mudcow007 |
mudcow007 World Chat Champion
Posted: 21:04 - 08 Oct 2017 Post subject: Blackbird - runded outta electricities |
So riding home on Friday an my new (to me) bike died.
Dead battery, stupidly its got a voltage light thing on the dash/ cluster which shows voltage levels (red, amber and green) which i had been ignoring
Got the bike home with a jump start, when I got the bike back battery was showing 11.8v left it over night on my optimate. just so there is a healthy voltage on the battery
The bike had a new reg/ rec earlier this year an it came with a new spare. Speaking to the previous owner he reckons it the genny/ alternator (which he has offered to go half's on - which is damn decent of him I reckon). The genny was replaced last year as well.
I have left the bike with him as I don't have the time at the moment to strip all fairings off etc.
why do Honda's always have issues with electricals!?!?!? |
Fisty |
Fisty Super Spammer
RhynoCZ |
RhynoCZ Super Spammer
Pete. |
Pete. Super Spammer
RhynoCZ |
Posted: 21:51 - 08 Oct 2017 Post subject: |
That's only one model. ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
Posted: 00:17 - 09 Oct 2017 Post subject: |
Why don't you test the windings with a multimeter before stripping half the bike apart and blowing your wad on possibly unecessary work?
If the alternator was replaced last year, it's vanishingly unlikely it's gone again unless whoever fitted it fucked it up.
Reg recs do go. So when you've tested the alternator and found it's perfectly ok, blow your wad on a mosfet reg/rec instead.
https://www.electrexworld.co.uk/cgi-bin/sh000001.pl?WD=cbr1100xx&PN=RR690-Honda-VTR1000-CBR1100XX-VTX1800C-%2ehtml#SID=1031?a1_21RR690
Alternator test in brief:
Unplug reg/rec. Set meter to resistance. Measure the following on the connector block that's connected to the bike.
Equal, reasonably low resistance between any pair of yellows. Open circuit (infinity resistance) between any yellow and the green.
Meter on volts DC: Battery voltage between red and green all the time. Battery voltage between green and black with ignition on only.
Dynamic test with meter on volts AC and engine running (caution, you could get a dunt if you get your fingers in the way). Roughly the same voltage, increasing with rev speed between any pair of yellows. Can be as high as 70v but it's a roughly equal output we're looking for here.
If all that checks out, your alternator is fine. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
mudcow007 |
Posted: 16:57 - 10 Oct 2017 Post subject: |
There shouldn't be continuity between any of the stator wires and earth. That should be a fully open circuit.
Continuity between a stator winding and earth would imply a short either on the stator itself or one of the yellow wires leading away from it. The last thing is worth a check? I've seen one pinched under a cover/body panel more than once.
There should be continuity (coil resistance) between any pair of coil wires. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
winz |
winz World Chat Champion
mudcow007 |
Posted: 22:52 - 10 Oct 2017 Post subject: |
Evenin all
Strator (an gasket) were picked up tonight from "Jaws".
fingers crossed its should be fitted tomorrow an ready to rock tomorrow.
It already has the reg/ rec from "Jaws" fitted. hopefully this is still cool
I think i will check over it my self when it back in my shed
ta |
Robby |
Robby Dirty Old Man
mudcow007 |
Posted: 00:37 - 12 Oct 2017 Post subject: |
Fixed!
Steady 14- 14.8v under throttle - yay!
Charge light shows green, its never done that |
Matt B |
Matt B World Chat Champion
Posted: 08:58 - 12 Oct 2017 Post subject: |
Well done on fixing it
Not so much for ignoring the charge indicator in the first place ____________________ stinkwheel: He had an animated .gif of a cat performing fellatio. It's not socially acceptable. It can have real life adverse effects on other people. |
P. |
P. Red Rocket
Bikeless |
Bikeless World Chat Champion
mudcow007 |
The last post was made 6 years, 195 days ago. Instead of replying here, would creating a new thread be more useful? |
