in quick sucsession, full throttle for about 5 minutes, we hit some hard ground that it was struggling to break up. Suddenly it slowed and cut out, I gave the pull start a tug, moved a turn then seized. Overheated? I did not let it run any significant time without throttle - I know that means no oil, so avoided.
Bloody awesome tool. Hard clay ground that spade wont touch, this puts an 200mm wide x 900mm deep hole in a couple seconds, but I have a large bruise on my leg.. |
Tankie |
Tankie Crazy Courier
kramdra |
Tankie |
- Super Spammer
kramdra |
alains |
alains World Chat Champion
kramdra |
Posted: 21:55 - 10 Oct 2017 Post subject: |
Polarbear |
Polarbear Super Spammer
Posted: 22:17 - 10 Oct 2017 Post subject: |
It does look a bit scruffy
Are pistons, rings and barrels readily available or will it just be cheaper to by a new one and use your old one as spares? ____________________ Triumph Trophy Launch Edition |
kramdra |
Robby |
Robby Dirty Old Man
The last post was made 6 years, 199 days ago. Instead of replying here, would creating a new thread be more useful? |
