What would you do..?
PostPosted: 22:32 - 10 Oct 2017    Post subject: Reply with quote
Tdibs wrote:
If the stand is collapsing from rust, I would get under the bike with a torch and feel/look for any bad corrosion in the sing-arm before parting with money. Thumbs Up
Swing arm carries the shaft drive and is built like a brick shithouse. Have a look on ebay, there are always loads because hey outlast the bikes.
Triumph Trophy Launch Edition
mentalboy
PostPosted: 00:13 - 11 Oct 2017    Post subject: Reply with quote
Polarbear wrote:
Pah, intellectual semantics.
I'm talking about tree destroying, Victory engine case ruining good old below pH7 acid. Cool
Recalling my mid '80's geology 'O' level course, I believe the term you are looking for is carbonic acid.
Make mine a Corona.
sickpup
Old Timer
PostPosted: 08:55 - 11 Oct 2017    Post subject: Reply with quote
At that price I would guess its a 650. The centre stands can be a bit of a bitch to replace on these as the exhaust needs to come off but as long as everything is ok the proce is more than fair. Its not like the centre stand is needed to adjust a chain afterall.
bacon
PostPosted: 13:34 - 11 Oct 2017    Post subject: Reply with quote
Yeah it is a 650. Cosmetically not perfect but seems pretty good.
Still undecided, I don't suppose it will depreciate either way so I may as well..
The centre stands seem to be a discontinued part as well
DrSnoosnoo
PostPosted: 14:52 - 11 Oct 2017    Post subject: Reply with quote
They've all dissolved in the warehouses ...
bacon
PostPosted: 19:29 - 13 Oct 2017    Post subject: Reply with quote
So I ended up buying the Deauville last night.....
Full details:
*£950
*42k Miles
*Recent Motad downpipes and exhaust
*Built in Starcom Intercom setup along with a pair of lids with it all fitted in, stripped the headsets from each helmet and they (the helmets) can probably go in the bin...
*Official Honda top box
*Heated grips, but they are currently wired so they can be turned on without the bike ignition being turned on, will likely redo it with a relay.
*12v charger in left cubby slot, along with an "Aux in" that is linked to the intercom setup
* CB radio in the offside pannier, was that a "thing"?
Rode to work and back today on it, so 50 miles covered, my initial thoughts are:
* Slow....so slow, the upside is I won't be losing my licence on the commute.
* Very very comfortable, never had a bike this comfortable before, though my past bikes have been predominantly sport bikes, but that doesn't take anything away from the Deauville, it is like an arm chair.
* Nice and quiet when starting it up at 6-6:30am
* Handling is best described as soft....kinda floaty....
* Combined brake system is suprisingly effective
* I feel like a bit of a high vis wanker while riding it, haha, maybe I need to get a high vis....
Here it is in all of it's "glory"...
pepperami
PostPosted: 20:44 - 13 Oct 2017    Post subject: Reply with quote
Nowt wrong with that Thumbs Up it’ll make a good workhorse.
Tracer1234
PostPosted: 23:08 - 13 Oct 2017    Post subject: Reply with quote
Full details:
*£950
*42k Miles
Certainly gunna get the job done!
sickpup
Old Timer
PostPosted: 08:16 - 15 Oct 2017    Post subject: Reply with quote
It was on escort duty bikes and there are a fair few about but the owner my just have liked listening to truck drivers.
They feel slow as its such a relaxed engine but keep an eye on the speedo, the engine is deceptive.
Perfectly ok on these to wire heated grips into the front brake light live, its how Honda does it.
If you want me to make you up the loom part required to do this PM me.
It looks like it doesn't have hand or feet deflectors which are worth getting.
The hand deflectors are here but I can't find the part number for the lowers
bacon
PostPosted: 19:54 - 15 Oct 2017    Post subject: Reply with quote
I have had a poke around the bike this weekend, the wiring seemed a bit busy around the battery, so I spent a short while working out what was what and labeling it all up.
It appears to have the wiring and a little 12v 2 pin style power connector in the right side pannier, no actual cb radio present, so the previous owner must not have understood what was in there when he was explaining it to me.
The intercom works, I'll velcro them into my current helmet and see how it is sounds on the move.
Front brake light live? As in the live wire that feeds the brake light switch? That would be great dude, I'll send you a pm now.
I did see some feet and hand deflectors on ebay before I bought it, but obviously didnt bid for them. I'll check them out if they make the difference, I was looking at some Tucanaos for the coming winter.
But I have to say, I'm rather pleased with my purchase, it is incredibly practical Thumbs Up
sickpup
Old Timer
PostPosted: 07:58 - 16 Oct 2017    Post subject: Reply with quote
As long as the fuse on the grips doesn't exceed the fuse on the lighting circuit you should be fine. Most grips use a 5amp fuse so definately ok.
bacon
PostPosted: 20:32 - 18 Oct 2017    Post subject: Reply with quote
Ok 200miles in and I thought I'd add a few more comments.
So I haven't been using the top box, so that has probably helped with aerodynamics, but I have used it every day for work since purchase, I've achieved 56mpg from the first tank, I'm rather pleased Smile
I'm also actually enjoying the bike a lot more than I expected too. It's very sure footed, very stable, it can corner just fine in fact, very confidence inspiring even in the wet. Ok it's not a straight line hero, but it has plenty of torque for a 650 and is perfectly happy sitting at 70-80 indicated which is exactly what I need from it.
I would happily recommend the Deauville Thumbs Up long term reliability will be the next test
PostPosted: 21:55 - 18 Oct 2017    Post subject: Reply with quote
They are great at what they do. Dull, maybe but will eat mile after mile with you in comfort well after a lot more expensive bikes have crippled you.
I toured Europe with a mate on his 650 Deauville, me on my Goldwing. He never bitched about the comfort even on 300 mile successive days.
The last post was made 6 years, 191 days ago. Instead of replying here, would creating a new thread be more useful?
Page 2 of 2
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.72 - MySQL Queries: 17 - Page Size: 87.34 Kb
